Buying a new HD Plasma TV. Do I need a new antenna on my house? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-16-2012, 04:17 AM - Thread Starter
Sarah Jorgenson's Avatar
The current antenna has been there for 15 years. It works fine with my crappy TV and converter box. Do I need a new antenna? I do not have cable or dish. I live in Minneapolis.
Sarah Jorgenson is offline
post #2 of 3 Old 11-16-2012, 06:14 AM
tylerSC's Avatar
Quoted: 385 Post(s)
Liked: 122
If your current antenna is working with your converter box, then it should work as well with your new plasma TV.
tylerSC is offline
post #3 of 3 Old 11-16-2012, 10:59 AM
ProjectSHO89's Avatar
Quoted: 127 Post(s)
Liked: 90
It's going to be up to the performance of the tuner in the new set, but if your signals are decent enough, it should work fine.
Unfortunately, it's not always the case that a built-in tuner is going to be as good as the converter boxes. The boxes had to meet published specifications for the coupon program but there is no way to know beforehand how good a tuner will be in any given set. If it's a well-known maker, the odds are good that it will have a decent enough tuner. LG, Sony, Samsung, Vizio, and Sharp sets have all done well in my personal experience.
ProjectSHO89 is offline
