Need Advice on Picking out an Antenna in Southeast Kentucky - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-05-2012, 09:37 AM - Thread Starter
jamie9427's Avatar
I live in southeast Kentucky right on the Virginia line in Smith Kentucky its very mountainous. I have used a small $30 lava hd antenna for the past year or so and can pick up WBIR 10 from Knoxville and WJHL 11 from Johnson City. My question is, if I buy a bigger or more powerful antenna or mount it higher could I recieve the other stations from Knoxville or the Tri Cities or maybe even WLOS 13 from Asheville NC?
jamie9427 is offline
post #2 of 3 Old 12-05-2012, 05:50 PM
tylerSC's Avatar
Quoted: 609 Post(s)
Liked: 143
A better antenna would definitely help. Consider Winegard 7698 or Antennacraft HBU55. And a good preamp possibly.
tylerSC is offline
post #3 of 3 Old 12-06-2012, 03:08 AM
MACINTN's Avatar
Go to tvfool.com and get the results using your address then post it here(your address will not show).Then someone will be able to help you.
MACINTN is offline
