Antenna for portable tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-05-2013, 08:52 AM - Thread Starter
drew64's Avatar
Quoted: 13 Post(s)
Just bought a 7 inch portable LCD tv. Works well but the antenna which is telescoping doesent pull in channels well. I have a leaf antenna for my plasma I tried and it works great but not portable enough. Are there any replacement antennas for these portable TVs.
drew64 is offline
post #2 of 3 Old 01-05-2013, 06:46 PM
tylerSC's Avatar
Quoted: 786 Post(s)
Liked: 180
There is a version of the Mohu Leaf that comes with a portable stand, and I believe you can order the stand separately. But if you want a similar smaller antenna, then the Artec postcard antenna reportedly gets good reviews for reception. It is a smaller flat panel antenna which should work well as a portable antenna.
tylerSC is offline
post #3 of 3 Old 01-05-2013, 11:31 PM
eherberg's Avatar
Quoted: 93 Post(s)
Liked: 27
Unfortunately the Leaf Stand is not really a stand - it has sticky tape on the bottom and without using the tape, it can't stand up on it's own. I ended up just taking a free-standing magazine holder and taping the Leaf to it. A lot of other items you have in your house could also be used -- paper towel holder, for example.
eherberg is online now
