Fox 5, Atlanta - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-25-2013, 08:41 AM - Thread Starter
jclark2878's Avatar
This is my first post so bear with me. I just began my transition from Uverse TV to antenna. I am located north of Gainesville approximately 45 to 50 miles north east of Atlanta. I am using a Clearsteam 4 antenna (rated 65 miles +). I have oriented the antenna slightly NW at approximately 220 degrees. I get 2, 8, 11, 14, 17, 36, 46 and 69 perfectly and very stable. The problem is channel 5. I get a good picture but it is not stable. The signal is frequently breaking up.
I have tried several different positions but no improvement. Any suggestions as to what to do?
jclark
jclark2878 is offline
post #2 of 3 Old 01-25-2013, 09:24 AM
jimboy's Avatar
You might want to try posting this in the forum for your TV market....
http://www.avsforum.com/t/384623/atlanta-ga-ota
jimboy is offline
post #3 of 3 Old 01-25-2013, 11:59 AM - Thread Starter
jclark2878's Avatar
Thanks, I will try that.
jclark
