AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Local HDTV Info and Reception (http://www.avsforum.com/forum/45-local-hdtv-info-reception/)
-   -   Help in Denver (http://www.avsforum.com/forum/45-local-hdtv-info-reception/1459227-help-denver.html)
jimx777 02-19-2013 07:55 PM
1 Attachment(s)
Hi all
New to forum and have little to no knowledge in this subject
so any pointers would help.
Want to go OTA with DVRS and streamers in the next couple months
So my first step is antenna called Antennadirect and a lady recommended the www_antennapoint_com_antennas_show_id_9009 west san juan drive littleton, co 80128.pdf 456k .pdf file
Clear Stream 2V so OK I bought it.
To cold to go outside yet OK maybe not too cold but soon.
So I put it in my upper level bedroom to see the results
I hooked it up to a 2009 Toshiba 42LCD so tuner should be OK
I received 5.1 7.1 7.2 9.1 9.2 12.1 12.2 and distant 78 { Spanish }
Please help what did I do wrong or is this my destiny ?
Thanks for your help
Jim
ProjectSHO89 02-20-2013 02:57 AM
You need to go back into the TV's setup menu, take it off the CABLE setting (put it on ANTENNA), and re-run the channel scan. See TV set owner's manual, if necessary.
Your antenna choice should work fine.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
