How to Hook up a converter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-09-2013, 06:10 AM - Thread Starter
Valkster's Avatar
I just hooked up my old vcr using a Dish Pal converter. I just used it a couple of times and forgot about the great TV guide it has on it and even better reception that my new Magnavox DVR/DVD!! It will pull in stations that the Mag. won't.
Now my question is how to hook it up to my new Magnavox (don't need the vcr) so I can have the TV guide and even better reception to my HDTV.
Valkster is offline
post #2 of 3 Old 03-09-2013, 06:15 PM
unclehonkey's Avatar
Quoted: 287 Post(s)
Liked: 60
The DTVPal only does SD so why would you want to view SD on a HDTV?
unclehonkey is offline
post #3 of 3 Old 03-10-2013, 06:48 AM - Thread Starter
Valkster's Avatar
True. Maybe I will connect a splitter and put a small TV beside my big one for the tv guide.smile.gif
Valkster is offline
