Samsung DVR -- recording failures - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-20-2013, 12:07 PM - Thread Starter
jm4duryea's Avatar
I have the Samsung SMT-H3270. Problem was occasional, now getting worse. As an example, I set the box to record Golden Boy last night in HD. When I go to play it, nothing happens --- black screen. All the stats on the recording look fine. If I try fast forward, it will immediately go to end of recording, asking the typical, save, delete or restart. If I restart, same thing happens, ie., nothing. I had also set the box to record a program an hour before and that was fine. it's an intermittent problem but is becoming more frequent, and of course it happens on programs that are not offered on onDemand. Anyone else have this problem? Or some insight? Thanks!
jm4duryea is offline
