No reception - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-28-2013, 10:49 AM - Thread Starter
ddfarm's Avatar
I have always received great local reception for channel 6,6.1,6.2, 6.3 ,8 and 12.3, 23.1, 23.2, 57.1, 35.1, 35.2 but as recent as a couple of months ago the picture for certain channels on my TV begin to break up ( little squares would appear, like the ones when I run my microwave). Then reception just stopped. Now I get "no signal" for channel 6, 6.1, 6.2, 23.1,23.3 and 57.1. Any ideas why this would be? I use a very good attic antenna that has not changed. I have check the wire and it is the same.
ddfarm is offline
post #2 of 5 Old 04-28-2013, 11:09 AM
Speed Daemon's Avatar
Quoted: 91 Post(s)
Liked: 47
It may be a good time to do a channel scan once again. Some of the channels that you have listed (6 & 8) are no more. Others may have changed frequencies since your last scan.
Since the signal degraded and quit, I'd look for a connection that has come loose, or possibly rodents chewing through your RF cable.
You get what you pay for.  For professional advice, pay the professional rate.
Speed Daemon is offline
post #3 of 5 Old 04-28-2013, 11:17 AM
Trip in VA's Avatar
Quoted: 863 Post(s)
Liked: 255
Send a message via AIM to Trip in VA
Guessing you're in Richmond, VA. Those stations were involved in an on-going equipment failure situation and are at reduced power.
The Richmond thread will give you more information.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #4 of 5 Old 04-28-2013, 11:32 AM - Thread Starter
ddfarm's Avatar
How do I get to the Richmond thread?
ddfarm is offline
post #5 of 5 Old 04-28-2013, 11:50 AM
Trip in VA's Avatar
Quoted: 863 Post(s)
Liked: 255
http://www.avsforum.com/t/435750/richmond-va-hdtv/8800_100#post_23213508
- Trip
N4MJC
RabbitEars
