Looking to trouble shoot my OTA issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-20-2013, 12:34 PM - Thread Starter
pmacdonaldii's Avatar
So according to TV fool I should not really need an external antenna.
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1dda991a1a48f2
I have one mainly because I lie in a relatively depress area and want to make sure I had enough height to get clear signal.
The majority of the time I receive 2, 4 and 5 fine. 7 is okay a lot but gets flaky. I also get 10 and 12 very well. 25 is good. 38 is iffy and the 44's are good a lot of time but regularly break up during show making it very hard to watch. 56 usually good and I get the ION 68 channels good all the time.
I have a Wineguard Medium antenna like this one Winegard HD7694P High Definition VHF/UHF Antenna. Now Ideally I need this split into multiple rooms, because right now I have split and one room does not get all the channels of the other room. Please ask your questions, so I make sure to give all the details.
Side note did anyone else loose 7 and or 10 last night during the apprentice?
Edit: Can and Admin move this to the Boston OTA area?
pmacdonaldii is offline
post #2 of 2 Old 05-20-2013, 05:24 PM
Dominic26's Avatar
Quoted: 54 Post(s)
From your TVFool results, I would post at the Boston OTA forum You will get good help there.
Dominic26 is offline
