Strange Station - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-27-2013, 06:35 PM - Thread Starter
squirrel 24's Avatar
This evening just going through the local channels haven't rescanned tv or anything .KDLO appears as channel 3.1 3.2 no picture or nothing only thing I can find online is Florence South Dakota . How did this happen without a rescan. UTV is 3.2?
squirrel 24 is offline
post #2 of 4 Old 05-27-2013, 06:37 PM - Thread Starter
Antenna pointing south from Virginia clear stream 4 antenna.
post #3 of 4 Old 05-28-2013, 05:50 AM
Trip in VA's Avatar
Quoted: 554 Post(s)
Liked: 147
Send a message via AIM to Trip in VA
https://en.wikipedia.org/wiki/E-skip#Sporadic_E_propagation_.28E-skip.29
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #4 of 4 Old 05-29-2013, 01:20 PM
TomCat's Avatar
A rescan is always a good idea after changes, and since we are not told when changes occur, a regular rescan is a good idea.
While it will straighten out issues if things have changed, really the only time you absolutely need it to find a channel is when the physical and virtual channels do not match, and you also have no information regarding that from your last scan.
That means that if you have a current scan in the database that indicates what the virtual/physical mapping for a station is, that if they add other subs, some TVs will pick them up without a scan, and some will not, depending on the particular design of the tuner.
There's no place like 127.0.0.1
TomCat is offline
