Hello Raleigh/Durham area AVS folks. I have re-written this initial post and will try to make it a pointer to some relevant information about our community.
*For information about MUCH more than can be pointed out here in this intial post please USE THE SEARCH. Especially once you are within a large post, such as this one then click on the "Search this Thread" button beside the Thread Tools drop-down.
*For information about QAM reception I would direct your attention to this wonderful site maintained by Erik Garci -
http://home.roadrunner.com/~res18h39/channels.htm Digital TV Channels in Durham, NC[/url]
*For information about antenna reception (Off The Air) check out antennaweb.org. Plug in your address and it will tell you what type of antenna you need and which direction to align it.
* Our local uber-HDTV station WRAL gives away free antennas. Check out Antenna Give-away
* On the subject of free antenna's scsiraid pointed out this information. CLICK HERE
* Your physical location is often helpful in troubleshooting issues and answering questions. Be sure to edit your profile and put in your town and state.
There are a ton of good posts in the forum. My intention is not to re-write everything here in this post or to try to be the decision maker on choice A -vs- B. I would rather just have this post point out fairly routine information that is well documented.
Some posts or information I would like to point out include:
* What to ask for when calling TWC to setup your new HDTV.
* What to ask for when calling for DIRECT-TV service.
Send updates via private messages to WildBill. I will try to be prompt.
