Raleigh, NC - HDTV - Page 474 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
Old 06-17-2011, 08:33 PM
scsiraid's Avatar
Originally Posted by HDMe2 View Post
When did the antenna work finish?
I tried just a couple of days ago and still no scan for WTVD... so I was waiting to read something in this thread. I'll have to try and scan later to see if it is back now.
Do we know that they have finished? The signal strength is about the same as it has been here. 25dB SNR.
scsiraid is offline
Old 06-17-2011, 09:23 PM
nitdawg's Avatar
Originally Posted by scsiraid View Post
TWC's Channel Changes website indicates the following...
On or about June 16th, Time Warner Cable will be making technical changes to our cable system that may disrupt your ability to view the following unencrypted (in-the-clear) channels on a digital television or other device that includes a QAM tuner (a ClearQAM device): WTVD, WTVD HD, WTVD Live Well HD D2, WTVD Accuweather D3.
http://www.timewarnercable.com/East/...nelchange.html
Perhaps they have taken ABC-11 to SDV?
Boo. I still use QAM for 2 tv's and lost wtvd 2 days ago. Hopefully its just temporary.
nitdawg is offline
Old 06-17-2011, 09:54 PM
HDMe2's Avatar
Quoted: 693 Post(s)
Liked: 489
Originally Posted by aldamon View Post
I think the WTVD/ABC11 antenna upgrade worked. It was a chore to tune in the channel before, but I hardly have to try to get a signal now.
I was responding based on aldamon's post (quoted above yours) that said he was getting it better now. I haven't tried yet today, but last I tried, it was still gone for me... and I used to have no trouble getting WTVD... so I have to think that once the antenna work is completed I would get it back again.
HDMe2 is offline
Old 06-18-2011, 04:41 AM
vidiot1985's Avatar
I remember when they last tried putting WNCN (I think?) on some low channel, lots of folks had trouble tuning it, complained and they reshuffled again a few days later. Maybe they didn't learn that lesson and made the same mistake with WTVD.
So you might want to complain to TWC about it if you haven't already. And maybe complain to WTVD that you can't get their signal and they'll push TWC from the other end.
vidiot1985 is offline
Old 06-18-2011, 04:42 AM
Scooper's Avatar
I had some problems for a couple days (OTA), but they seem to be resolved now.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
Old 06-18-2011, 01:47 PM
jamieh1's Avatar
Ive started to pull in WTVD at night here in Washington NC, 88 miles from the tower. Have not pulled in since the transition 2 years ago.
Directv HD
Samsung UN50H6350 50" LED Smart TV
Channel Master 4228 antenna
Greenville NC, Ral-Durham NC ota market
jamieh1 is offline
Old 06-18-2011, 06:15 PM
aldamon's Avatar
Originally Posted by jspENC View Post
That's a good sign. Maybe we will hear from others the same thing. It would be nice to hear this from someone 70 or 75 miles away that they can now view the channel instead of pixelation or cutting out. I might have to get a real VHF antenna and see what I might can do way down here.
Well, with the unamplified antenna in my room, the biggest trouble spot for WTVD in my house, the signal was very strong this week but weak again this weekend. Placebo maybe? Dunno but it seems like they're still tweaking to me.
aldamon is offline
Old 06-20-2011, 07:37 AM
nitdawg's Avatar
Originally Posted by Trip in VA View Post
If that's the case, I'd bet money they're looking to change from horizontal polarity to circular.
- Trip
Nice! I just got an email from one of their engineers and indeed, they replaced their horizontal polarized antenna with a circular polarized version for better indoor reception. If I had a prize befitting, you would be the winner.
nitdawg is offline
Old 06-20-2011, 08:00 AM
Trip in VA's Avatar
Quoted: 589 Post(s)
Liked: 161
Send a message via AIM to Trip in VA
Hehe, no prize is necessary.
I just hope it helps with reception.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
Old 06-20-2011, 11:37 AM
JJ555's Avatar
It has been 5 days and Time Warner QAM WTVD HD is still missing (or if they have re-mapped it, I can't find it). Anyone know what the story is?
JJ555 is offline
Old 06-20-2011, 01:30 PM
Kevad's Avatar
Have you called Time Warner to ask what's going on? Might be worth it - I just have RR service, so I don't officially get the QAM channels and didn't want to call and complain. Ended up switching to OTA, and the one trouble spot I'd had in the past (WTVD) has been fixed with their recent transmitter upgrade.
Kevad is offline
Old 06-20-2011, 01:46 PM
nitdawg's Avatar
According to one of their engineers, the antenna work for WTVD is complete. The physical QAM channels are now on 99-1, -2, and -3. Their previous channel coincided with channel 22 and were experiencing some interference issues...117 MHz was best available. This is likely below signal traps used, so its being stopped out at the curb most likely.
nitdawg is offline
Old 06-20-2011, 01:50 PM
thewallisgreen's Avatar
I'm also unable to get TVD. Engineering said they were moved to 117 MHz due to interference at QAM 78.
I was told the rescan should have brought them back... but it didn't. Manually tuning to 99-1 and 99-2 also failed. I guess at this point it's just a waiting game and hoping there are enough complaints to warrant TWC trying them somewhere else. No ABC11 for me until they do!
thewallisgreen is offline
Old 06-20-2011, 03:21 PM
JJ555's Avatar
Thanks! I'm picking them up now on 99-1, -2, -3.
JJ555 is offline
Old 06-21-2011, 06:28 AM
donnied4rko's Avatar
Same here... I'm using an HDHomeRun tuner and still get nothing on QAM 99-1 and 99-2. All other QAM channels come in fine.
donnied4rko is offline
Old 06-21-2011, 10:22 AM
NCCaniac's Avatar
Quoted: 58 Post(s)
Liked: 82
Rather ironic considering all the ads TWC is running now that say cable is superior to sat because sat doesn't give you your local channels (which, of course, is extemely close to false advertising....).
Mark
Panasonic VIERA TC-P60ST60 Plasma, NAD T775 receiver, OPPO BDP-103, AT&T uVerse
Era D5 front left/right, Era D5 LCR center, Triad in-ceiling Mini 8/LCR surrounds, Martin Logan Abyss and SVS SB12-NSD subs
NCCaniac is online now
Old 06-21-2011, 04:41 PM
Retspin's Avatar
Quoted: 24 Post(s)
WTVD's antenna upgrade must be working out, my mom can now get them in Greene County after being MIA for 2 years.
Retspin is online now
Old 06-21-2011, 08:28 PM
nitdawg's Avatar
My antenna setup is pretty simple. I have a CM4228HD that I got from WRAL. It is attic mounted, connected to a drop-amp in the attic, then down to my media closet then to my HTPC (PCIe dual Hauppauge 2250). As far as placement, I'm in a tough spot since WUNC and the Garner farm are 160 degrees apart from each other. I aim my antenna 120 right at the Garner farm. This gives me perfect signal for all the signals in that direction. I have multipath issues with WUNC, since my SNR goes from high and then just drops (my kids love their PBS). My recent solution (thanks to Drew!) was to split the line coming into my HTPC, get a kworld USB tuner ($25)...in the end, I got another tuner which really did do a much better job with the WUNC signal, somehow taking care of that multipath.
I was planning on getting a second antenna and possible a network tuner, and after reading about the leaf antenna, I decided I would at least give it a whirl. Well, first off, I hooked it up to a panel downstairs in my office, scotch taped it to a wall and was able to tune in everything. I had no means to test the signal strength on that TV, but everything looked great.
Then I went up to my attic, placed the leaf almost in the same direction (heading at 100) and plugged tried that in lieu of my CM4228HD. Went downstairs, pulled up the Huappauge tuner monitor and I maxed out my SNR for all of Garner and WUNC without any drops. I even picked up the CBS affiliate out of Greensboro at 70%.
The only thing I wouldn't mind getting is WRPX, but as it is, I'm going with the leaf and my 3 tuner setup for now. I will see how it goes over the summer.
Anyways, for something 1/8th the size of my current antenna, this little tiny piece of something really does work. Since there is no difference between front and back, I think its pretty ideal for my setup.
Just wanted to share.
Best,
NitDawg
nitdawg is offline
Old 06-21-2011, 09:18 PM
Splat!'s Avatar
Coming through fine for me on a Samsung HDTV's built-in tuner. Oddly enough, until I boosted the signal, ABC-11 was the only clear-QAM local coming in.
Splat! is offline
Old 06-22-2011, 11:28 AM
NCCaniac's Avatar
Quoted: 58 Post(s)
Liked: 82
Wow. I am in Cary and also have a CM antenna in the attic. I may have to try using the Leaf I got for the upstairs TV in the attic and compare it to how well the CM antenna does for my downstairs media center.
Mark
Old 06-22-2011, 12:05 PM
DonB2's Avatar
A coworker is looking to cut his cable bill. He was thinking just keeping TWC roadrunner and dropping TV CABLE. He was thinking of getting a Antenna and going the OTA route.
My question is:
If he drops to basic tv cable will he also get the Subchannels like I get with OTA? i.e. 50.2 and 5.2 and so on?
DonB2 is offline
Old 06-22-2011, 12:30 PM
nitdawg's Avatar
I was surprised as well. My biggest issue was with the backside reception on the CM. Now all expected channels are 30/30 with the little leaf. I may play around to try to get WRPX, or maybe point my CM in that direction and see if I can get it...but for $40, it performed as advertised. I'm going to set one up for my parent's HTPC setup down in Fuquay, so I'll see how that goes as well.
nitdawg is offline
Old 06-22-2011, 12:41 PM
nitdawg's Avatar
My question is:
The QAM subs are their for most of the channels. There is an extra sub for WUNC (the MX channel), 5.2, 11.2, 17.2, and 17.3, 22.2, 28.2, and 50.2. No subs for WRPX (only 47.1).
Basic cable tv is still $65/mo.
Broadcast tv is $19/mo
If you go with RR only they install a trap...this in the past has not affected the unencrypted QAM channels, it blocks out all the basic cable channels (1-74). However, WTVD and their subs are now on a frequency that is trapped. Also they occasionally move the channels around which can cause issues on HTPC software.
nitdawg is offline
Old 06-22-2011, 01:49 PM
DonB2's Avatar
nitdawg,
Does the "Broadcast tv is $19/mo" work with a TWC cable box to provide 4.1,4.2,4.4,5.1,5.1,11.1,11.2,17.1,17.2,22.1,22.2,28.1,28.2, 50.1, and 50.2? Basically the OTA channels?
DonB2 is offline
Old 06-22-2011, 07:07 PM
nitdawg's Avatar
nitdawg,
Pretty much, but no cable box...so if you have an analog tuner you will get the analog cable signal (so no HD) for channels 0, 2-24, a bunch of shopping channels. If you have a digital tuner (QAM) you will get the OTA equivalent for those channels you mention and in addition, 2 more HD channels WRPX (ion) and Durham Bulls HD Games channel.
nitdawg is offline
Old 06-23-2011, 09:06 AM
mdb77a's Avatar
My question is:
Well, he may get a nice surprise from TWC. I recently dumped my entire cable package (one HD DVR and a second TV with no box) and stripped down to just RR. The next day, "retention" called and asked me if I'd like to come back on board with the same set up plus Showtime for a year for $57 per month (total, after taxes). The price is valid for 24 months, cancel any time. Really can't beat that price. They are just basically paying me not to go to AT&T or satellite.
So, your friend might be able to cut his bill considerably for 24 months just by cutting the cord for 24 hours.
mdb77a is offline
Old 06-23-2011, 09:09 AM
DonB2's Avatar
Correct me if I am wrong but a Analog Tuner would not get the sub channels like 11.2 and 5.2 for "Broadcast tv is $19/mo".
But a TWC box would get 11.2 and 5.2 subchannels for "Broadcast tv is $19/mo"
Sorry for the confusion
DonB2 is offline
Old 06-23-2011, 11:22 AM
NCCaniac's Avatar
Quoted: 58 Post(s)
Liked: 82
Are you getting WTVD (11) and the subchannels? Recent posts here have talked about the upgrade to the channel 11 transmitter, but I rescanned last night on the upstairs TV and using the Leaf, I did not pick up anything for 11.1, 11.2, etc. (Whereas my attic CM antenna does pick up 11.1)
Mark
Old 06-23-2011, 12:08 PM
vidiot1985's Avatar
Originally Posted by mdb77a View Post
Well, he may get a nice surprise from TWC. ...
If six months ago TWC had done anything close to what they offered you, we'd still be with them, but no, they wouldn't do ANYTHING for us and wouldn't even give us the "triple play" deal (for new customers only of course) they kept bombarding us with on TV ads and mailings (not sure why they bothered mailing us offers they wouldn't let us accept, I guess a blanket junk mailing was cheaper than something targeted).
Old 06-23-2011, 12:17 PM
mdb77a's Avatar
this was not the 1st time i've dumped TWC cable entirely. so maybe it helped to be a repeat offender
mdb77a is offline
