Raleigh, NC - HDTV - Page 514 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #15391 of 15415 Old 05-17-2015, 10:01 AM
Retspin's Avatar
They are scattered on the 3 towers. WTVD, WRAL,WNCN, WRAZ, WRDC, and WLFL all call it home. As far as FM, WRAL, WQDR and WTKK are there too.
Retspin is offline
post #15392 of 15415 Old 05-17-2015, 12:33 PM
jspENC's Avatar
Quoted: 51 Post(s)
WQDR is on the analog WRAL tower as well as WRAL FM I believe. WTVD is on it's own tower further east. If you look for the three headed tower, that is the one with WNCN, WRAL, WRAZ, WLFL and RDC
jspENC is online now
post #15393 of 15415 Old 05-17-2015, 02:50 PM
AndThenScottSays's Avatar
Quoted: 44 Post(s)
WCMC 99.9 is also out there along with a UNC-TV translator for WUNC. The eastern tower is the one with the candelabra. I think WTVD is a little south of that and then the old analog/FM tower is the westernmost one. WRAL has a camera around the 1800ft level of the candelabra tower that looks at downtown Raleigh and the old FM stick is always visible in the corner of the shot.
AndThenScottSays is offline
post #15394 of 15415 Old 05-17-2015, 05:33 PM
Retspin's Avatar
WRDC went back to back to the analog tower and reused the old analog ch 28 antenna for digital operation. The rf 27 facility that they were using at the candelabra tower was switched over to WLFL.
Retspin is offline
post #15395 of 15415 Old 05-18-2015, 10:39 AM
mvcg66b3r's Avatar
Quoted: 29 Post(s)
Liked: 1
Originally Posted by timhk63 View Post
When traveling up interstate 40 near Clayton Garner area I can see what appears to be the antenna farm for the RDU tv stations. What stations are located there and are they all on the same tower?
RabbitEars has a list of stations at the Garner antenna farm. If two or more stations have the same ASRN number, they're on the same tower.
http://www.rabbitears.info/locationm...arner+%28NC%29
One person's craziness is another person's reality. - Tim Burton
mvcg66b3r is online now
post #15396 of 15415 Old 05-18-2015, 11:06 AM
Bruce Watson's Avatar
Most of the local broadcasters have transmitters in the Garner antenna farm. This Antennaweb.org chart shows you where this is located relative to Raleigh. The yellow line runs to the Garner location.
If you look closely, you can see that there are at least three towers because the location vectors vary just a little. Which station is using which tower I couldn't tell ya.
Bruce Watson is offline
post #15397 of 15415 Old 05-18-2015, 02:31 PM
timhk63's Avatar
why do channel 5 and 50 have two listings
timhk63 is offline
post #15398 of 15415 Old 05-18-2015, 03:21 PM
NCCaniac's Avatar
Quoted: 24 Post(s)
So....any idea why WRAL 5.1 seems to drop-out and pixelate more than it used to? I used to get the best, most stable signal for WRAL with my OTA antenna, but lately (last month or two), more often than not, WRAL is not as stable as WTVD and WNCN.
NCCaniac is offline
post #15399 of 15415 Old 05-18-2015, 03:34 PM
mvcg66b3r's Avatar
Quoted: 29 Post(s)
Liked: 1
One is for the primary transmitter (DT-LIC), while the other is for the auxiliary transmitter (DX-LIC).
Q. What do the DT-LIC, DX-CP, etc. all mean?
The first two letters identify the station type, and the second identify its status. DT is full-service Digital Television, DS is a Digital STA (Special Temporary Authority), DX is Digital auXiliary, DC is Digital Class A, LD is Low-powered Digital. As for status, LIC is licensed, CP is Construction Permit, APP is an APPlication for a construction permit, and an STA is special temporary authority to operate with the specified facilities without a license for those facilities, often used in cases of tower collapse and other unforseen events.
http://www.rabbitears.info/faq.php#layout
post #15400 of 15415 Old 05-18-2015, 04:00 PM
Quoted: 44 Post(s)
No problems here south of Greenville
post #15401 of 15415 Old 05-18-2015, 04:35 PM
jspENC's Avatar
Quoted: 51 Post(s)
Not living in the broadcast radius of WRAL, it is hard for me to say. Usually when I do find the signals coming in from these stations, WRAL is one of the more stable channels but WRDC seems to have the edge on all of them. I do not get WTVD because it is squeezed in between WNCT and WCTI. I would guess you have some kind of signal blockage like reflections or tree issues.
post #15402 of 15415 Old 05-18-2015, 11:40 PM
GCAVS's Avatar
Quoted: 12 Post(s)
Generally speaking, reception issues that start mid-March to mid-May are almost always Spring Foliage related.
GCAVS is offline
post #15403 of 15415 Old 05-19-2015, 11:03 AM
NCCaniac's Avatar
Quoted: 24 Post(s)
OK, going with that idea....does that have more impact on the lower number stations? Since all the channel transmitters now come from the same tower farm in Garner and my OTA antenna is mounted in the attic aimed at the antenna farm seems like all the channels would have some spring foliage impact unless it is more pronounced on the lower end stations.
NCCaniac is offline
post #15404 of 15415 Old 05-19-2015, 11:20 AM
GCAVS's Avatar
Quoted: 12 Post(s)
You are looking at that incorrectly.
WTVD actually broadcasts on RF Channel 11
WNCN actually broadcasts on RF Channel 17
WRAL actually broadcasts on RF Channel 48
You cannot go much higher than that.
How is your reception on WRAZ which actually broadcasts on RF Channel 49?
GCAVS is offline
post #15405 of 15415 Old 05-20-2015, 05:00 AM
jspENC's Avatar
Quoted: 51 Post(s)
All the high power UHF channels are coming in good this morning for me, and I have four splits off my antenna.
post #15406 of 15415 Old 05-20-2015, 06:11 PM
tylerSC's Avatar
Quoted: 385 Post(s)
Liked: 122
We are now getting into the summer season where weather conditions pull in the distant channels more favorably.
tylerSC is online now
post #15407 of 15415 Old 05-22-2015, 06:22 PM
timhk63's Avatar
I generally have trouble with WRAZ come summer time. There is a huge mass of pines about 100 yards directly in line with my antenna. I can still get but have to find the perfect direction. My antenna points to the NW 99% of the time. I can receive all the RDU stations and Greenville/Newbern without having to rotate from the NW direction. WLFL and WRDC are my best stations. I can generally get them just about anyway I have it pointed. I'm guessing it has something to do with my antenna being able to tune RF 27 and 28
timhk63 is offline
post #15408 of 15415 Old 07-01-2015, 06:07 AM
I knew this was coming but can anyone else confirm that clear qam local channels are officially gone from TWC?
beazster is offline
post #15409 of 15415 Old 07-01-2015, 06:32 AM
dah12's Avatar
In North Raleigh on TWC at my house, analog disappeared a couple of weeks ago, and locals have disappeared over the last 36 hours. They've taken it away, so now the increased internet speeds had better be close behind.
dah12 is offline
post #15410 of 15415 Old 07-01-2015, 08:27 AM
jspENC's Avatar
Quoted: 51 Post(s)
So are you going to go with antenna or subscribe to their cable TV? Living so close to the broadcast towers, I think it's foolish to pay for something that is readily available for free. Down here, the local channels are nearly $20, and you don't even get half of them, maybe a quarter of them.
post #15411 of 15415 Old 07-01-2015, 09:27 AM
ddi
ddi's Avatar
I asked TWC about that a week or two ago, and they said October.
ddi is offline
post #15412 of 15415 Old 07-01-2015, 09:55 AM
dah12's Avatar
Thanks for the info about internet speed rollout. It's better to have an approximate date than to be speed-testing daily and crossing my fingers, then frustrated.
I knew this day was coming and prepared with an antenna. Antennas can be bought for under $50, which was a good investment for me.
FWIW the two antennas I have that are working well in North Raleigh in my attic are the Mohu Leaf (I tested the variants and found minimal difference for my house, specifically in my location) and the Antennas Direct 43XG. The Mohus (which are omnidirectional) did great but I experienced dropouts when planes fly over, and I'm right by RDU. I recommend trying them for your location because they were perfect at my old house in Durham, getting both Raleigh and Greensboro stations. This multipath dropout from planes is lessened by the 43XG. There seems to be a few times in a month that antenna reception is barely watchable, like during a bad storm, but I can live with it for the 98% of the time that it's perfect for me.
dah12 is offline
post #15413 of 15415 Old 07-01-2015, 05:51 PM
Nullman's Avatar
I came here to see if it was my tuner. So yes, for me they are gone today - my tuner says encrypted now.
Nullman is offline
post #15414 of 15415 Old Yesterday, 08:42 PM
veedon's Avatar
Quoted: 383 Post(s)
Liked: 140
Anybody had any experiences (good, bad, or indifferent) with the DTA's that TWC is providing now? What is the reason behind having to call TWC to activate the unit once you have hooked it up?
As for OTA reception, my indoor antenna does a pretty good job with all of the local stations. When I do get pixelation or dropouts, it tends to be for the three stations that have the most powerful signal at my location, WRAL, WRAZ, and WLFL. I tend to attribute that to multipath issues.
veedon is offline
post #15415 of 15415 Unread Today, 04:48 PM
VisionOn's Avatar
Liked: 800
It's basically a CableCARD in it's own box. Now TWC knows exactly what channels you should be receiving on that one device. If someone used a splitter to send your cable feed to another household - even if they bought an off-the-shelf DTA - they wouldn't get any service.
VisionOn is online now
