Raleigh, NC - HDTV - Page 515 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #15421 of 15436 Old 07-27-2015, 09:46 AM
ColleenT's Avatar
Looking for attic antenna recommendation
We live in Apex and would like to put an antenna in our attic to get the main broadcast channels to at least 2 TVs, maybe more later. I record onto a HDD recorder and since TWC went all digital requiring a digital adapter I can't really record unattended. We have tried the Mohu Sky in our upstairs bedroom, but not all channels always come in very well. I've recorded shows with parts unwatchable. Is there a better attic antenna that someone can recommend?
ColleenT is offline
post #15422 of 15436 Old 07-28-2015, 09:05 AM
VisionOn's Avatar
Liked: 844
Appears MAXX went live here sometime in the past couple of days. 118/12 Mbps on Extreme.
That's on a 6141.
VisionOn is offline
post #15423 of 15436 Old 07-29-2015, 05:42 AM
dundakitty's Avatar
I'm in Durham and I first tried a Mohu Leaf, which didn't work for me.
Next I tried HD Frequency's "Cable Cutter", available here:
http://www.hdfrequency.com/best_indo..._antennas.html
It was much better, but still not good enough.
I finally went with a Channel Master 4228HD
http://www.channelmaster.com/CM_4228HD_p/cm-4228hd.htm
Even then WTVD (11) doesn't come in well.
I then home-built a high-vhf hourglass antenna and combined it with the CM4228HD. Instructions are here:
http://imageevent.com/holl_ands/loop...fhourglassloop
I used the one with seven reflector rods.
WTVD is now acceptable, but I still get some drop-outs. The channels I care the most about report a signal strength of over 90 on my TV, though WTVD is in the low 70's. Without the high-vhf antenna WTVD is in the low 40's. With just the high-vhf antenna connected WTVD is also in the low 40's.
If I were to do it again I might just get two CM4228HDs and combine them.
dundakitty is offline
post #15424 of 15436 Old 07-29-2015, 07:49 AM
Bruce Watson's Avatar
Quoted: 12 Post(s)
That's probably because WTVD is the only station in the area still using VHF. The Channel Master 4228 is designed for UHF, which is what all other stations in the area use. The 4228, good as it is, has peak efficiency (that is, maximum gain) somewhere in the middle of the UHF range, around channel 25 (UNC virtual channel 4.1) IIRC. Its efficiency is pretty far down by the time you get down to channel 11 (WTVD virtual channel 11.1). Wave lengths down there are just too long for efficient capture by a bowtie.
All I'm sayin' is that you're on the right track by adding your hi-vhf antenna. Aim needs to be good (including elevation). And you may want to add an amplifier for it.
Bruce Watson is online now
post #15425 of 15436 Old 07-30-2015, 05:06 AM
dundakitty's Avatar
The CM4228 has fairly good performance on high VHF, which is why I chose it. In my simple experiments I found it to perform on channel 11 just as well as the high VHF hourglass. I measured each antenna individually, then used a UHF/VHF combiner (Blonder Tongue ZUVSJ). The TV reported the same signal strength on channel 11 for each test. I finally ended up with a simple combiner, which raised the reported signal strength from the 40's to the 70's. Be sure to use identical lengths (and brands) of coax between the antenna and the combiner. The two antennas should be separated by at least 5 feet.
My house is in a depression surrounded by trees. The antennas are mounted in the attic. I'm sure I'd get better performance if I had them on a mast above the roof line.
post #15426 of 15436 Old 07-31-2015, 06:17 AM
jspENC's Avatar
Quoted: 57 Post(s)
An amplifier may make things worse on WTVD if you already have distortion going on from reflections in the attic or noise interference. The best thing to do is get out of the attic if you can with a real VHF high antenna with a horizontal boom. Even in the attic the proper antenna may be enough. WTVD has a lousy signal on VHF anyway from everything I have seen.
jspENC is offline
post #15427 of 15436 Old 08-01-2015, 09:03 AM
Daryl L's Avatar
Has WRAL 5.2 switched networks? It used to be ThisTV but I just noticed today that is now listed as H&I (Heroes & Icons) network.
Daryl L is offline
post #15428 of 15436 Old 08-01-2015, 11:08 AM
NCCaniac's Avatar
Quoted: 27 Post(s)
Liked: 45
Yes. They changed it this last Thursday. Ratings were dropping and they figured that a network showing more 1 hour shows would do better than one showing a lot of old movies. Time will tell if they are right. Here is a link to the article.
New Programming Coming to WRAL2
http://www.wral.com/change-coming-to-wral2/14799253/
NCCaniac is online now
post #15429 of 15436 Old 08-02-2015, 10:20 AM
Daryl L's Avatar
Cool. Although they did have some decent movies on ThisTV for the most part majority of them did not really appeal to my viewing interests. I looked at H&I's channel lineup and I will be more inclined to watch more programming on 5.2 with those shows. I know everybody does it feel this way but I'm just speaking for myself. Besides I still get ThisTV from another network on cable if I ever choose to watch any of their programing.
Daryl L is offline
post #15430 of 15436 Old 08-02-2015, 11:02 AM
AndThenScottSays's Avatar
Quoted: 46 Post(s)
WRAZ/50 has been on a weak backup transmitter for a month now. Anyone know what happened to their primary?
AndThenScottSays is online now
post #15431 of 15436 Old 08-02-2015, 11:07 AM
jspENC's Avatar
Quoted: 57 Post(s)
This TV used to be better. It has been airing movies that I don't want to watch for the last several months. The MOVIES! network has also gone downhill. Hero's and Icons is coming soon this month to my area as well, and will replace Antenna TV.
jspENC is offline
post #15432 of 15436 Old 08-02-2015, 11:59 AM
Quoted: 46 Post(s)
Who has Antenna TV/is getting H&I?
post #15433 of 15436 Old 08-02-2015, 04:18 PM
jspENC's Avatar
Quoted: 57 Post(s)
It's coming to 41.2 WTMQ August 15 I think, but not exact on the date.
jspENC is offline
post #15434 of 15436 Unread Today, 09:49 AM
Retspin's Avatar
I was told that they have a problem with the transmission line and that they are on a backup antenna. They are a no show at my mom's house Greene County now.
Retspin is online now
post #15435 of 15436 Unread Today, 10:00 AM
mvcg66b3r's Avatar
Quoted: 30 Post(s)
Liked: 1
Originally Posted by Retspin View Post
I was told that they [WRAZ] have a problem with the transmission line and that they are on a backup antenna. They are a no show at my mom's house Greene County now.
Why won't WRAZ simulcast temporarily on WRAL 5.3 (in 720p HD)?
One person's craziness is another person's reality. - Tim Burton
mvcg66b3r is online now
post #15436 of 15436 Unread Today, 10:52 AM
Quoted: 46 Post(s)
WRAZ is back to normal now
