Raleigh, NC - HDTV - Page 520 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #15571 of 15572 Old 08-04-2016, 10:39 AM
Can anyone confirm if the TWC Starter TV package (20 or so local channels) is DRM free? I was thinking about the hdhomerun prime with the Channels app on Apple TV but it doesnt support DRM channels. Thanks
beazster is offline
post #15572 of 15572 Old 08-31-2016, 09:21 PM
krick's Avatar
If by "DRM free" you mean "works without a DTA", then no.
I currently have the TWC "Starter TV" package and they went full digital and scrambled everything a few years ago. If you connect the cable directly to an HDTV without a DTA, it doesn't work.
I'll be dumping Starter TV shortly. As soon as I decide on an HDTV antenna to install in my attic.
Retspin likes this.
krick is offline
