New home construction- advice for D* newbie - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-17-2013, 08:54 PM - Thread Starter
cratch's Avatar
We're in the process of building a new house- we're currently in the framing stage.
I've always been a TWC customer, but I'm seriously leaning towards moving to DirecTV at our new home. I'm trying to make sure I have all my T's crossed and lower case J's dotted...
When should I get D* involved to determine where to place the satellite? If the roof is the best option, I want to make sure the installer doesn't mess up the roof shingles.
I'd like to also make sure the optimal location is used for the satellite.
Also, does DTV require different cabling than regular cable?
[edited- thanks cgmv for the explanation]
My Setup:
Sony XBR65X850D 65-Inch 4K Ultra HD Smart TV
Denon AVR-S900W
Harmony Hub Elite remote
7.1 speakers: (combination of Polk Audio and ceiling speakers)
cratch is offline
post #2 of 3 Old 06-17-2013, 09:10 PM
cgmv123's Avatar
Quoted: 42 Post(s)
Liked: 36
Just make sure the south side of your house doesn't have any trees that would mess up the signal. Dishes can be mounted anywhere as long you can get a clear line-of-sight to the satellites.
The cabling isn't special per sé, but not just any cable will work. Satellites run on (way) higher frequencies than some cables are designed for.
Also: DTV = ATSC/Over-the-Air Digital Television, DirecTV = D*
Max Vrany
@cgmv123
cgmv123 is offline
post #3 of 3 Old 06-17-2013, 09:16 PM - Thread Starter
cratch's Avatar
Thanks!!!
My Setup:
Denon AVR-S900W
cratch is offline
