Antenna Choice from Anderson - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By tylerSC
post #1 of 27 Old 07-15-2013, 01:26 PM - Thread Starter
Slowdog's Avatar
We decided a few months ago to rely on the over the air broadcast for our TV. We are located between Anderson and Townville, SC. Currently, all I have is a small flat antenna (which is really intended for interior use) mounted to the outside of my house about 15' above grade. Based on my research and from reading this forum as well as toying around with the small indoor antenna I am sure that I can get most of the Greenville stations with almost any roof mounted medium range antenna. However, I also want to get WLOS Ch 13 since they carry a lot of the football games.
With the little interior antenna that I have hung outside on the house I can receive the following broadcast signals (if the weather is perfect and tree foliage is not too thick):
4.1 (RF Ch 36) which is 41 miles at 17 degrees
7.1 (RF Ch 7) which is 53 miles at 35 degrees
21.1 (RF21) which is 45 miles at 10 degrees
62.1 (RF45) which is 49 miles at 18 degrees
I cannot get any signal from WLOS Channel 13, which is about 61 miles north (4 degrees) of me.
My question is this: What would you guys recommend in a VHF/UHF roof mount antenna that will collect the signals from Channel 13 as well as Channel 7 (and all of the UHF in between). The spread between 13 and 7 is about 30-35 degrees....according to AntennaWeb. From what I have read, the typical maximum spread that most antennas will pull in is about 20 degrees.
Will I have to have two VHF antennas, one directional pointed at Mt. Pisgah (Ch 13) and then another VHF/UHF antenna pointed toward the other stations? Or, is there a recommended antenna that should capture everything?
Of course the other considerations are the cost and the fact that I live in a fairly restrictive subdivision which would probably limit me to the height of my chimney, about 20-25 feet.
Thanks in advance for your help!!
Slowdog is offline
post #2 of 27 Old 07-15-2013, 03:41 PM
tylerSC's Avatar
Quoted: 814 Post(s)
Liked: 181
Winegard 7696 or 7698 are very good HiVHF/UHF combo antennas. Also Antennacraft HBU-33 or HBU-55 versions sold at RadioShack. And possibly add a Winegard 8700 preamp. But if 13 is too much in a different direction from the other channels, then you may want a separate HiVHF antenna such as Antennacraft YA 7-13. And there is a smaller version HBU-22 sold at RadioShack which may have enough gain for all channels if you want to give it a try. But still consider a low gain preamp.
tylerSC is online now
post #3 of 27 Old 07-15-2013, 05:18 PM - Thread Starter
Slowdog's Avatar
Thanks! I will look into those suggestions. I appreciate the help!
Slowdog is offline
post #4 of 27 Old 07-15-2013, 05:45 PM
gregzoll's Avatar
Liked: 33
In your position, 61 miles is alot for the fact that you have the hills and mountains. LOS across the flat plane on the globe is at most 75 miles with no hills or mountains. Unless you can get it at least 50 to 75 feet in the air, which really is not doable, you will never pick up that station 61 miles away, unless they get a repeater nearer to you.
gregzoll is offline
post #5 of 27 Old 07-15-2013, 05:55 PM
ybsane's Avatar
Quoted: 100 Post(s)
Liked: 35
WLOS is completely doable in the Ops location with a decent VHF- antenna, I have family in Fountain Inn and they have no problem with an antenna in their attic picking up this station.
All Comments made are my own and not of my employer.
ybsane is offline
post #6 of 27 Old 07-15-2013, 06:14 PM
tylerSC's Avatar
Quoted: 814 Post(s)
Liked: 181
I would say just go to RadioShack and get a HBU-22 and give it a try. You can always return it. It may be all you need. And you can try one of their preamps and see if that helps. Although the Winegard 8700 from Solid Signal is a better performer, and cheaper at $29. And you could try and see if RadioShack will price match Solid Signal on the antenna.
post #7 of 27 Old 07-15-2013, 06:18 PM
tylerSC's Avatar
Quoted: 814 Post(s)
Liked: 181
My cousin in Fountain Inn gets WLOS, as well as WBTV, WCNC, and WJZY from Charlotte. Plus WYFF and WSPA of course. And I use only rabbit ears and a preamp in the attic in Mauldin and have no problem with 13, 7, or 9(29). But 13 is weakest and more strategic placement is required.
post #8 of 27 Old 07-15-2013, 06:44 PM - Thread Starter
Slowdog's Avatar
Great information guys, thanks!! Buying at R.S. is also a good idea if they will allow me to return the antenna if it will not do the job....I love the prices of the smaller units the best... I have a lot of good information to look over.
Slowdog is offline
post #9 of 27 Old 07-16-2013, 05:54 PM - Thread Starter
Slowdog's Avatar
Another question: Which mast to use and which chimney bracket.....reviews all seem negative on the brackets I found.
Also, can the mast be attached to the top few feet of my chimney or should it go all the way to the ground (my chimney is on the outside wall of the house).
Another idea I have, is using my Direct TV dish mount which is attached to the north facing eave of the house, about 20-25 feet off of the ground and curves up above the roof (the dish is pointed south across the roof)....how large of an antenna would that mount typically hold (assuming I can figure a way to securely attach the antenna) Would the HBU-22 is about 5lbs and the HBU-33 is about 7lbs with a short mast be too heavy? Your opinions please....and THANKS!!!
Slowdog is offline
post #10 of 27 Old 07-16-2013, 06:46 PM
tylerSC's Avatar
Quoted: 814 Post(s)
Liked: 181
RadioShack and Lowes sell masts and brackets. Also Solid Signal and Channel Master store online. But you may be able to use DirecTV mast for the HBU-22 since it is not that big.
post #11 of 27 Old 07-18-2013, 08:54 AM - Thread Starter
Slowdog's Avatar
Thanks, but if I decide to strap an antenna to the chimney (my chimney is on an outside wall) should I buy enough mast to go all the way to the ground or can I merely strap the bottom 5' up onto the chimney? Also, what about grounding the mast....is that necessary?
One other question....do you have any opinion on the HD Stacker antenna from Denny's?? It cost three times that of the HBU 22 or about the same as the HBU-55....how would you compare them from what you know about them?
Slowdog
Slowdog is offline
post #12 of 27 Old 07-18-2013, 02:12 PM
tylerSC's Avatar
Quoted: 814 Post(s)
Liked: 181
Instead of HD Stacker, if you go with 2 separate antennas, I would get an Antennacraft Y5 7-13 for HiVHF, and an Antennas Direct 43XG for UHF. Or a Winegard 9022 or Antennacraft MXU-47. You don't really need a larger UHF antenna. Combine the antennas with a UHF/VHF signal joiner (UVSJ) from Radioshack. It will allow power pass for a preamp on the UHF side. A Winegard 269 or 8700 preamp should work fine.
post #13 of 27 Old 07-20-2013, 11:58 AM - Thread Starter
Slowdog's Avatar
Thanks, as soon as I can I am going to try a HBU 22 or 55 and then if that does not work I may try the two antenna method.... Based on what I have read and from the replies here on this forum, the 35 degree separation between Ch 7 and Ch 13 may require two antennas.
Slowdog is offline
post #14 of 27 Old 07-20-2013, 12:39 PM
gregzoll's Avatar
Liked: 33
Slow dog, going with two antennas is better, even though some like the DB4 & DB8 will pick up high VHF (7-13). Because of foliage on our trees between my house and the antenna 8 miles away, I have found the signal dropped 8 points from where it was, when I originally put it in my attic. Using that as an example that you need to recheck your signals after the trees start defoliating and adjust accordingly to raise the signal on that one tower you are using the one antenna to receive, just like I did with my setup.
All I am using is the AntennaDirect DB8 and the AntennaCraft Y5713, and Channel Master 7778. In your area, you may need the Antennacraft Y10713 for high VHF, and the Channel master 7777. If you can find a local antenna shop that could let you try different pre-amps, that would be better, or just order both from Amazon.com, then return the other that does not work for you. I have done that with stuff, when trying to find the right option, and it is easier to order a couple items for the same job, then send back what you are not going to use.
gregzoll is offline
post #15 of 27 Old 07-20-2013, 04:12 PM
tylerSC's Avatar
Quoted: 814 Post(s)
Liked: 181
I think try the HBU-22 first and see if it is adequate. Adjust the aim for best results. You may be able to find a sweet spot that will receive 13, as well as 7 and the other channels which should be stronger. As for the preamp, I think either a Winegard 8700 or Channel Master 7778 will be best, as the new CM-7777 is too strong at 30 db and may overload.
post #16 of 27 Old 07-20-2013, 11:57 PM
gregzoll's Avatar
Liked: 33
Tyler, the 7778 may not be overkill, due to the lay of the land that you happen to be in. You have to take into consideration of what is between you and the towers (ie hills, foliage, the fact that you are trying to pick up a station at the nexus of the max azimuth that any antenna will pick up, unless you can get it high enough (ie 75-125 feet in the air).
gregzoll is offline
post #17 of 27 Old 07-21-2013, 05:33 AM
ybsane's Avatar
Quoted: 100 Post(s)
Liked: 35
The lay of the land is not that bad, Charter only has their antennas at the 30-35' level for all their locals.
ybsane is offline
post #18 of 27 Old 07-22-2013, 02:28 PM - Thread Starter
Slowdog's Avatar
1) What is the best way to mount these antennas?? It will have to go on my chimney (outside wall) or a gable. I had considered using my Direct TV mast but the trees have grown up around it so badly that I will have to have a tree trimmed or removed to mount an antenna there.
2) Any suggestions on what brand of mounts or brackets and masts are the best?? I see a range of prices....
3) Also, how far down the chimney should the mast come and,
4) should the mast be grounded?
5) If I use 2 antennas:
A) How far apart on the mast should they be? and,
B) What type of a Combiner do I use when I join a VHF and a VHF/UHF antenna (since I will use a VHF for Ch 13 and a VHF/UHF for other channels)....I notice that the UVSJ combiner is for one VHF and one UHF antenna....
THANKS!!!!!
Slowdog is offline
post #19 of 27 Old 07-22-2013, 08:00 PM
gregzoll's Avatar
Liked: 33
If the Chimney is solid, get the straps and attach it to the Chimney with two straps. Make sure that you have the pole high enough by at least six feet min above it. If you go on the gable, you may want to extend the pole down at least four feet on the wall, to make it solid, so that you do not have the two mounts only a foot or two feet apart, but still extend the antenna at least six feet min. above the peak of the roof. You want it higher than the highest point on the roof, and higher than tree line if possible, which would involve a tower to do that.
Brackets and mounts you can get at Lowe's, Home Depot, Radio Shack, online through Amazon.com if you want. They are all pretty much made in the same country (China).
As for the Splitter/Combiner, it goes between the two antennas. Make sure that it has DC pass through capabilities. All I did was use a off the shelf Radio Shack UHF/VHF Splitter/Combiner for my setup in my attic. My mount is a roof mount, that is mounted to a 2x6 screwed to the joists up there.
gregzoll is offline
post #20 of 27 Old 10-12-2015, 08:15 AM - Thread Starter
Slowdog's Avatar
Well, forgive me guys...due to some health problems and other distractions I have never installed the outside antenna as I had planned....but now I wish to do so. However, all of the antennas recommended by TylerSC and Gregzoll are not longer on the market....so I must ask again....what antenna/antennas and preamp do you guys suggest for me...
Also...I have a little work shop that sits about 15 feet higher in ground elevation than my house does, however, it is about 100' away. The installation on the shop would be much easier but I am not sure how much gain I will lose running underground coax cable that far....do you have any advice on that? The roof ridge line of the shop is about 5' lower than the house ridge line....however, if I place an antenna on my roof or highest gable I will have to hire someone to do the install (due to the height and health reasons)....
What do you think of the Channel Master CM3020 for $99 on Amazon or at Home Depot??
Thanks for all of your help!!
Slowdog is offline
post #21 of 27 Old 10-12-2015, 01:57 PM
tylerSC's Avatar
Quoted: 814 Post(s)
Liked: 181
That Channel Master 3020 is a large all band antenna, which is unnecessary unless you want to receive FM radio. Otherwise, you do not need the large elements for Low VHF, as WSPA and WLOS are High VHF channels 7 and 13. You would ideally need a smaller High VHF/UHF combo antenna as previously mentioned.
However due to the Radioshack bankruptcy, the Antennacraft antennas are no longer manufactured. Unless you can find a Radioshack store with remaining inventory now on clearance, such as HBU-33 or HBU-55. Otherwise, Winegard versions would be the HD-7697 or 7698.
Another idea would be a Clearstream 4V sold at Best Buy for $149 or $169. A bit pricey, but a very good compact UHF loop antenna that adds a VHF dipole. Aim for WLOS or a sweet spot between all the stations. As for a preamp, the newer Winegard model is the LNA-200 sold at Home Depot for about $43. Moderate gain about 19db, but that is all you should need. And the RCA preamp from Walmart online is also a good inexpensive preamp.
If a bit more gain is needed for WLOS, then consider MCM Electronics High VHF antenna for channels 7-13 from Stellar Labs. Combine with their UHF/VHF signal joiner to the Clearstream 4V, or select a cheaper MCM UHF antenna, such as their 8 bay or triple boom yagi. They also have a triple boom UHF yagi style which adds VHF dipoles as a combo antenna.
Several options to consider, and if price is a factor, MCM is the cheapest, and use the promo source codes on the home page. But Best Buy and Home Depot may be more convenient and easier to return.
ybsane likes this.
post #22 of 27 Old 10-30-2015, 03:40 PM - Thread Starter
Slowdog's Avatar
Hey TylerSC, sorry for the long delay, I appreciate your reply!! I do in fact need an antenna for FM signals, I can barely receive any of the FM Greenville stations on my Receiver....therefore would the Channel Master 3020 kill all of my birds with the one stone? Or is there a better deal on an all band antenna? As you suggest, I am looking at the products that MCM sells....
What about my question related to any downside to running a cable 100-150' from my little shop on the hill behind my house to my house....I mention that in my previous query....
Also, our Radio Shacks in the area are sold out of remaining stock when it comes to the mast or poles. Neither Lowes or HD stock any TV mast (at least that is what I was told) Both the prices and the shipping for online purchase of the poles is outrageous. Are you aware of any local stores that sell the 10' mast? What about using chain link fence top poles?
Thanks again for everyone's help and suggestions!
Slowdog is offline
post #23 of 27 Old 10-30-2015, 05:16 PM
ProjectSHO89's Avatar
Quoted: 282 Post(s)
Liked: 130
Chain link fence top poles make excellent masts as does 1" or 1 1/4" electrical conduit. All are around $10 a stick at your local Home Depot.
ProjectSHO89 is offline
post #24 of 27 Old 10-30-2015, 07:05 PM - Thread Starter
Slowdog's Avatar
Thanks, I will check it out!
Slowdog is offline
post #25 of 27 Old 10-31-2015, 12:29 PM - Thread Starter
Slowdog's Avatar
TylerSC and others....Help me understand.
I am confused again... Greenville Channel 7.1 broadcast on high VHF, correct? Does Channel 4.1 broadcast on Low VHF requiring an antenna that covers that? Or does 4.1 broadcast UHF on 36? I am in Anderson....do I need an antenna that covers the low VHF? Thanks!
Slowdog is offline
post #26 of 27 Old 10-31-2015, 03:44 PM
tylerSC's Avatar
Quoted: 814 Post(s)
Liked: 181
WYFF moved from VHF channel 4 analog to UHF channel 36 for digital. So you need a UHF antenna for WYFF and a High VHF antenna for WSPA which stayed on channel 7. You do not need an all band antenna such as the CM-3020 unless you want FM radio.
post #27 of 27 Old 10-31-2015, 07:05 PM - Thread Starter
Slowdog's Avatar
That is what I needed to know! Thanks again!!
Slowdog is offline
