Is 27.2 the same as 27-2? And can't get this channel even after rescan. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-23-2013, 05:35 PM - Thread Starter
jaaade's Avatar
hi. i am a renter in someone's home. i get free basic cable from time warner. no box. i re-scanned my system and the movie channel is still not there. what am i missing? what should i do?
and like the title of this post says, is 27.2 the same as 27-2? when i manually enter 27-2 it doesn;t respond. tv goes back to previous channel. like the channel is not there. i don't have a . option on my remote so hoping 27-2 is the same thing smile.gif
i live in downtown dallas area.
any help is appreciated.
thank you
jaaade is offline
post #2 of 6 Old 07-24-2013, 09:40 AM
Mister B's Avatar
Quoted: 17 Post(s)
If you are using the cable company clear QAM for the local channels they most likely do not provide all of the sub-channels. There is also no guarantee they are listed with the same numerals as when received over the air. I assume you are familiar with the Movie channel in question due to the use of an antenna at your previous residence. Yes, some remotes have a dash and others a dot, they are both used to access sub-channels.
Mister B is offline
post #3 of 6 Old 07-25-2013, 08:31 PM - Thread Starter
jaaade's Avatar
Thank you for the response. I'm not at all familiar with the movie channel.
So you suggested I clear QAM. I don't kno how to do that. I looked around to see if there's something similar I don't see it.
Were you also saying that some people may not receive it at all or might be a different channel? Sorry not sure if im understanding. I still don't know how to get the channel.
Thanks again for your help
jaaade is offline
post #4 of 6 Old 07-26-2013, 10:24 AM
Mister B's Avatar
Quoted: 17 Post(s)
QAM is a method the cable company uses to send digital signals through their lines. When it is in the "clear" that means no cable box is required to decode the signal and one may tune the channel on any digital TV equipped with the proper type of tuner. That is how you are able to receive the local basic channels without a box. Sorry, I was not suggesting that you "clear" a setting in your menus.
Channel 27-2 is a digital subchannel that KDFI broadcasts in addition to their primary programming. The network that they put on 27-2 is a relatively new service called "Movies!" Reception of 27-2 would be available to anyone who can receive the primary KDFI signal with an antenna. You are not using an antenna, you are getting your signal from the cable company. The cable company may not carry the channel in question. They may carry it "in the clear" but it has been assigned a different number. I assume you have looked through all of the channels that you can get to see if any may be "Movies!" Finally, the cable company may carry this channel but you would have to pay them to use a cable box to receive it.
Mister B is offline
post #5 of 6 Old 07-27-2013, 12:53 AM
kevin120's Avatar
Quoted: 31 Post(s)
Liked: 36
thank you
No I am in the North Texas area as well with Time Warner Cable (Arlington area) and 27.2 is KSTR HD on TWC as 27.2 on cable does translate into 27.2 OTA. TWC does not carry Movies! and I don't expect them to as they don't have Bounce TV which KDFI has had for a while now. 27.1 KDFI HD is carried but it is on 28.1 physical channel (28) but digitized if you manually tuned to it. I think TWC should have mapped 27.1 KDFI HD to 27.1 physical channel (27) make it easier on the TVs to get the channel name.
here is the TWC digital QAM listings for Dallas:
Type Channel Virtual Name Resolution Aspect
qam256 15-1 16 GOAC015 544x480i
4:3
qam256 15-2 81 GOAC015 544x480i
4:3
qam256 15-3 96 GOAC096 544x480i
4:3
qam256 15-4 97 EDAC097 544x480i
4:3
qam256 15-5 98 EDAC098 544x480i
4:3
qam256 15-6 99 EDAC099 544x480i
4:3
qam256 15-7 491 EDACC4 544x480i
4:3
qam256 15-8 492 EDACC5 544x480i
4:3
qam256 15-9 493 EDACC6 544x480i
4:3
qam256 15-10 494 HLPRKED 352x480i
4:3
qam256 15-12 999 na1 352x480i
4:3
qam256 15-13 1000 na1 352x480i
4:3
qam256 15-101 16 GOAC016 544x480i
4:3
qam256 15-102 95 PUAC095 544x480i
4:3
qam256 18-1 11.1 KTVTDT 1920x1080i
16:9
qam256 18-3 21.1 KTXA 1920x1080i
16:9
qam256 19-1 39.1 KXTX 1920x1080i
16:9
qam256 19-2 55.1 KAZDDT 1280x720p
16:9
qam256 19-3 47.1 KTXDDT 1920x1080i
16:9
qam256 25-1 381 KERADT 1920x1080i
16:9
qam256 25-2 369 WFAA-DT 1920x1080i
16:9
qam256 25-3 371 WFAADT2 704x480p
16:9
qam256 25-4 372 WFAADT3 704x480i
16:9
qam256 25-5 383 KERADT2 704x480i
4:3
qam256 27-1 23.1 KUVN-DT 1920x1080i
16:9
qam256 27-2 49.1 KSTRDT 1920x1080i
16:9
qam256 27-3 52.1 KFWD 1920x1080i
16:9
qam256 28-1 33.1 KDAF 1920x1080i
16:9
qam256 28-2 27.1 KDFI DT
qam256 28-3 68.1 KPXDDT 1280x720p
16:9
qam256 28-4 33.2 KDAFDT2 720x480i
4:3
qam256 81-1 15 LEAC015 544x480i
4:3
qam256 81-2 25 WGN Amer 704x480i
4:3
qam256 81-3 28 CSPAN-2 704x480i
4:3
qam256 81-8 22 QVC 704x480i
4:3
qam256 81-9 2 CSPAN 704x480i
4:3
qam256 92-2 twc1 528x480i
4:3
qam256 92-3 twc1 528x480i
4:3
qam256 92-4 twc1 528x480i
4:3
qam256 92-5 twc1 528x480i
4:3
qam256 94-1 twc4 528x480i
4:3
qam256 94-2 twc5 544x480i
4:3
qam256 94-3 twc6 352x480i
4:3
qam256 98-1 4.1 KDFWDT (KDFWDT-DT)-Fox Affiliate 1280x720p
16:9
qam256 98-2 5.1 KXASDT 1920x1080i
16:9
qam256 98-4 5.2 KXASDT2 704x480i
16:9
qam256 101-1 4 1011 544x480i
4:3
qam256 101-2 5 1012 544x480i
704x480i
4:3
qam256 101-3 7 KDFI 544x480i
4:3
qam256 101-4 8 WFAA 544x480i
704x480i
4:3
qam256 101-5 9 1015 544x480i
704x480i
4:3
qam256 101-6 10 KXTXDT 544x480i
4:3
qam256 101-7 11 KTVT 544x480i
4:3
qam256 101-8 12 KAZD 544x480i
4:3
qam256 101-9 13 KERA 544x480i
4:3
qam256 101-10 6 CSPAN-3 704x480i
4:3
qam256 102-2 14 KFWD 544x480i
704x480i
4:3
qam256 102-3 17 KDTX 704x480i
4:3
qam256 102-4 21 KAZDDT 544x480i
4:3
qam256 102-5 20 KSTR 544x480i
4:3
qam256 102-7 23 KUVN 544x480i
4:3
qam256 102-8 24 KTXD 544x480i
4:3
qam256 102-9 26 KPXD 544x480i
4:3
qam256 102-10 29 KMPX 720x480i
4:3
qam256 102-11 18 EWTN 720x480i
4:3
qam256 102-13 350 spanish6 528x480i
4:3
kevin120 is offline
post #6 of 6 Old 07-27-2013, 10:55 AM
Mister B's Avatar
Quoted: 17 Post(s)
I am glad a member who is actually in the area contributed this useful information. I think the bottom line is that when one connects a TV directly to the cable outlet with no box, they are lucky to get anything and have to figure out on their own what channels are available and the numerical assignment. Although I am a diehard antenna user, I had to figure out "clear QAM cable" when my Mother was in a nursing home and make a chart for her. Many members of this forum believe this will not be a problem for long, as soon cable boxes will be required in all circumstances.
Mister B is offline
