dayton ohio stations. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-11-2013, 04:34 PM - Thread Starter
1am14fan's Avatar
i jason new here. anyway i am runnning an antennas direct outdoor antenna with a signal booster. my question i can almost get channel 30 here in dayton. its a country music channel not sure where the channel is from but what else do i need to get this channel. this is my 3rd year as a proud cord cutter.
1am14fan is offline
post #2 of 2 Old 09-02-2013, 07:07 AM
Nitewatchman's Avatar
Quoted: 33 Post(s)
Liked: 25
Hi Jason.
1st off, from now on, best to use the existing Dayton thread in this forum which is here :
http://www.avsforum.com/t/136336/dayton-lima-oh-hdtv
Normally, it's unlikely anyone in Dayton area would have seen your post, as we all use that thread instead, but I happened across it via an unrelated google search(although almost a month late), which explains why its been so long before you received a reply ...
Anyway -- I believe you are refering to TNN on WWRD-LP dayton, which is on channel 32, not 30, and is currently a ANALOG only station, so you'll need to use a analog tuner for that one, and make sure your antenna is aimed towards Bellbrook area ..
They are a low power station and have a smaller coverage area than the Dayton full power stations, so whether you can get it or not depends upon your location ...
Check your tvfool.com analog station plot for more details ....
Jeff
Nitewatchman is offline
