Antenna Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-12-2013, 09:44 PM - Thread Starter
Vulcan of Love's Avatar
Hi. I have been building antennas for the past few months and after getting lower results than I had hoped for (although I know a DB4 made out of coathangers, spare wood, and a recycled balun isn't the best antenna), I have decided to give manufactured antennas for a spin. I'd prefer to mount it at around 12' AGL, as there is a false front on my building perfect for a J-mount, but as there are 20' trees directly to the east, I would go a maximum of 30'. Also, please, if you have a favorite amp/preamp or rotor, please tell me a bit about it.
I'm really gunning for the top ten on the list, but I am a channel surfer, so any extra ones are welcome.
Note: I have been able to constantly get KVRR, with spotty reception of K49FA-D. I did a scan out of boredom one day and oddly enough got KFTC out of Bemidji. Lost after a half hour, though.
Vulcan of Love is offline
post #2 of 8 Old 09-13-2013, 12:39 AM
pamajestic's Avatar
That is a horrible TV fool report. Realistically the top two channels are the best you could hope for even with the best equipment. You would be better off the consider satellite TV.
pamajestic is offline
post #3 of 8 Old 09-13-2013, 05:37 AM
George Molnar's Avatar
What antenna height did you enter for your exact address when you ran this report?
George Molnar is offline
post #4 of 8 Old 09-13-2013, 06:34 AM - Thread Starter
I didn't, and yes, that report does suck. I had talked to a friend who lives just up the road who said he got a solid 5 channels with his attic-mounted DB4. I don't know if he was talking about stations or the 4 subchannels on K49FA-D.
post #5 of 8 Old 09-13-2013, 06:39 AM
Trip in VA's Avatar
Quoted: 554 Post(s)
Liked: 147
Send a message via AIM to Trip in VA
KVRR (Fox) and K49FA-D (PBS) are likely relatively easy catches. I would hope a dedicated high-VHF antenna (like the Y10-7-13) aimed east would get KCCW (CBS). That leaves ABC and NBC, which are significantly harder catches for you.
I'd be curious to see your TVFool report at 30 feet AGL.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #6 of 8 Old 09-13-2013, 07:09 AM - Thread Starter
I will get you a map at 30'AGL when I get to a PC. Right now my phone locking up when I try to upload a photo and it won't let me copy the link. Oy.
post #7 of 8 Old 09-13-2013, 10:39 AM - Thread Starter
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d46aea2c04a06eb
My location at 30' AGL. Interestingly enough, WDAY-DT moves up in the list.
post #8 of 8 Old 09-13-2013, 09:10 PM - Thread Starter
I was thinking of getting this antenna:
http://www.amazon.com/gp/aw/d/B00CX6UJ5K/ref=mp_s_a_1_3?qid=1379127157&sr=8-3&pi=AC_SX110_SY165
mounted at around 15' AGL with a rotor and my existing Magnavox(?) 12dB indoor amplifier. Yes? No?
