uhf antennae - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-16-2013, 02:25 PM - Thread Starter
yoiyoi's Avatar
could someone recommend a good moderately priced outdoor uhf antennae . i previously used a db2 model which is no longer available.
i saw this on the web http://www.solidsignal.com/pview.asp?p=hdb2x&d=solid-signal-xtreme-signal-hdb4x-high-definition-blade-4-bay-xtreme-antenna-%28hdb4x%29&sku=700112818400.
could anyone recommend one within that price range and pulls in a good reception.
thanks for suggestions and recommentdations
yoiyoi is offline
post #2 of 7 Old 09-16-2013, 02:48 PM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
For moderate pricing, I would select whichever Solid Signal model most suits your needs. Or you could consider MCM/Stellar Labs.
tylerSC is offline
post #3 of 7 Old 09-16-2013, 05:59 PM
ADTech's Avatar
Quoted: 121 Post(s)
Liked: 65
We still have over a hundred "A" stock DB2s left in stock. You'll have to call in to order as they're off the web store.
We also have over a hundred refurbished "B" stock DB2s on hand. They are on our website under the refurbished and clearance section.
Tech support for Antennas Direct
ADTech is offline
post #4 of 7 Old 09-17-2013, 08:13 PM - Thread Starter
yoiyoi's Avatar
In what conditions are the refurbished? are they used and returned items? how much do the new ones cost?
yoiyoi is offline
post #5 of 7 Old 09-21-2013, 08:58 PM - Thread Starter
yoiyoi's Avatar
Could anyone provided some guidance as to which of these two antenna will give a better reception as an outdoor antennae. An objective evaluation will be most appreciated.
thanks
1.Solid Signal Xtreme Signal HDB2X High Definition Blade 2 Bay Xtreme VHF/UHF Antenna (HDB2X)
or
2. Antennas Direct DB2 UHF HDTV Antenna (DB2
yoiyoi is offline
post #6 of 7 Old 09-22-2013, 05:39 AM
ProjectSHO89's Avatar
Quoted: 206 Post(s)
Liked: 109
They're pretty much the same, older-design 14-69 antennas. You probably won't notice any difference unless it breaks. They you'll find one has a lifetime warranty, and the other has a very short warranty and you own a broken antenna.
Of course, there is a new version from Antennas Direct, the DB2e, that has been upgraded to the new UHF channel band and performs very well. Solid Signal, on the other hand, chose to put their name on some white box Chinese generic UHF antenna
ProjectSHO89 is online now
post #7 of 7 Old 09-22-2013, 03:44 PM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
The DB2e would probably be the best performer, as it has a larger reflector and more fined tune elements for today's UHF channels. Although the other 2 should work basically fine as well. The Eagle Aspen version of the DB2 on Amazon is probably the cheapest, but if you want the best choose the DB2e.
tylerSC is offline
