Email just in from WESH - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-13-2014, 05:07 PM - Thread Starter
barry32976's Avatar
Darragh, Brian H Hello Barry, I can assure you the decisions on what channel WESH programming is broadcast on is made at the highest levels of our organization. We are aware of the limitations of the VHF channel assig
To Me
Today at 6:31 PM
Hello Barry,
I can assure you the decisions on what channel WESH programming is broadcast on is made at the highest levels of our organization. We are aware of the limitations of the VHF channel assignments. Unfortunately, the new digital systems were already in place.
With the current efforts underway to repack the digital channels (National Broadband Plan), it is possible other broadcasters will be forced to return to the VHF band.
This uncertainty makes our group unlikely to spend millions of dollars on tower space, transmitters, lines and antennas to move channels.
We have had success with the Winegard GS-2200 sensar lll
Thank You,
Brian Darragh
-----Original Message-----
Sent: Sunday, January 12, 2014 9:45 AM
To: Darragh, Brian H
Subject: WESH.com Feedback Form
Importance: High
PAGE 1 QUESTIONS:
1. Department:
Engineering Department
2. Your Message:
The fact that the station is on VHF-HI (11) is a handicap to your market. I get all of the stations major networks out of the Orlando market, but WESH's signal is the only unreliable signal. I sell and install  lightweight amplified antennas in the area and the common complaint is the WESH signal. VHF signals require a much larger antenna that would also necessitate a heavier duty mounting installation. All this adds up to throwing a lot of money just to try to get that one station. There are many similar antennas to the one I sell, and they are nearly identical as far as reception goes. I do have many happy people using my antennas. I don't know if WESH can up their power, add a UHF translator towards the south, or completely changeover to UHF. My antenna in Micco, is only 15 ft off of the ground and I regularly scan from 57 to 62 channel/sub-channels in the Orlando direction only. VHF is at a disadvantage in comparison to UHF. I sent this to the engineering dept, but was not sure "to whom it may concern". Perhaps everyone. Thanks.
3. Your Email Address:
miccofl@yahoo.com
4. Your Name
Barry Lostetter
barry32976 is offline
post #2 of 2 Old 01-13-2014, 07:04 PM
tylerSC's Avatar
Quoted: 722 Post(s)
Liked: 166
Perhaps WESH could increase power to overcome reception problems. VHF can be more subject to noise and interference. In some areas, HiVHF reception has improved when the stations were indeed allowed to increase the power level. WXIA RF10 in Atlanta has a very strong signal. And WJLA-7 and WUSA-9 improved their reception in DC, VA, and MD after they increased power. And some stations use a circular polarization antenna rather than horizontal, which can be a factor. But, as you say, many of those small, amplified consumer antennas are indeed quite poor for VHF. Perhaps consider a better antenna, such as Clearstream 5, Clearstream 2V, or one of the Digitenna models. Or an Antennacraft HBU-22 or 33, or a Winegard 7694, 7696. You have to be sure you have a decent antenna that is designed to receive VHF. And an appropriate preamp if needed. Selecting a poor antenna is a big part of the problem.
tylerSC is offline
