Yadkinville NC, can't get FOX WGHP. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-18-2014, 05:18 PM - Thread Starter
poolboyclay's Avatar
I can get everything else pointing in that direction. Can someone point me to the correct info? I have viewed TVfool data. https://www.tvfool.com/index.php?option=com_wrapper&Itemid=90
If I read it correctly. I should be able to see this station.
Antenna is a clear-stream 4 pointed at that tower.
With that wattage, the voice coil is now a Rail Gun. You get 1 note, but it will be memorable! - JEFFakaMAX
poolboyclay is offline
post #2 of 2 Old 01-18-2014, 06:47 PM
tylerSC's Avatar
Quoted: 814 Post(s)
Liked: 181
You may try posting in the Greensboro thread. Your exact TVFool report did not come up. Please post again. Also, have you tried for FOX-46 or any of the Charlotte channels? You may have better luck with a 91XG or an Antennacraft MXU-59, and a preamp such as Winegard LNA-200.
tylerSC is offline
