STD, HRC, and IRC in Samsung HDTV options. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-19-2014, 03:04 PM - Thread Starter
phildaant's Avatar
Quoted: 526 Post(s)
Liked: 170
Any preferred option to use for TWC with its coax cable connected directly to a Samsung HDTV (QAM tuner?)? Thank you in advance. smile.gif
phildaant is offline
post #2 of 4 Old 01-19-2014, 09:34 PM
domino92024's Avatar
Quoted: 100 Post(s)
Liked: 191
?? What kind of option ya lookin' fer? Ich verstehe nicht.
domino92024 is offline
post #3 of 4 Old 01-19-2014, 10:41 PM
veedon's Avatar
Quoted: 382 Post(s)
Liked: 140
I would first try running the channel scan using the standard (STD) setting for the cable system, and then try HRC or IRC only if STD does not give good results. I think most cable systems use STD.
veedon is offline
post #4 of 4 Old 01-20-2014, 12:44 AM - Thread Starter
phildaant's Avatar
Quoted: 526 Post(s)
Liked: 170
Thanks. It seems like I got almost scanned for IRC and STD (makes no differences?) with combined digital and analog. HRC got about eight/8. :O
