OTA antenna question. - AVS | Home Theater Discussions And Reviews
Old 04-14-2014, 07:52 AM - Thread Starter
SleepyEyez's Avatar
Can I connect the antenna to main coaxial cable that is distributed throughout my home? It will be running on 2 tv with built in tv tuner so I assume I need an amplifier, am I correct? If I have cable modem connected the same coaxial cable will there be interference?
What are your suggestion?
SleepyEyez is offline
Old 04-17-2014, 09:50 AM
PoliPino's Avatar
From what I've gathered from researching this myself, cable (including internet signal) operates at the same frequencies as OTA signals. So you cannot send cable modem and OTA through a single coax through the home.
Your best bet would be to run a second coax line dedicated to the Modem.
As for an amplifier, that really depends on the strength of the OTA signals where you live. Splitting the signal to 2 TVs will drop the signal strength to each, but it may well still be strong enough without an amp. In the end, try and see if it works.
PoliPino is offline
Old 04-18-2014, 06:17 PM - Thread Starter
SleepyEyez's Avatar
Thank you.. that helps.
Sent from my SGH-I747M using Tapatalk
Old 05-30-2014, 09:20 AM - Thread Starter
SleepyEyez's Avatar
Another question.
I have 2 LG tv one is getting 24 channels and the other is getting 14 channels with no splitter.
