Need help with OTA in Spring City, TN - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-12-2014, 08:34 AM - Thread Starter
glbtrekker's Avatar
As the title suggests, I am trying to convert from Dish network to OTA programming, but since I haven't dealt with antennas in many years and I am a long distance away from the local broadcasters (45-55 miles), I really don't know where to start. I have looked at the recommendations of TV Fool, and am hoping that someone here might be able to point me in the right direction. If possible, I would like to simply adapt the dish satellite mast and attach a roof-top antenna directly to it. Currently, it is located about 12 feet off the ground. What do you think? Follow the link below for the specifics provided by TV Fool.
[URL=http:// http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3de1c60020d442d6]TV Fool Analysis Report[/URL]
glbtrekker is offline
post #2 of 4 Old 05-12-2014, 11:14 AM
McTNN's Avatar
Mounting the antenna/amp is simple enough and odds are you will pick up something not found on Dish. It might be worth doing if for no other reason than to scratch the itch and see what is out there. Depends on one's expectations and what you would consider successful.
McTNN is offline
post #3 of 4 Old 05-12-2014, 11:51 AM
tylerSC's Avatar
Quoted: 746 Post(s)
Liked: 171
Most major channels seem to be HiVHF and UHF. So I would suggest an Antennacraft HBU-33 or Winegard 7696 antenna. And a Winegard LNA-200 preamp or the cheaper RCA preamp. There is a RF3 channel, but doesn't appear to be a major network.
tylerSC is online now
post #4 of 4 Old 05-12-2014, 12:06 PM - Thread Starter
glbtrekker's Avatar
Thanks! I actually ended up ordering the Winegard HD 7698P as the recommended antenna from one of the online vendors. Now, well see how high I need to mount it smile.gif.
