Dose Anyone Know The Best OTA for Peoria AZ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-12-2014, 10:07 AM - Thread Starter
wrightejw's Avatar
Hi all i just cut the cord from Dish Network and loving it, I have a 70" Sharp LED Aquos using Roku 3 to get Netflix, Amazon Prime, Hulu Plus and Plex. I have a small Indoor Out door HD Antenna for locals which i have mounted out side on the roof and it pulls in all the stations but FOX 10, can someone in the Peoria area give me some info and a good Antenna? i would prefer a indoor modal but any info would be help full.
wrightejw is offline
post #2 of 4 Old 05-12-2014, 02:39 PM
Charles O's Avatar
Quoted: 60 Post(s)
Liked: 66
I live by the 101 and Olive and get FOX10 fine using a Mohu Leaf indoor antenna...the only stations that are iffy are the low power ones such as KAZT and KFPH.
If you can use a outdoor antenna, you should get all the stations off of South Mountain...a good one is the RCA ANT751. Fry's Electronics has it for $45 and has the Mohu Leaf for $20.
Charles O is offline
post #3 of 4 Old 05-13-2014, 04:20 AM
ProjectSHO89's Avatar
Quoted: 279 Post(s)
Liked: 129
A small combo antenna like the ClearStream 2V, RCA 751R, CM2016, or the HBU11 would al work well in your area.
What is your existing antenna?
ProjectSHO89 is offline
post #4 of 4 Old 05-15-2014, 10:36 AM - Thread Starter
wrightejw's Avatar
I live at 99th and Beardsley and the I got the antenna from Monoprice it's a powered antenna and it's pulls in all the station very except Fox it very spotty. I heard some good things about the ClearStream I think i'll try it
