What type of HDMI cable to install in walls / ceiling - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-12-2014, 01:11 PM - Thread Starter
mpvosseller's Avatar
I'm having an electrician install a 40' HDMI cable in my walls (to run from TV to closet in back of the room).
It will run through a few walls and along the ceiling of an unfinished basement and garage.
The Monoprice "40ft Ultra Slim Series High Performance HDMI® Cable w/ RedMere® Technology" seems good (latest tech, cheap-ish, thin / easy to turn corners).
But Is RedMere more likely to fail than other cables?
Some other cables advertise as being good for "in-wall"?
Anything else I should be thinking about?
mpvosseller is offline
post #2 of 4 Old 05-12-2014, 01:42 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
First of all I would install your cable, whatever you choose, in a 1" conduit. It makes repairing/replacing cable so much easier. Add a pull-string or two for future cable pulls as well.
Keep the bends in the cable to an absolute minimum. No 90 degree bends if possible.
A Redmere cable would certainly work well but, they do have a chipset in one end, so like any other electronic device, they can fail. If you've installed the cable in a big enough conduit without sharp bends, you could replace the cable if it fails without too much difficulty. I would consider solid core CAT-6 and then terminate with HDBase-T. Probably a little more expensive but it would work, be easy to repair/add, and basically it would "future-proof" your setup to quite some time.
Otto Pylot is offline
post #3 of 4 Old 05-12-2014, 07:18 PM - Thread Starter
Great idea! Hadn't thought of HDMI over ethernet.
So I assume all I need is a 40' CAT-6 cable and something like these wallplates:
http://www.monoprice.com/Product?c_id=109&cp_id=10914&cs_id=1091401&p_id=10224&seq=1&format=2
Would you bother with a 1" conduit and pull-string for a cat-6 cable?
post #4 of 4 Old 05-12-2014, 07:29 PM - Thread Starter
Great idea! I hadn't thought of HDMI over ethernet.
So I guess I just need 1 40' CAT-6 and something like Monoprice Product ID: 10224 "HDBaseT Wall Plate Extender Kit"?
Would use bother with the 1" conduit and pull strings for a CAT-6 cable?
