best bet for rooftop antenna in the middle of nowhere? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 05-14-2014, 05:22 PM - Thread Starter
pbeary's Avatar
Hi- obviously, this has been covered here a million times, but I'm hoping I can get some good recommendations for the best antenna setup in my area. We do ota tv only, and since the switch to digital, we've been having trouble locating some channels. PBS comes and goes, and we haven't seen NBC in a few years, other than the odd day or two it appears before going away again. Thanks for any input- my tvfool info is as follows:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3de1c60ad0e8d514
pbeary is offline
post #2 of 16 Old 05-15-2014, 04:15 AM
Trip in VA's Avatar
Quoted: 547 Post(s)
Liked: 145
Send a message via AIM to Trip in VA
NBC is on channel 6, which will require a low-VHF antenna, and PBS is on 42 or 43, depending which one is stronger, and requires a UHF antenna. What antenna are you using now? That would be a helpful starting point.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #3 of 16 Old 05-15-2014, 07:22 AM
Mister B's Avatar
Quoted: 17 Post(s)
Also, go to Trip's web site to help you figure out which Phoenix stations are on which of your area translators. Just click on the blue "rabbitears" under Trip's post. This should help you determine which translator site you are receiving and even if your chances would be better aiming at another one.
Mister B is offline
post #4 of 16 Old 05-15-2014, 09:21 AM - Thread Starter
pbeary's Avatar
Thanks, but NBC is on 2.1 or 12.1 here, and the PBS stations are 8.1 to 8.3. I'm in Prescott, AZ - about 100 miles from Phoenix. Currently, we have a Radio Shack aerial around 8 feet long. I don't recall the model number, as I bought it ten years ago before we moved here.
pbeary is offline
post #5 of 16 Old 05-15-2014, 09:43 AM
Trip in VA's Avatar
Quoted: 547 Post(s)
Liked: 145
Yes, I know where you are, based on your TVFool analysis. K06AE-D appears on your TV as channel 2-1, and thus you will require a low-VHF antenna.
If you do not know your model number, could you post a picture of it?
- Trip
N4MJC
RabbitEars
post #6 of 16 Old 05-15-2014, 10:11 AM - Thread Starter
pbeary's Avatar
Hope this helps- it sits about 25' off the ground right now. Has no preamp, coax runs to two tvs, i believe about 35' to the splitter, then 25' to one tv, maybe almost 40' to the other.
pbeary is offline
post #7 of 16 Old 05-15-2014, 10:36 AM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
That pic is a medium range UHF/VHF all band combo antenna, made by Antennacraft for RadioShack. Since you seem to have channels on both Low VHF and High VHF, as well as UHF, then that is the appropriate type of antenna. You should investigate as to whether most of those low power translator signals will provide the major networks, as your full power stations appear to be extreme fringe. A larger version of your current antenna would be the Antennacraft C490 now sold at Radioshack. Or a Winegard 8200. But it may be all you need is a good low noise preamp. Such as Winegard LNA-200, Channel Master 7778, or the RCA version. But for problematic fringe signals, a Kitztech preamp may be a better choice. And best fringe antennas are the Antennas Direct 91XG for UHF, and the Winegard 8200 or 7698 for UHF/VHF. Depending upon what may be needed. But I would determine if the nearby translator signals will provide all the major channels you desire.
tylerSC is offline
post #8 of 16 Old 05-15-2014, 10:59 AM
Trip in VA's Avatar
Quoted: 547 Post(s)
Liked: 145
I'll save you the work Tyler asked you to do. Here are the translators and what they carry.
Mingus Mountain
6 (2-1 NBC)
7 (7-1 IND)
16 (45-1 MY)
34 (61-1 CW)
36 (10-1 FOX)
38 (3-1 IND)
40 (5-1 CBS)
42 (8-1 PBS)
44 (15-1 ABC)
Mount Francis
11 (3-1 IND)
30 (5-1 CBS)
32 (32-1 3ABN)
39 (10-1 FOX)
43 (8-1 PBS)
47 (15-1 ABC)
Badger Mountain
14 (45-1 MY) - Currently analog
Is your current antenna aimed at 70 degrees (toward Mingus Mountain)? I concur that it looks like it should get you decent (though perhaps not ideal) results. If it is appropriately aimed, an amplifier may be helpful to you, as recommended.
- Trip
N4MJC
RabbitEars
post #9 of 16 Old 05-15-2014, 06:44 PM - Thread Starter
pbeary's Avatar
Thanks all- I'll try moving the antenna to that orientation. I haven't touched it since we moved in 8 yrs ago, and it looks like things have changed.
pbeary is offline
post #10 of 16 Old 05-15-2014, 07:02 PM
Trip in VA's Avatar
Quoted: 547 Post(s)
Liked: 145
Let us know how it goes.
- Trip
N4MJC
RabbitEars
post #11 of 16 Old 05-16-2014, 11:14 AM - Thread Starter
pbeary's Avatar
Experimented with pointing the antenna yesterday, starting at roughly 70 degrees, scanning five times, moving a degree or so each time. I found just about everything, except no sign of PBS. ABC was just on the verge of breaking up, so I imagine a preamp could help that. The PBS stations here have been coming and going for about a month, so I'm not sure if the problem is on my end. My son's grown up watching PBS programming for the last five years- its loss is what's motivating my attention to this now. I repointed it to the orientation it was originally so we could record our usual shows. Once I get the preamp, I'll try again.
pbeary is offline
post #12 of 16 Old 05-21-2014, 07:43 PM
Trip in VA's Avatar
Quoted: 547 Post(s)
Liked: 145
Sorry for letting your post linger. I'm surprised PBS is giving you such trouble, since there should be one or more sources for it nearby. Definitely let us know how the pre-amp goes.
- Trip
N4MJC
RabbitEars
post #13 of 16 Old 05-21-2014, 08:50 PM
veedon's Avatar
Quoted: 759 Post(s)
Liked: 465
From looking at your TVFool report and checking rabbitears.info to learn what stations are carried by the translators, it appears to me that you might have some co-channel interference causing problems in receiving the PBS transmissions.
K42AC-D at 70 degrees appears to be your best bet for getting PBS ("Arizona PBS Eight"), but there is a chance that the weaker signal from the more distant K42IQ-D ( a religious station, GCN) could be interfering with that.
On RF 43, I would expect your antenna to pick up K43IE-D (KSAZ FOX 10) rather than the weaker signal from PBS translator K43LW-D.
There is a web site that lists all of the PBS translators:
http://www.azpbs.org/reception.php
veedon is offline
post #14 of 16 Old 05-21-2014, 09:14 PM - Thread Starter
pbeary's Avatar
Thanks- I have a preamp on order. That interference wouldn't surprise me. There are religious radio stations around here that bleed all over the dial. The PBS issue is interesting- we didn't get it at all for years, then it appeared and was fine until about a month ago, when it started going in and out at random instead of just with storm activity. We're far enough from civilization that a mild thunderstorm can kill a translator for two days. It's common enough that we just expect it to happen. Once the preamp arrives, I'll set it up and see what I can find.
pbeary is offline
post #15 of 16 Old 04-01-2016, 04:51 PM
vysean's Avatar
pbeary - Did you ever find success?
If anyone else would be willing to respond - I live in the same town as pbeary (but that may not mean much, given the varied topography), and am having a similar problem - I can receive all channels now except for 2.1 (VHF 6 - NBC affiliate). I have tried an RCA ANT-742, an AntennasDirect Clearstream 4V, a Winegard FM antenna (I know), and now a ChannelMaster 3016. The 3016 is receiving adjacent VHF channels from the same location (Mingus Mountain), but not 6. I do receive 7.1-7.3 as well as the PBS broadcasts (8.1-8.4) and they come in great. The antenna is mounted on a short pole on the roof, but the house sits below street level, so the antenna is more or less at ground level. I have both a pre-amp and a powered distribution amp. I can disconnect any of those if need be. There is no line of sight to the tower due to a single hillside
between the antenna and the transmission towers. I have a 6' extension pole that I can try, but it's pretty unstable/unwieldy.
Here's my reception lineup:
http://www.tvfool.com/?option=com_wr...51346d7732736e
I would sincerely appreciate any feedback as I'd love to be able to get NBC.
vysean is offline
post #16 of 16 Old 04-01-2016, 06:00 PM
vysean's Avatar
This was the prompt but unhelpful response from the manufacturer:
Have you considered contacting the broadcast tower? I suspect that the signal is simply too weak to come in, but they may be able to offer more assistance.
Since I get all of the other channels and many are lower power, I don't think that's the problem (but I'd be delighted to be proven wrong with a useful explanation).
vysean is offline
