Anyone receiving channel 9 (CBET) in Royal Oak, Michigan? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-04-2014, 07:52 PM - Thread Starter
apollo-creed's Avatar
I use to be able to watch channel 9 (CBET) here in Royal Oak, Michigan. But now I can't. I am using a large channel master rooftop antenna, and that still isn't enough to detect the channel. Does anyone else here in Royal Oak, or a nearby city receive channel 9?
apollo-creed is offline
post #2 of 3 Old 06-07-2014, 04:27 AM
Super Moderator
DrDon's Avatar
Quoted: 1250 Post(s)
Liked: 2420
Try the Detroit HDTV thread. Most AVS members bookmark their local threads and never check the root of this section. First thing I'd do is check all of your connections out and back. Got some pretty good storms, recently. DId they move your antenna? Moisture can affect some frequencies but not others. Otherwise, look for structures that just went up. Neighbors with some sort of transmitting equipment, trees that just came all the way in, etc.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #3 of 3 Old 06-07-2014, 06:54 AM - Thread Starter
Thank you for your help. I read on the wikipedia page for Channel 9 (CBET) that they reduced the size of their broadcast antenna. That is probably why I don't see this channel anymore.
