Lexington, KY - HDTV - Page 176 - AVS Forum | Home Theater Discussions And Reviews
post #5251 of 5339 Old 07-24-2014, 11:30 AM
William Smith's Avatar
Just a quick note:
I'm retiring from KET effective August 1st, 2014 due to family health issues.
William
William Smith is offline
post #5252 of 5339 Old 07-24-2014, 10:07 PM
HDTVChallenged's Avatar
Liked: 215
Originally Posted by William Smith View Post
Just a quick note:
William
Sorry to hear that, on both accounts. I think it's safe to say that KET, particularly in it's digital incarnation, wouldn't exist if not for your blood, sweat and tears (and probably more than a few muttered "curses." ) .... this is where I'm not sure what else to say ... except thank you and best wishes for your family ...
HDTVChallenged is offline
post #5253 of 5339 Old 07-25-2014, 11:03 AM
jb_ky1's Avatar
Quoted: 12 Post(s)
Just a quick note:
William
Wish you the best on your retirement... Hope all is okay with your family.
jb_ky1 is offline
post #5254 of 5339 Old 08-22-2014, 09:38 AM
Liked: 0
Why not make a listing in 1st post of all channels Available in this and all other dma's OTA ?
CA_LLS is offline
post #5255 of 5339 Old 10-12-2014, 11:20 AM
Liked: 0
GRIT TV coming soon to 56.3
CA_LLS is offline
post #5256 of 5339 Old 10-22-2014, 07:04 AM
tripelo's Avatar
Quoted: 21 Post(s)
WBKI (RF Channel 19) Signal Strength
Does anyone know if WBKI (RF 19) has made changes to antenna or transmitter in last several months?
Haven't read of any official FCC changes, and RabbitEars usually keeps informed of such.
The reason for the inquiry is that WBKI-19 has for a few years been easily received in Russell County, KY (41 miles to southeast) . For the past several months signal strength has dropped very signifcantly. Looking back at past 2-3 years of recorded signal measurements & spectrums, they show the signal was several dB stronger than currently at this particular location. Measurements made at a neighbor's antenna, more than a quarter mile away*, indicate similar results.
WBKI-19 present signal could be considered relatively strong, compared to most other distant stations (say Lexington ~ 70 miles away), but it can no longer be casually received, such as in an antenna sidelobe.
* A signal obstruction is a possibility. The neighbor's location, relative to this particular location, is almost perpendicular to the signal path from WBKI-19. An obstruction near either receiving location would have to be very wide to affect both locations. And, if close to WBKI, must surely be a fairly tall obstruction.
Posted this inquiry in the Louisville thread, 5 days earlier, so far no response.
tripelo is online now
post #5257 of 5339 Old 10-24-2014, 12:52 AM
Liked: 215
Saw it. I haven't had a chance to investigate. I wouldn't be surprised if they had encountered some weather damage ... I suspect most folks in Louisville/Jefferson Co. proper are relying on the Ch58(RF51) sub-channel.
post #5258 of 5339 Old 10-24-2014, 09:25 AM
tripelo's Avatar
Quoted: 21 Post(s)
Originally Posted by HDTVChallenged View Post
... I wouldn't be surprised if they had encountered some weather damage ...
Interesting. Thanks for your reply.
Because I'm in KY only a few times per year, cannot be sure when the signal decreased. The signal was definitely weak in June this year (2014), and in first couple weeks of this month (October, 2014).
In the past, because WBKI-19 had been comparatively strong, little attention was given it's actual signal strength.
I used to casually think of WBKI-19 and WBXX-20 as having about the same signal strength into Russell County. Even though WBXX-20 is ~75 miles distant vs ~40 miles for WBKI-19. Interestingly TVfool shows signal levels:
WBKI-19 : -61 dBm
WBXX-20: -77 dBm
Both paths are 1-Edge, mostly over hills & forest, antenna height 53 feet AGL.
So, TVfool shows about a 16 dB advantage to WBKI-19.
About a week ago, measured received power of WBKI-19 was lower than WBXX-20.
...I suspect most folks in Louisville/Jefferson Co. proper are relying on the Ch58(RF51) sub-channel.
Yes, probably so.
Wonder if that means WBKI-19 gets less attention from management/technical these days?
post #5259 of 5339 Old 10-24-2014, 11:59 AM
Liked: 215
I'm pretty sure there's been at least one (if not more) rounds of severe t-storms that pretty much had Raywick in the bull's-eye this summer/early fall.
Terrain (plus weather,) could very well be a factor too.
Since WKYT bumped 27.2(CW) up to 720p(ish,) I haven't been paying attention to WBKI as much ... The TiVo is much easier to schedule without having to worry about switching antennas.
post #5260 of 5339 Old 10-25-2014, 12:06 AM
Liked: 215
Follow up: I checked WBKI RF19 yesterday afternoon, and the signal strength was consistent with what I recall in the past. No problem with pulling it in on a side-lobe of my original recipe CM4228. I didn't have time to rotate the antenna around to on axis before the evening's recordings kicked off. (The rotor has a tendency to shred all RF signals when it is turning.)
Anyway, what ever is or was going on doesn't appear to be currently impacting the signal at my location (~43ish miles east-ish of the tower.)
... FWIW ...
post #5261 of 5339 Old 10-25-2014, 07:13 AM
tripelo's Avatar
Quoted: 21 Post(s)
... WBKI RF19 yesterday afternoon, ... consistent with what I recall ... pulling it in on a side-lobe of my original recipe CM4228...
...my location (~43ish miles east-ish of the tower.)...
Thanks for the data point.
As I recall the original 4228 had fairly low sidelobes, so your experience would be consistent with my past observations.
And, your distance to WBKI is similar to the distance from WBKI to Russell County. Of course the paths are somewhat different.
Anyway, what ever is or was going on doesn't appear to be currently impacting the signal ...
Next time, if the signal is weak at my location, will make some mods to receiving system to compensate and still allow sidelobe reception. Rotating antennas is not a usual thing here either. Might be trickier to help my neighbors system.
post #5262 of 5339 Old 01-02-2015, 02:39 PM
jb_ky1's Avatar
Quoted: 12 Post(s)
WDKY has now added 56.3 Grit TV.
Also no WLEX on DirecTV.
jb_ky1 is offline
post #5263 of 5339 Old 01-02-2015, 07:13 PM
ADWarrenLexKY's Avatar
Yep, 56.3 is new and carries Grit TV, all westerns. Wish WDKY would fix 56.2 broadcast of Get-TV....signal has has been compressed for months. Except the basketball games. WDKY will not reply, I have been in contact with TECH from GET-TV they are looking into it.
ADWarrenLexKY is offline
post #5264 of 5339 Old 01-03-2015, 01:49 AM
Liked: 215
The funny thing about that was they started their "evil D*" crawl the same night the OTA signal went down for at least 3.5 hours in primetime. Oh well, hopefully "Parks and Rec." will fit into the TiVo schedule ...
post #5265 of 5339 Old 01-04-2015, 05:15 PM
sam_gordon's Avatar
And the irony is DirecTV customers (along with Time Warner customers) still got a signal that night.
sam_gordon is offline
post #5266 of 5339 Old 01-05-2015, 01:55 AM
Liked: 215
True ... that was the first time I've used the D* feed in quite a while, probably since "Parks and Rec" finished up last season. (I try to keep the OTA stuff off of the D* DVR as much as possible.)
post #5267 of 5339 Old 01-13-2015, 12:12 AM
Liked: 215
It looks like WLEX and DirecTV have made up. Feed is back up as of 1/12.
post #5268 of 5339 Old 01-25-2015, 10:31 AM
Liked: 215
FWIW: It looks like DirecTV may be moving the remaining SD Locals over to the Ka spotbeam. Perhaps will finally get the "HD" version of CW? ....
post #5269 of 5339 Old 01-25-2015, 10:54 AM
unclehonkey's Avatar
Quoted: 270 Post(s)
Liked: 58
what they are doing is moving the locals that are on 119 over to the KA slots so installers dont need to install a SL5 LNB so you can get 1 or 2 stations in SD. They have been doing this for a couple months now.
unclehonkey is offline
post #5270 of 5339 Old 03-01-2015, 10:25 AM
demonspawn's Avatar
Glad too see you guys are still here it has been a long time since i have been here Guess i need to update everything
Jamie
No Longer Works For ELAN Home Systems, Sunfire and Homelogic Tech Support Specialist.
MY opinions are my own and when i am in forum i do not represent any of these companies!
demonspawn is offline
post #5271 of 5339 Old 05-27-2015, 09:46 AM
jb_ky1's Avatar
Quoted: 12 Post(s)
Did any Lexington TV station ever have translators?
jb_ky1 is offline
post #5272 of 5339 Old 06-07-2015, 06:50 AM
sam_gordon's Avatar
I don't believe so.
post #5273 of 5339 Old 06-07-2015, 07:48 AM
tripelo's Avatar
Quoted: 21 Post(s)
In the mid-late 1960's, there was a translator located on a knob in Somerset, KY that converted at least one channel (probably ch 18) to VHF.
As I understood it, the translator was owned and operated by Hobart Withers, a local TV repair shop owner and ham radio enthusiast. 'Hobe', as he was called was somewhat legendary with local ham operators.
post #5274 of 5339 Old 08-06-2015, 10:47 AM
jb_ky1's Avatar
Quoted: 12 Post(s)
Just ran across these... I remember seeing these 10-15 years ago. These stations never made it to the airways in Lexington.
Call NEW
Transmitter type NM
Channel 20
Authority DA
Frequency Offset 0
Zone 2
License ADD
City LEXINGTON
State KY
Country US
fileletter BPRM
filenumber -20000717ADO
erp 2500. kW
haat 352.7
Fac ID 127414
Lat degrees 37
Lat minutes 47
Lat second 24.00
Long degrees 84
Long minutes 15
Long seconds 33.00
Owner PAPPAS TELECASTING OF AMERICA AND TV CAP CORP OF LEXINGTON
Height Above Sea Level 612. m
H H
Antenna ID 44240
Pattern Rotation 0.
Antenna Structure Registration
Call W24BT
Transmitter type TX
Channel 25
Authority ND
Frequency Offset +
Zone -
License APP
City LEXINGTON
State KY
Country US
fileletter BPTTL
filenumber -20011010AAH
erp 100. kW
haat 0.0
Fac ID 37071
Lat degrees 38
Lat minutes 2
Lat second 23.00
Long degrees 84
Long minutes 24
Long seconds 10.00
Owner MS COMMUNICATIONS, LLC
Height Above Sea Level 567. m
H -
Antenna ID 17730
Pattern Rotation -
Antenna Structure Registration 1030383
Call 960722KH
Transmitter type TV
Channel 62
Authority ND
Frequency Offset Z
Zone 2
License APP
City LEXINGTON
State KY
Country US
fileletter BPCT
filenumber -19960722KH
erp 5000. kW
haat 610.0
Fac ID 82790
Lat degrees 38
Lat minutes 12
Lat second 48.00
Long degrees 85
Long minutes 10
Long seconds 16.00
Height Above Sea Level 848. m
H H
Antenna ID -
Pattern Rotation -
jb_ky1 is offline
post #5275 of 5339 Old 09-09-2015, 07:12 PM
Call NEW
Transmitter type NM
Channel 20
Authority DA
Frequency Offset 0
Zone 2
License ADD
City LEXINGTON
State KY
Country US
fileletter BPRM
erp 2500. kW
haat 352.7
Fac ID 127414
Lat degrees 37
Lat minutes 47
Lat second 24.00
Long degrees 84
Long minutes 15
Long seconds 33.00
H H
Antenna ID 44240
Pattern Rotation 0.
Call W24BT
Transmitter type TX
Channel 25
Authority ND
Frequency Offset +
Zone -
License APP
City LEXINGTON
State KY
Country US
fileletter BPTTL
erp 100. kW
haat 0.0
Fac ID 37071
Lat degrees 38
Lat minutes 2
Lat second 23.00
Long degrees 84
Long minutes 24
Long seconds 10.00
H -
Antenna ID 17730
Pattern Rotation -
Call 960722KH
Transmitter type TV
Channel 62
Authority ND
Frequency Offset Z
Zone 2
License APP
City LEXINGTON
State KY
Country US
fileletter BPCT
erp 5000. kW
haat 610.0
Fac ID 82790
Lat degrees 38
Lat minutes 12
Lat second 48.00
Long degrees 85
Long minutes 10
Long seconds 16.00
H H
Antenna ID -
Pattern Rotation -
No translators in Lexington area but there was a full power Channel 62 for a while..
Studios were located on New Circle just South of Broadway.. The transmitter was on a 500 ft tower off North Cleveland Road.. The antenna was side mounted so they could increase tower height to 1000 ft.. The STL tower was too short and the path was blocked often by swaying trees near the old Brian Station High School.. Bob Klein ( former CE at KET) was the CE. Later his assistant came to work at KET with me so I got the gory details.. Sam, Don Case ( formerly of WLEX) worked there for a while too..
It was a TTC Silverline transmitter and from what I was told the biggest issue was Bob taking out transistors and putting them in backwards...
By the time they got around to raising the STL tower to eliminate the fades, the damage was done..
William Smith
Now working TV without pictures...
post #5276 of 5339 Old 01-21-2016, 10:12 PM
Whats up with 56.2?? Sonys GET tv is replaced with cheap, low budget Comet tv.
post #5277 of 5339 Old 03-17-2016, 02:49 PM
Liked: 0
Im hoping someone may be able to shed some light as to why 1 station in Lexington I am having problems with. The station Im having issues with is WTVQ-DT 36.1 which is only 4.1 miles away from me but I get alot of pixelation on it. This doesnt happen on any other channel ones closer and father I even get the 67.1 WUPX channels that are 46 miles away. I am using indoor antenna because I get all of the channels available for me so have never tried outdoor antenna since I live in a apartment and this is frowned upon here. But I have tried 3 different ones and all of them do the same thing. It just doesnt make since to me why the signal would be weak for such a close broadcast. I am using a Tivo Roamio and it shows the signal strength as 69 - 71. Any suggestions ?
Here is My TVFOOL INFO
bryankc14 is offline
post #5278 of 5339 Old 03-30-2016, 10:56 AM
jb_ky1's Avatar
Quoted: 12 Post(s)
If you get WLEX just fine, then you should get WTVQ even better. They are on the same tower.
WTVQ is on top of the tower and WLEX is on the side (less power too). Right?
jb_ky1 is offline
post #5279 of 5339 Old 03-30-2016, 10:58 AM
jb_ky1's Avatar
Quoted: 12 Post(s)
Anyone think will any of the Lexington stations get selling their spectrum or moving channels? Lexington just loves VHF channels.
https://drive.google.com/open?id=0B2...FRKb3JmVkRMUGM
jb_ky1 is offline
post #5280 of 5339 Old 03-30-2016, 11:28 AM
tripelo's Avatar
Quoted: 21 Post(s)
WDKY might be a participant, for the following reasons:
1. Sinclair announced it would be a participant, WDKY is a Sinclair station.
2. WDKY had an FCC approved construction permit for upgraded antenna that would have allowed better coverage. WDKY let it expire without action, not long after the time the auction was announced.
3. WDKY-31 has a high initial offer price in the auction and a high rank for 'Interference', both indicators of FCC off-the-air desirability .
4. WDKY probably has the equipment required to go back to low VHF.
