Lexington, KY - HDTV - Page 178 - AVS Forum | Home Theater Discussions And Reviews
post #5311 of 5327 Old 05-19-2016, 05:33 AM
jb_ky1's Avatar
Originally Posted by sam_gordon View Post
Depends on your definition of "soon". Safe to say not in the next few months. Part of me looks forward to one, but I also know what a hassle it is to swap it out.
BTW, MeTV is now HD. Certain shows and most local commercials will be HD. Other shows will be 4x3. They're supposedly working on remastering all the shows, but it will obviously take a while.
Haha, I am sure it's a big job to take it apart, build a temp set in the newsroom, and build a new set. Although it will look great I am sure when you all build one. Thankfully Centerpointe hasn't been build yet, would of had to change out the backdrop on the set, so you all are safe for a few more years haha.
Cool! I look forward to some HD on MeTV.
jb_ky1 is offline
post #5312 of 5327 Old 05-31-2016, 01:02 PM
Gruber22's Avatar
Looks great! I noticed that a few days ago.
I wish the remaining local SD channels would at a minimum deliver 16x9 SD. In particular, 56.2 and 56.3 - on 2 different tv's they look like old anamorphic DVDs (squished in from the sides) - and one of them is a recent 32" Sceptre (cheapo from walmart). 46.2 & 46.3 would also work better as 16x9SD - most everything I notice on 46.2 looks wide screen anyway so not sure why they don't just deliver it as 16x9.
Gruber22 is offline
post #5313 of 5327 Old 06-09-2016, 10:29 AM
jb_ky1's Avatar
WTVQ-36 had added yet another subchannel. 36.5 Escape TV. http://www.escapetv.com/
36.4 Laff TV.
jb_ky1 is offline
post #5314 of 5327 Old 06-20-2016, 07:51 AM
sam_gordon's Avatar
Another Subchannel...
WLEX has launched BounceTV on 18.3.
Scan your TVs.
sam_gordon is offline
post #5315 of 5327 Old 06-20-2016, 08:14 AM
jb_ky1's Avatar
Scan your TVs.
Nice! Not in HD I guess? 18.2 looks good though.
jb_ky1 is offline
post #5316 of 5327 Old 06-20-2016, 08:26 AM
sam_gordon's Avatar
Ha! No.
post #5317 of 5327 Old 06-20-2016, 08:28 AM
jb_ky1's Avatar
Ha! No.
haha, good. TVQ just added their 5th and all of them are starting looking really compressed.
jb_ky1 is offline
post #5318 of 5327 Old 06-20-2016, 02:22 PM
sam_gordon's Avatar
It's the trifecta:
18.1: 1080
18.2: 720
18.3: SD
post #5319 of 5327 Old 08-01-2016, 12:09 PM
Trip in VA's Avatar
Quoted: 467 Post(s)
Liked: 136
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
I'm hearing Justice is now on 36-3 and Antenna was bumped to a new 36-6. Anyone seeing it?
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #5320 of 5327 Old 08-02-2016, 10:16 AM
jb_ky1's Avatar
- Trip
Yep! You are correct.
jb_ky1 is offline
post #5321 of 5327 Old 08-23-2016, 05:43 AM
jb_ky1's Avatar
I guess MeTV on 18.2 has zoomed in on some of the shows now? The side bars aren't as big.
jb_ky1 is offline
post #5322 of 5327 Old 09-21-2016, 07:14 PM
Liked: 0
WIDER Cable Distribution and NEW sub-channels COMING SOON to WOBZ 9
stevekent09 is offline
post #5323 of 5327 Old 09-22-2016, 07:07 PM
Liked: 0
A BUZZ is coming to WOBZ 9
post #5324 of 5327 Old 09-25-2016, 11:42 AM
Liked: 0
COMING SOON to WOBZ 9 ... A NEW GAME IS IN TOWN FOR THE SHOW
post #5325 of 5327 Old 10-21-2016, 08:42 AM
Liked: 0
Channel 36.1 thru 36.6 signal loss.
Has anyone else had any problems? Mine started gradually about 10 days ago. For the last 4 days it's unwatchable. Channel 18 or any other Lexington channel hasn't been affected, just 36.
I'm about 40 miles away 'as the crow flies' and due to terrain also, so a 5-10 dB loss is the difference in getting a signal or not.
tuneraider is offline
post #5326 of 5327 Old 11-03-2016, 10:26 AM
jb_ky1's Avatar
I don't watch channel 36 that much, but happen to check there yesterday morning and it did cut out... I live in south Lexington.
jb_ky1 is offline
post #5327 of 5327 Unread 11-04-2016, 07:06 PM
Liked: 0
reception problems
hello all,
i'm looking for advice - i'm cutting the cable tie and trying to just receive channels OTA. i purchased an antenna (relatively cheapo radio shack) and have no problems getting all local stations EXCEPT wkle/wket.
checking on tv fools, apparently i'll need an attic antenna at the least (surprising to me, as i live less than a mile from ket headquarters). i might just go ahead a purchase a rooftop antenna, but before i do, does anyone have any recommendations or experience with room antennas and ket reception within lexington?
if not, any recommendations for rooftop antennas?
thanks in advance!
pbs fan is offline
