Can I split signal from Directv after box? - AVS Forum | Home Theater Discussions And Reviews
Old 07-31-2014, 06:19 AM - Thread Starter
Liked: 0
I want to connect a 2nd TV. I realize I can only watch the same program that is on the MAIN TV, that is fine. I also realize I will have to change the channel from the MAIN TV, that is fine also.
I now have HDMI going to MAIN TV. Can I also have a coax from box to 2nd TV? I will only have a box on MAIN TV. Will this type of setup work?
Thanks for any help.
bayridge is offline
Old 07-31-2014, 07:06 AM
ProjectSHO89's Avatar
Quoted: 212 Post(s)
Liked: 110
You might be able to use an HDMI splitter, depending on your distances and whether or not the two sets and the DirecTV box cooperate.
HD DirecTV boxes do not have coax out as a feature.
ProjectSHO89 is online now
Old 07-31-2014, 09:02 AM - Thread Starter
Liked: 0
Right, no coax out on box. Didn't think of that.
It's about 60 feet. 3 rooms away but direct path, so no walls.
There's only 1 HDMI on box so I guess I'll need a HDMI splitter.
bayridge is offline
Old 07-31-2014, 07:36 PM
cgmv123's Avatar
Quoted: 40 Post(s)
Liked: 36
Make sure you get an amplified splitter. 60 feet is pushing it for a single run of HDMI.
Max Vrany
@cgmv123
cgmv123 is offline
Old 08-01-2014, 08:52 AM - Thread Starter
Liked: 0
I was reading someplace that there is an adapter so one can use regular cat5 cable. I want to keep cost down as much as possible. Have you heard of this adapter?
bayridge is offline
Old 08-01-2014, 09:33 AM
Otto Pylot's Avatar
Quoted: 1364 Post(s)
Liked: 854
That sounds like HDBase-T (HDBT) and it can get expensive. CAT-6 -> HDBT.
Otto Pylot is offline
Old 08-01-2014, 09:35 AM
dishrich's Avatar
Quoted: 56 Post(s)
Liked: 39
Did you consider running a component cable to (either) TV??? Both outputs are active; however, there is the caveat that on some channels that have HDCP (mostly premium channels) you would have to either keep the TV on HDMI either turned on, or disconnected from the HDMI cable - otherwise you would get the HDCP message on the component TV connection. But if you could live with these limitations, you would not have to spring for the HDMI splitter...
dishrich is offline
Old 08-01-2014, 09:07 PM - Thread Starter
Liked: 0
Got me there. Haven't a clue what you're talking about. Don't know what a component cable is? Or HDCP. Got the Genie box (HR34 I think) in Living room and a Visio TV in Bedroom. Don't care that I have to tune from Living room or have to watch same channel. Just want to be able to watch TV in bedroom once in a while. I have bedroom hooked up to one of those paper thin local antennas that only gets local channels. Works good but want to watch my saved shows on Genie box.
bayridge is offline
Old 08-02-2014, 08:21 AM
dishrich's Avatar
Quoted: 56 Post(s)
Liked: 39
You probably should then just get a Mini client for that TV, pay the extra monthly $6 for it & call it a day...would be much easier for you to deal with.
Actually they now also have the wireless mini clients out now, that you would not even have to have a coax run to that TV...
dishrich is offline
