Memphis, TN - HDTV - Page 201 - AVS | Home Theater Discussions And Reviews
Old 06-30-2013, 09:26 PM
fastoy's Avatar
Originally Posted by jbburks View Post
I called Comcast today to try and get the price down (it went up again).
I was thinking of going CableCard and Tivo, but they told me they now have a multi-room DVR with more capacity. They gave me a good 12-month deal on that, and I'm going to try it. They have to come out to install it.
Has anyone else tried that?
Tried what? Believing Comcast? Nah.
fastoy is offline
Old 06-30-2013, 09:42 PM
fastoy's Avatar
I've been using a SageTV system and a Hauppauge PVR-350 to record SD video and burn it to DVDs. The whole story is here.
I've been using the TiVo to record HD video and burn it to DVDs. The whole story is here.
Here's the question. Today when I recorded SD video (channel 207 in Memphis Comcast) on the TiVo and transferred it to TiVo Desktop the resolution was 528x480. That's a non-standard DVD resolution and will require me to transcode to burn DVDs.
I presume that this resolution is pushed by Comcast. Why is Comcast using such an odd resolution?
Does anybody have a suggestion on how to get a standard DVD resolution without transcoding?
fastoy is offline
Old 07-12-2013, 09:41 PM
jbburks's Avatar
Originally Posted by Tom Thomas View Post
I'd really like to hear how it goes for you as I'm considering doing the same thing. When you get it installed would you post back with how it's working and the model DVR etc you got.
Sorry I don't check back often enough. I got the MR DVR and it works reasonably well, for Comcast. It's a Cisco RNG150N. Two tuners. Both rooms can view recordings. But inexplicably, only the room with the DVR can set or delete recordings. The remote can only view recorded or live. Can't even pause.
Quite stable.
But the external eSATA that worked well on the SA 8500 II doesn't work on this box, even though there is an eSATA connector.
jbburks is offline
Old 07-13-2013, 01:55 PM
fastoy's Avatar
Comcast Internet in BelMor subdivision (southwest of Hwy 305 and College Rd.) of Olive Branch has been down since Thursday 7/11 9:00AM. When you call into 800-COMCAST and enter your account # they say they are having "technical difficulties" in your area and give an estimate of when service will be available. They seem to just be moving that time forward.
Any idea what has happened?
fastoy is offline
Old 07-14-2013, 11:30 AM
fastoy's Avatar
On page 12 of the RNG150N User Guide it says "Your cable service-provider may enable a feature that allows an external hard disk to work with your set-top." (emphasis added)
fastoy is offline
Old 07-15-2013, 08:22 AM
Tom Thomas's Avatar
Quite stable.
Do you have just the one RNG150N and it works with both TVs? I'm not sure I really understand. Is that the DVR and Multi Room device?
Tom Thomas is offline
Old 07-15-2013, 09:27 PM
fastoy's Avatar
My daughter's Comcast Internet in BelMor subdivision came back up the morning of Monday 7/15. Comcast told us that "Node Y54" had some cable modems blocked and that they have been having issues since 7/2. Speaking with neighbors several of them have had problems recently that were resolved after several days. I'd guess they have a block of ports down in that node and are moving people around when they call and complain.
fastoy is offline
Old 07-16-2013, 07:09 PM
jbburks's Avatar
The RNG150N is the dual tuner DVR. There is another Cisco cable box that is the remote unit and has its own tuner. They are only connected via the home coax.
jbburks is offline
Old 07-17-2013, 07:57 AM
Tom Thomas's Avatar
Thanks for the info, I think I'm getting the idea now of how it all works.
Old 07-29-2013, 07:41 PM
Afroteddy's Avatar
My cable has been up and down and my internet has been totally down for almost a week. Been getting the run around from customer support since the beginning. They either lie to me, ask stupid questions, or blame my setup. There used to be a regional office that I would go to complain to in person but I was told today that it has moved to Nashville. I really want some executive assistance with this matter.
From my own research I've determined that my return voltage is too high and that it's caused by a dirty line from outside of my apartment.
Afroteddy is offline
Old 07-30-2013, 11:19 PM
fastoy's Avatar
Have you tried tweeting to @comcastcares?
If you know anybody that works for Comcast they can get you a "Make It Right" card with a direct # to call. They're not magic but at least it's somebody you can talk to and they will run the gauntlet that is Comcast Customer Service and Maintenance.
fastoy is offline
Old 08-01-2013, 01:45 PM
Afroteddy's Avatar
I don't have a Twitter account. I wonder if one of the local bill pay offices has one of those cards.
Old 08-03-2013, 08:43 AM
teCh0010's Avatar
So I am on dish and lost channel 5 because of the raycom deal, what antenna do I need to pick up 5 in collierville? I know they are on VHF vs. most being on UHF. Antenna web just shows yellow.
teCh0010 is offline
Old 08-03-2013, 03:59 PM
ProjectSHO89's Avatar
Quoted: 93 Post(s)
Liked: 77
Channel 5 in Memphis operates on "real" channel 5 which often requires a wide VHF antenna. A small all-channel combo should work for your city.
ProjectSHO89 is offline
Old 10-29-2013, 10:52 AM
eaamon's Avatar
Quoted: 32 Post(s)
a regular old TV antenna, VHF-UHF is and was never obsolete and will work just fine tuning in todays TV stations.
why? well they many times are still broadcasting on the same old frequencies......a HD antenna is just a gimic......sales point like re-bait.
what might have changed is some stations have gone to UHF for good. but they have the ability to have your TV display the channel they
use to be on. a station really broadcasting on UHF channel 43 can be displaying channel 2.1 on your digital TV.
just be sure the older antenna has good clean wire connections.
my HT
eaamon is offline
Old 04-18-2014, 02:54 PM
wvvolfan's Avatar
Comcast XFINITY On Demand is now available on TiVo Premiere and Roamio Series DVRs throughout the state of Tennessee.
http://www.tivo.com/discover/cable
wvvolfan is offline
Old 07-09-2014, 06:30 PM
Tom Thomas's Avatar
Did anyone else get smaller guide in the Memphis area on Comcast today? It now looks to be 4:3 instead of 16:9. It shows up that way on my RNG150 and 8300HD boxes.
Old 07-14-2014, 03:25 PM
Tom Thomas's Avatar
I've also found that now the Xfinity TV Go and TV Remote Apps work with both my RCG150 and 8300HD DVR. I can control each from my iPad, iPhone and computer. I can now set up recordings, change channels, access OnDemand content and access my DVR remotely where I couldn't do any of that before.
Old 12-30-2014, 01:00 PM
unclehonkey's Avatar
Quoted: 62 Post(s)
I know it isnt Memphis related but its a neighboring market that some folks may get
KAIT ABC (Jonesboro) to add NBC the week of 1/26
http://www.kait8.com/story/27724733/...n-late-january
Residents in northeast Arkansas and southeast Missouri will soon be able to watch programming from a second television channel affiliated with KAIT. An announcement was made Monday afternoon.
KAIT, Region 8's ABC affiliate, will also begin broadcasting NBC programming to residents in the Region 8 News coverage area. NBC Region 8 will be seen over the air on 8.2 and on cable and satellite providers.
NBC Region 8 will begin broadcasting the week of January 26, 2015.
unclehonkey is online now
Old 12-30-2014, 02:50 PM
Neil L's Avatar
^^Interesting... don't know how much benefit I will get from this, but it's always good to have more options.
How common a practice is this...for a ABC affiliate to carry NBC programming? I've never before heard of any station broadcasting programming from two different networks.
Neil L is offline
Old 12-30-2014, 03:13 PM
Trip in VA's Avatar
Quoted: 141 Post(s)
Liked: 75
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
KSBW, WGTU/WGTQ, KTEN, KGNS, WBOY, WIVT, KBMT, WTVA...
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
Old 12-30-2014, 03:18 PM
Quoted: 62 Post(s)
in smaller markets it is very common. Jonesboro is a 1 commercial station market
KAIT 8 ABC
They have PBS and a religious station too
But if we are just talking "Big 4" stations some examples of a Big4 net being a subchannel
-Mankato, MN (75 miles from Minneapolis). KEYC CBS -1, FOX -2 (1 station market)
-Presque Isle, Maine Fox -1, CBS -2 (1 station market + PBS)
-Glendive, MT CBS -1, NBC -2 (1 station market)
-In almost all Montana markets Fox is a subchannel on ABC
-Ottumwa, IA ABC on -1, CBS on -2...conversely in Quincy, IL CBS is -1, ABC -2 (same owners). Also in Quincy NBC -1, CW (SD) -2 FOX on -3
-Alexandria, LA ABC -1, CBS -2
-Albany, GA NBC on -1, ABC on -2
-Sherman, TX/Ada OK runs all 4 nets (6 with My & CW) off 2 stations. CBS -1, My (SD) -2, FOX -3. NBC -1, CW (SD) -2, ABC -3
-Wheeling, WV CBS -1, My -2, ABC -3. NBC -1, FOX -2
-Cheyenne, WY CBS -1, NBC -2 (also on a low powered station)
And due to crackdowns by FCC of companies owning more than 1 of the BIg 4 in a small market companies moved stations to subchannels of their owned stations. Sinclair has done it. Gray is big on it. They buy everything but the transmitter and license of the station they want, then move everything to a owned station. In most cases the stations were co-owned (or one was run) under the old owner but the FCC doesnt want that anymore.
Examples of Gray
-Lincoln, NE. Put NBC on their owned CBS station as a subchannel
-Grand Island, NE. same thing but the existing NBC closed down
-Western ND. Fox put as subchannel on NBC
-Fargo, ND. CBS put on subchanel of NBC recently
-Monroe, LA ABC is now a subchannel of CBS
Old 12-30-2014, 06:32 PM
Neil L's Avatar
Hmmm, I would have never thought it so common. It's all part of the new digital age, I guess.
Thirty plus years ago, when OTA TV was all that I had, I suppose it wasn't really possible to carry anything extra. They only had one channel licensed. Sheesh! I'm feeling old and out of touch with technology.
Neil L is offline
Old 01-03-2015, 01:05 PM
Quoted: 62 Post(s)
WMC changed 5-3 from This to Grit in the last day or so
Old Today, 12:13 PM
Quoted: 62 Post(s)
went live this morning
schedule here
http://www.kait8.com/link/5478/kait-tv-programming
