wjla channel 7 Washington dc - AVS Forum
Old 10-13-2014, 06:17 PM - Thread Starter
Liked: 0
I have 3 TVs 2 vizio and 1 Insignia Could get all 7 associated channels 7.1,7.2, 7.3 when new antenna installed but lost them on vizio TVs.insignia still fine tried all methods to reset Vizios and rescan channels but cannot get them back Thank you
todd0613 is offline
Old 10-16-2014, 08:11 AM
Jake V's Avatar
What kind of new antenna did you install? Provide the model number. And check the specifications to see if it provides support for VHF-HI.
What was the model of your old antenna? Why did you replace it?
Does channel 9 - WUSA - come in OK?
You might check out your specs at TVFool.com
Jake V is offline
