Baytown, TX - HDTV - AVS Forum
post #1 of 4 Old 10-25-2014, 02:13 PM - Thread Starter
Cypsteel's Avatar
Liked: 0
Question Help with Antenna selection - Baytown, TX
So I am trying to cut the Comcast cord and go with a family DVR setup with Plex, WMC, and a couple HDhomerun Plus's. The one problem I don't know anything about is the whole OTA HD signals. My wife would die without her news and local CBS channel. It looks like I have a wide selection of channels in a very clear direction from me 249 and 250, but they are 40-45 miles away.
Here is my antennaweb report. I would like to get the yellow and green channels.
hxxp://*******/Lmf7Y0
Here is my tvfool report:
hxxp://*******/rsJgEC
What antenna should I buy for an attic installation? I plan on running the signal straight into a HDhomerun Plus or possibly splitting the signal and running into 2 HDhomerun Plus's. (the HDhomerun Plus just distributes it to the WMC for recording and other devices around the house to stream from)
1) Would something like this work? hxxp://*******/8WP95U
2) If I do end up getting a second HDhomerun Plus and splitting the signal, does it take a special splitter? Would I need a separate amplifier at that point?
3) Due to all the channels I want being at 249-250 direction, does a directional antenna make more sense?
Thanks in advance for any assistance. *Can't post links as I am new here*
Cypsteel is offline
post #2 of 4 Old 10-25-2014, 02:16 PM - Thread Starter
Cypsteel's Avatar
Liked: 0
Ridiculous that I can't post links about my setup....*sigh* Those links above are goo<dot>gl URL shortner. I was hoping that would get by the forums automatically scraping my url links... so just replace the ******* with goo <dot> gl
Cypsteel is offline
post #3 of 4 Old 10-25-2014, 08:15 PM - Thread Starter
Cypsteel's Avatar
Liked: 0
And that is a google URL shortner for those who aren't familar with it
Cypsteel is offline
post #4 of 4 Old 10-26-2014, 12:13 PM - Thread Starter
Cypsteel's Avatar
Liked: 0
Is there other information I should provide? Or is the whole link missing the problem? History shows that this forum is usually pretty helpful....
Cypsteel is offline
