Moneta, VA - TVfool report URL - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-11-2014, 02:04 PM - Thread Starter
stephenson's Avatar
Hi,
Am located in Moneta, VA - on the eastern side of Smith Mountain Lake.
TV Fool report is at - whoops - forum won't allow ...how do I get the report to the forum?
I have a DB4 bowtie on a pole attached to the chimney - about 20' off the ground.
Usual RG 6 coax run of about 25' to a splitter where is goes to three locations - all 20-30' from the splitter.
I am currently not quite getting all the green channels without pixelation.
I have tried repeatedly to point the DB4 for better reception, but haven't found the "best" point ...
This is a second home -neither cable, DSL, or FIOS are available. DISH, etc is, but I don't want to pay for TV when I can't get internet ... :-)
Enlarging antenna is easy to do, but I can't change the height (my quick look at height models shows it wouldn't make much of difference anyway). My reading turns up lots of non-definitive options - would appreciate thoughts and recommendations on type, size and amplification.
George
stephenson is offline
post #2 of 4 Old 11-11-2014, 02:08 PM - Thread Starter
stephenson's Avatar
tvfool com/?option=com_wrapper&Itemid=29&q=id%3dd243fa826d9ca 0
post #3 of 4 Old 11-11-2014, 02:09 PM - Thread Starter
stephenson's Avatar
Sorry to have to trick the software - moderator, please don't yell, pls, as is just the tvfool report for my location :-)
Thanks to everyone!
post #4 of 4 Old 11-11-2014, 04:29 PM
Trip in VA's Avatar
Quoted: 862 Post(s)
Liked: 255
Send a message via AIM to Trip in VA
What channels are you getting and what channels are you missing? I am almost sure you're missing 15-1, because the DB4 is about as wrong for 15-1 as you can get. You will need a low-VHF antenna if you need PBS.
To my knowledge, WTLU and WEDD-LD are both currently off the air.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
