Looking to Cut the Cord - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-21-2015, 09:43 AM - Thread Starter
Liked: 0
Looking to cut the cord to my cable box for i only have one TV:
I will be saving $65 a month for a total of $780 a year. I might go for a Channel-Master DVR or Hulu for $8 a month which will drop savings to $684 a year which is still really good.
I'm on the ground floor, and indoor antennas do not work for me the indoor antenna i have (leaf) works outside but i don't get 7-ABC/11-CW/13-PBS
I'm looking for an antenna that will do:
Hi-V
Omi-Directional
I need to get channels:
2-CBS/4-NBC/5-FOX/7-ABC/9-MYN/11-CW/13-PBS
What antenna should i getm it wont be going on the roof it will be going only 9 Feet High or 19 Feet High.
Thank you in advance.
Techmanac is offline
antenna , hi-v , Hulu , omi-directional , outdoor
