Indianapolis / Terre Haute / Lafayette, IN - HDTV - Page 248 - AVS Forum | Home Theater Discussions And Reviews
 37Likes
post #7411 of 7422 Old 08-04-2017, 03:32 PM
ccrider2's Avatar
Quoted: 36 Post(s)
Originally Posted by unclehonkey View Post
If they are owned by same company (as is the case) they can have the station on more than one RF station. Its not really competition since its the same feed. Since there is nothing out there on the FCC site for WPBY-CD or a channel 35 licensed to Lafayette I have to guess.
The reason stations map networks to more than one RF station (when they own more than one) is mainly coverage. I'll give you an example
In Minneapolis FOX is on BOTH RF29 & RF9. They were on analog 9 but when the DTV transition happened lots of indoor antenna folks lost FOX 9 when KMSP (FOX) went back to RF9. Since FOX owns both KMSP and WFTC (which is on RF29) they mapped a SD feed of Fox on RF29. A few years ago they redid it so if you scan RF29 you get FOX HD on 9-1, My HD on 9-2 and Movies on 9-3. If you scan RF9 you get Buzzr on 9-4, Light on 9-05 and FOX HD on 9-9.
I know in St Joseph, MO they did the same thing. They recently got CBS there and its on a low powered station (KCJO). The issue is its only at 750 watts (shortspace with a KC station also on RF30). So they also put it on co-owned KNPN RF26 which has FOX on the -1 which is at 15,000 watts. So better coverage.
I think they're just "hogging-up" air-space to be able to sell that space to other investors in the future when the internet opens up to different uses. Probably a law that requires them to use the space, but not in any regard to actual programming.... just a supposition on my part.
Chris C
ccrider2 is offline
post #7412 of 7422 Old 08-05-2017, 11:33 AM
Vidop's Avatar
Quoted: 211 Post(s)
Liked: 100
Good explanation. Sounds reasonable to me. Even though I knew both stations are under the same ownership, it just seemed odd that they both were carrying ABC in the same DMA. Once again, thanks for the comeback.
Vidop is offline
post #7413 of 7422 Old 08-05-2017, 08:11 PM
Liked: 6
ccrider2 wins post of the day. There's no commitment to serving Lafayette / West Lafayette long term. Simply speculation on a future payday.
Takin'Charge is offline
post #7414 of 7422 Old 08-05-2017, 08:16 PM
Liked: 6
Originally Posted by Vidop View Post
Why do these two LaFayette stations both carry the ABC net feed in the evening?
Quick aside, Vidop. Are you new to Lafayette? Purdue, perhaps? The reason I ask is your spelling "LaFayette." Not something I see long term residents do.
post #7415 of 7422 Old 08-06-2017, 07:29 AM
Vidop's Avatar
Quoted: 211 Post(s)
Liked: 100
So-am I new to the LaFayette area? Yes and no. I grew up in this area. But, for the last 35 years, I've lived/worked in Chicago. I've now retired and moved back to LaFayette.
As to why I capitalize the "F" in the name, you may wonder?
In grade school (in the mid-fifties--yes, I'm that old), we were all taught that the proper spelling was with a capital "F". Here are the reasons that were given.
1) Obviously, this is a French name from the American Revolutionary war. You always capitalize a name.
2) In French, the name is really two words. The "La" and "Fayette". So, since it is a name, both first letters of the two words should be capitalized.
Whether these reasons are valid or not, that is what I (and other classmates) were taught back then. So, that is ingrained in my memory. I do realize, though, that most people do spell it with the small "f". I'll persist in being being contrary and continue to use the capital "F". :-)
Thanks for asking!
Vidop is offline
post #7416 of 7422 Old 08-06-2017, 07:38 AM
Liked: 6
I suspected that to be the case. I'm a bit younger than you (grade school in the mid 60s) but spent a few years in the area and didn't recall seeing anyone spell it that way. I trust there's no offense that I asked.
post #7417 of 7422 Old 08-06-2017, 11:47 AM
Vidop's Avatar
Quoted: 211 Post(s)
Liked: 100
Don't give it a second thought. No offense was taken by your question. I took it as an idle curiosity query.
Vidop is offline
post #7418 of 7422 Old 08-12-2017, 10:13 AM
Liked: 0
WLFI launched CW Plus on 18.2 on August 1. WTHI is supposed to add it as well on 10.3, but it has been delayed. I think it's because they need equipment to launch an additional HD channel. They already had the main CBS and Fox on HD, and this will be a third. WLFI only had the CBS channel in HD.
johnothy is offline
post #7419 of 7422 Old 09-13-2017, 05:34 PM
TechFan893's Avatar
Liked: 0
The CW on WTHI launched last Wednesday and I can confirm that it is in 720p. That now means they are running three channels in HD and one in SD.
10.1: CBS (1080i)
10.2: Fox (720p)
10.3: CW (720p)
10.4: Ion (480i)
TechFan893 is offline
post #7420 of 7422 Old 09-23-2017, 01:04 PM
a68oliver's Avatar
I recently replaced my AVR with a new one capable of playing Dolby Atmos programming. I have now completed installation of ceiling speakers and have been giving it a good test run.
However, something odd is happening on one channel. I am receiving programming through Comcast in Crawfordsville. Most channels are broadcasting audio in Dolby Digital 5.1, some in 2.0. My receiver is operating in an auto surround mode which decodes the audio into an appropriate format and distribute it to my speakers. Here is what it reports:
Input: Dolby D 2.0 ch, Output: Auto Surround 2.0 ch
Input: Dolby D 5.1 ch, Output: Auto Surround 5.1 ch
Input: Dolby D Ex 6.1 ch B, Output: Auto Surround 5.1.2 ch
The 6.1 broadcast is from WISH TV 8. This is from both the HD and SD cable broadcast.
Are they actually broadcasting a 6.1 signal or is Comcast messing with it somehow? I can't tune this in OTA to check.
Alan Oliver
Tivo user since May 2000
a68oliver is offline
post #7421 of 7422 Old 09-23-2017, 05:56 PM
ccrider2's Avatar
Quoted: 36 Post(s)
OTA only; don't know if this helps, but TSReaderLite generates the below as an HTML export for WISH TV Ch 9 8.1 'The CW Network' - Kansas City/Sox Ball Game currently on.
Program Association Table
PAT Version Number: 7
Transport Stream ID: 1121 (0x0461)
PMT PID 48 (0x0030) - Program 3 WISH-HD
PMT PID 64 (0x0040) - Program 4 Get TV
PMT PID 80 (0x0050) - Program 5 JUSTICE
Program Map Table(s)
Program Number: 3 WISH-HD
Descriptor: Smoothing Buffer Descriptor
SB Leak Rate: 0 SB Size: 0
Descriptor: Registration Descriptor
Format identifier: 0x47413934 (GA94)
Descriptor: ATSC Content Advisory Descriptor
ATSC Content Advisory Descriptor:
Region 1 Rating: None Description:
PCR PID: 0x0031
Stream Type: 0x02 MPEG-2 Video PID 49 (0x0031)
MPEG Video: Bitrate 25.000 Mbps Resolution 1920 x 1080i
MPEG Video: Framerate 29.97 fps Aspect Ratio 16:9 Chroma Format 4:2:0
Descriptor: Data Stream Alignment Descriptor
Alignment type: video access unit
Descriptor: ATSC Caption Service Descriptor
ATSC Caption Service Descriptor:
Language: eng Format: Line 21 captions from Even field
Stream Type: 0x81 AC-3 Audio PID 52 (0x0034)
AC3: Bitrate 384 Kbps Sample Rate 48 KHz
AC3: Mode complete main Coding 3/2 5 L, C, R, SL, SR
Format identifier: 0x41432d33 (AC-3)
Descriptor: ISO639 Language Descriptor
Language: eng
Audio type: undefined
Descriptor: ATSC AC-3 audio Descriptor
ATSC AC3 Descriptor
Stream Type: 0x81 AC-3 Audio PID 53 (0x0035)
AC3: Bitrate 128 Kbps Sample Rate 48 KHz
AC3: Mode complete main Coding 2/0 L, R
Language: eng
ATSC AC3 Descriptor
Program Number: 4 Get TV
Region 1 Rating: TV-PG Description:
PCR PID: 0x0041
Stream Type: 0x02 MPEG-2 Video PID 65 (0x0041)
MPEG Video: Bitrate 15.000 Mbps Resolution 720 x 480i
MPEG Video: Framerate 29.97 fps Aspect Ratio 4:3 Chroma Format 4:2:0
Stream Type: 0x81 AC-3 Audio PID 68 (0x0044)
Language: eng
ATSC AC3 Descriptor
Program Number: 5 JUSTICE
Region 1 Rating: TV-14-L-V Description:
PCR PID: 0x0051
Stream Type: 0x02 MPEG-2 Video PID 81 (0x0051)
Stream Type: 0x81 AC-3 Audio PID 84 (0x0054)
Language: eng
ATSC AC3 Descriptor
Chris C
ccrider2 is offline
post #7422 of 7422 Old 09-24-2017, 01:25 PM
nathill's Avatar
Quoted: 90 Post(s)
Liked: 54
10.1: CBS (1080i)
10.2: Fox (720p)
10.3: CW (720p)
10.4: Ion (480i)
From my HDHome run's reported bit rates (rounded off)....
4-1 CBS 1.7MB/s
10-1 CBS 1.0MB/s
10-2 .8MB/s
10-3 .4MB/s (reported as HD ---> really?)
10-4 .2MB/s
Trying to watch the Buccaneers-Vikings game on 10-2 (FOX-NFL), and the video is HORRIBLE.
Reminds me of the early days of digital television, "HD lite."
10-1 (CBS), the Colt's game, looks better, but nothing to write home about.
Looks like twenty frames a second.
Scrolling across the bottom is jagged.
Really bad deal for the poor folks receiving the signals from RF10..
Apparently there is a visual price to pay for squeezing too many bits into one TV channel.
nathill is offline
