Myrtle Beach, SC - HDTV - Page 68 - AVS | Home Theater Discussions And Reviews
post #2011 of 2039 Old 12-01-2014, 07:16 AM
Daryl L's Avatar
Originally Posted by bdfox18doe View Post
No, 43.4 MeTv is 16:9 Widescreen. As for 43.1 They should not be. Your receiver should be following the AFD code to throw it to 16:9 letterbox in a 4:3 frame. There is an exception with one or two local shows that are delivered to us stretched by the paying customer.
Hello Bob, long time. When I'm watching 43.4 MeTv my information bar tells me it's in 16 x 9 and I have my TV set at the 16 x 9 four SD material as it has been for quite a while (my television doesn't have auto aspect ratio for SD material). But as of lately all the shows on MeTV seem to be stretched and zoomed. For example, Saturday night I like to watch "Superman, Batman, Wonder Woman, Star Trek and the Svengoolie movies". All of them appeared zoomed and stretched to fill the screen. Yet my TV is set to 16 x 9 and your information bar showed us the signal as being 16 x 9. As I write this I'm looking at "Perry Mason" and the picture is not a 4 x 3 image with black bars on both sides. It is actually filling the screen. If I set my TV aspect ratio two 4 x 3 it adds the black bars for me but then the image looks squeeze a little bit horizontally like it is stretched vertically. If I set my TV back to 16 x 9 the image filled the screen but they do not look fat which means that it must be zoomed in cropping off the top and bottom a little from what I can tell. Sometimes I can pick up WRAZ Fox 50 out of Raleigh and they have MeTV on 50.2 and I was catching it one evening a couple days ago and I compared the image of theirs to yours. They broadcast a 4 x 3 picture and with my TV set to 16 x 9 to stretch it out to fill the screen they were showing slightly more picture information at the top and bottom than 43.4 is showing on my television. I'm not sure what's happening. I'm guessing it's the MeTV network doing this and not you. That was my assumption all along. I just wanted to confirm if anybody else was seeing what I was seeing.
Daryl L is offline
post #2012 of 2039 Old 12-01-2014, 07:56 AM
bdfox18doe's Avatar
Quoted: 128 Post(s)
Liked: 88
Thanks for the detailed update DL, I have asked Doug @ WFXB to take a close look at this, Standby.
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #2013 of 2039 Old 12-01-2014, 08:27 AM
Daryl L's Avatar
Thanks Bob! No rush. I was just curious.
Daryl L is offline
post #2014 of 2039 Old 12-01-2014, 01:58 PM
Daryl L's Avatar
Hello Bob,
Just checked 43.4 and looking at Adam 12 right now and they have the black sidebars on it again now. Looks like it's been corrected.
Daryl L is offline
post #2015 of 2039 Old 12-01-2014, 06:33 PM
jspENC's Avatar
Quoted: 48 Post(s)
I just checked out 43.4. It looks normal on one TV, and on another TV it has black bars when I put it on Wide mode. I don't see that on MeTV 10.2 or MeTV 7.3 - Atmosphere allowing good skip tonight is why I can see 43.4 and 10.2
jspENC is offline
post #2016 of 2039 Old 12-02-2014, 07:41 AM
Daryl L's Avatar
Hi jspENC,
On Fox 43.4 they are sending a 16 x 9 image so the TV should be set in a wide mode (16 x 9) and any material that has a 4 x 3 aspect ratio they add black bars to the side instead of stretching it out so is displayed in its original aspect ratio. On another Fox network out of Raleigh they send a 4 x 3 image for any material they broadcast that has a 4 x 3 aspect ratio is stretched to fill the screen so you have to set your television to the 4 x 3 mode so the TV does not stretch but adds black bars to the sides if you want to watch it in its original aspect ratio.
For a few days for some reason 43.4 was stretching there 4 x 3 material but yesterday it was corrected and now it is displaying in its original aspect ratio with black bars on the sides like it'd been doing before.
Daryl L is offline
post #2017 of 2039 Old 12-02-2014, 10:19 AM
jspENC's Avatar
Quoted: 48 Post(s)
Originally Posted by Daryl L View Post
Hi jspENC,
On Fox 43.3 they are sending a 16 x 9 image so the TV should be set in a wide mode (16 x 9) and any material that has a 4 x 3 aspect ratio they add black bars to the side instead of stretching it out so is displayed in its original aspect ratio. On another Fox network out of Raleigh they send a 4 x 3 image for any material they broadcast that has a 4 x 3 aspect ratio is stretched to fill the screen so you have to set your television to the 4 x 3 mode so the TV does not stretch but adds black bars to the sides if you want to watch it in its original aspect ratio.
For a few days for some reason 43.3 was stretching there 4 x 3 material but yesterday it was corrected and now it is displaying in its original aspect ratio with black bars on the sides like it'd been doing before.
Thanks Daryl, that explains it for me on aspect ratio. However, when I tune to 43.3, I see a weather station!
jspENC is offline
post #2018 of 2039 Old 12-02-2014, 10:31 AM
bdfox18doe's Avatar
Quoted: 128 Post(s)
Liked: 88
MeTv is 43.4, however 43.3 Wx is 16:9 as well, it is actually sourced/downconverted from WFXB's HD Wx system.
Bob
post #2019 of 2039 Old 12-02-2014, 12:55 PM
Daryl L's Avatar
My apologies guys! I was referring to 43.4 but I kept typing 43.3. I went back and edited my posts to reflect the correct channel number. Again sorry for the confusion. I'm getting old and senile now.
But anyway yes, 43.3 MeTV is now displayed in the proper aspect ratio as before.
Daryl L is offline
post #2020 of 2039 Old 12-14-2014, 08:14 PM
David-the-dtv-ma's Avatar
Originally Posted by cpalmer2k View Post
I'm coming to Myrtle Beach (the south end almost at Surfside) next month and know already the condo we are staying in has a horrid SD TV. I'm bringing along a decent sized portable TV with me since we enjoy sleeping with a TV on at night anyway. My question is will a portable antenna pick up the broadcast stations in that area? I'm assuming I need an amplified indoor antenna to even have a chance? Looking for some advice from those in the area. I'm guessing nothing would be available via QAM from TWC?
I am sure you will get a few digital tv channels with a digital tv or an analog tv with an dtv converter box; Because WMBF on rf ch 32 is just a few miles away from your location. But the other stations depend on how high [ Like ground level or 2nd floor] you are, what buildings are around you or are you like right on the ocean front & finally which side of the building you window is facing. I have seen some folks in on the ocean front with a window with a view down the south receive all the Charleston SC stations. On the other hand I have seen folks with a window facing North receive all of the Full power stations from Wilmington NC. But in both cases they had trouble getting the VHF stations from Florence for CBS for the MB area because the signal did not go through wall of the building
David-the-dtv-ma is offline
post #2021 of 2039 Old 12-15-2014, 01:13 PM
ee1993's Avatar
If your condo in on the TWC Hotel Loop, you will get only analog SD and no QAM. My folks have TWC phone and the lowest tear of basic TV locals in analog but clear QAM works to get all the local channels in HD.
ee1993 is offline
post #2022 of 2039 Old 12-15-2014, 05:31 PM
jspENC's Avatar
Quoted: 48 Post(s)
Wilmington FOX has Grit TV on 26.3 and Escape on 6.3 now; both are pretty good channels. I know Horry county and maybe Marion should be able to tune into these.
jspENC is offline
post #2023 of 2039 Old 01-05-2015, 08:21 PM
mvcg66b3r's Avatar
Quoted: 26 Post(s)
Liked: 1
Potential Sinclair subchannel shuffle in Florence-Myrtle Beach:
WPDE: 15.1 ABC (720p HD), 15.2 CW (720p HD), 15.3 CW Plus (480i SD), 15.4 Weather (480i SD)
WWMB (spun off): 21.1 ????
One person's craziness is another person's reality. - Tim Burton
mvcg66b3r is offline
post #2024 of 2039 Old 01-06-2015, 07:42 AM
Daryl L's Avatar
Where did this information come from? Interesting. What in the world can that leave 21.1 end up being? I certainly hope it's not MyNetworkTV, besides, WBTV 13.2 is that network during primetime hours (8PM-11PM). They have much of nothing worth watching to me. Maybe they'll be GritTv or CoziTv or both.
Daryl L is offline
post #2025 of 2039 Old 01-06-2015, 07:46 AM
mvcg66b3r's Avatar
Quoted: 26 Post(s)
Liked: 1
Where did this information come from? Interesting. What in the world can that leave 21.1 end up being? I certainly hope it's not MyNetworkTV. They have much of nothing worth watching to me. Maybe they'll be GritTv or CoziTv or both.
The posts I made here and on other threads are just pure speculation on just what might happen in these markets, with the FCC's crackdown on JSAs/SSAs and the impending incentive auction. Some of you may have been offended, and for that I apologize.
post #2026 of 2039 Old 01-06-2015, 11:51 AM
Daryl L's Avatar
Ahhh, gotcha. By the way, I myself was not offended, just curious.
Daryl L is offline
post #2027 of 2039 Old 03-30-2015, 06:50 PM
our Local non-profit tv cable/phone company is trying to scare folks stating " there is no such thing as free tv" to think they must pay to get tv signal now. What a big false statement. They say they must pay for $5.00 for each customer. Why do they expect their customers to pay to get the tv cable signal but the tv cable does not think they must no be required to pay to get the signal they get & then re sell it. It is great. they should be required to pay for it, if they are going to charge their customers to receive it.
post #2028 of 2039 Old 03-31-2015, 03:58 AM
Gary J's Avatar
Quoted: 179 Post(s)
Liked: 120
Post a reference that makes more sense.
Gary J is offline
post #2029 of 2039 Old 05-08-2015, 05:06 AM
cpalmer2k's Avatar
Quoted: 83 Post(s)
Just curious if anyone has any recommendation on an indoor antenna (amplified I imagine) that will work in the Myrtle Beach area? I'm going to be vacationing there in a few weeks and the condo we have reservations at has an HDTV, but no HD channels. It is fed by the in-house cable TV system. I was going to plug in a small antenna and try my luck picking up some of the local stations at least.
cpalmer2k is online now
post #2030 of 2039 Old 05-08-2015, 08:58 AM
tylerSC's Avatar
Quoted: 361 Post(s)
Liked: 119
Just curious if anyone has any recommendation on an indoor antenna (amplified I imagine) that will work in the Myrtle Beach area? I'm going to be vacationing there in a few weeks and the condo we have in has an HDTV, but no HD channels. I was going to plug in a small antenna and try my luck picking up some of the local stations at least.
Try a Terk HDTVa. I think it is a bit better than the amplified rabbit ears and loop. And probably better than the Mohu Leaf or Flatwave variety. Now if you wanted to spend a bit more, you could try a Clearstream 2V and add a Channel Master distribution amp or Winegard LNA100 amp. But someone locally would have more experienced advice.
tylerSC is offline
post #2031 of 2039 Old 05-08-2015, 09:18 AM
cpalmer2k's Avatar
Quoted: 83 Post(s)
I honestly was hoping to find someone who could give some feedback on the Leaf 50 (or Leaf 50 Curve), the models with the amplifier built in. Those would be much easier to travel with than the Terk model would. Keep in mind this is a Condo, so my options are very, very limited. I realize the Myrtle Beach market is a difficult one, however, because it is right between 3 DMA's, but really not close to the towers of any of them truthfully. Not like we are in the upstate at least.
post #2032 of 2039 Old 05-08-2015, 09:39 AM
bdfox18doe's Avatar
Quoted: 128 Post(s)
Liked: 88
Yea. Generic recommendations from those with no area experience usually aren't much good.
Plot the address at tvfool and let us see it here. Or the Zip code on RabbitEars will give you a
general idea based on direction. Most transmitters are a ways away. WFXB's is in Mullins..
Bob
post #2033 of 2039 Old 05-08-2015, 10:10 AM
cpalmer2k's Avatar
Quoted: 83 Post(s)
Here is the DTV.gov listing I pulled. Most fall in the "Yellow" range. TVFool is also attached.
ID:	706530   Click image for larger version
post #2034 of 2039 Old 05-08-2015, 10:37 AM
bdfox18doe's Avatar
Quoted: 128 Post(s)
Liked: 88
A big part of the question is how high are you and what direction can you see, like NW. Id' take a length of RG6 so you can move the antenna around quite a bit. I'd recommend a Silver Sensor, but you can't get those anymore.
Bob
post #2035 of 2039 Old 05-09-2015, 11:25 AM
tylerSC's Avatar
Quoted: 361 Post(s)
Liked: 119
Like I said, someone locally would have the best advice. But you may luck out with a Mohu style antenna, but they can be somewhat gimmicky and overpriced. But they seem to work well for some folks depending upon location. Although the amped version may sometimes be problematic. And a real antenna used indoors may often perform better, such as a DB2 or Clearstream 2V. Right now MCM has their DB2 antenna from Stellar Labs priced at $8.99 with the source code from their home page. But you may have to add a set of rabbit ears for VHF concerns. But I certainly understand the convenience factor with the Mohu, which you could always try and return to Walmart. Although Solid Signal has some of their Blade versions lower priced, as well as the Channel Master unamped version for $9.99 on their website. I would be curious to hear what works.
tylerSC is offline
post #2036 of 2039 Old 05-09-2015, 11:30 AM
tylerSC's Avatar
Quoted: 361 Post(s)
Liked: 119
Also the Terk HDTVa uses a similar Silver Sensor design for UHF, and adds rabbit ears for VHF. I believe you can remove the inline amp if not needed, or you can still possibly locate the HDTVi unamped version somewhere. But that original Silver Sensor sold under the Zenith and Phillips brands always got good reviews.
tylerSC is offline
post #2037 of 2039 Old Yesterday, 07:06 PM
cpalmer2k's Avatar
Quoted: 83 Post(s)
I'm not sure about the floor, I tried to find out today but it could be one of three. I did ask that we get one of the units that are facing "North". We stay there every year, and have been in 3 different units that they rent out.
I'm considering just taking my TiVo Roamio OTA model and hooking it up to the cable line and scanning for QAM channels. The condos get the "extended" basic lineup, not the typical "hotel" channels. Does Time Warner leave QAM clear there, or are they encrypted?
post #2038 of 2039 Old Today, 04:08 AM
bdfox18doe's Avatar
Quoted: 128 Post(s)
Liked: 88
Should still be some clear QAM's for locals from what I have seen.
Bob
post #2039 of 2039 Old Today, 04:20 AM
Gary J's Avatar
Quoted: 179 Post(s)
Liked: 120
10-12 clear QAM here in Pawleys Island TWC. Also on Roku so why mess with antenna? Don't know about other than TWC.
Gary J is offline
