Pittsburgh, PA - OTA - Page 143 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 03-02-2010, 11:58 AM
upzdayzm's Avatar
This coming Saturday morning, Mar.6th, might be good time for Tropo's in Western Pa.
"If you want total security,go to prison,there your fed,clothed,given medical care and so on The only thing lacking,,,,,,,,is FREEDOM " Dwight D.Eisenhower
upzdayzm is offline
Old 03-02-2010, 12:51 PM
firemantom26's Avatar
firemantom26 is offline
Old 03-02-2010, 02:29 PM
dmorrison's Avatar
Originally Posted by WB3LEQ View Post
Hey Dave Morrison,
Any updates on when the WPXI repeater will be up and running in Uniontown? I know the weather conditions up in the mountains will be causing delays. It would be nice to see some programming from you folks again. I'm also hoping somebody will focus an antenna lobe towards eastern Greene County.
BobS
No info for you yet. I'll let you all know as I learn more.
Dave
Anytime you have a 50-50 chance of getting something right, there's a 90% probability you'll get it wrong.
dmorrison is offline
Old 03-02-2010, 02:31 PM
dmorrison's Avatar
Originally Posted by pghturbo88 View Post
But it's been nice catching some rays from their new radar that has "revolutionized" weather forecasting!
Research said that our viewers wanted that warm, fuzzy feeling - and to have their microwave popcorn pop on the counter .
Dave
Old 03-07-2010, 10:43 PM
JK77's Avatar
PSIP says "CMG-TV" but the program guide only shows "DTV Program" like 16-1 used to show in theirs.
JK77 is online now
Old 03-13-2010, 09:45 PM
benji15301's Avatar
For Dave Kasparek http://tvdxexpo.com/dunne5.html is a DX log I happened to accidentally come across.
Before we work on artificial intelligence why don't we do something about natural stupidity?
benji15301 is offline
Old 03-14-2010, 12:49 AM
rpesq's Avatar
FYI - The channel guide info for 11.2 RTV has been wrong for the past few days (evenings?)
rpesq is offline
Old 03-15-2010, 01:07 PM
trapsh00ter's Avatar
I'm using a basic RCA set top antenna to try and access WJAC 6 out of Johnstown, I manual tune the receiver and get a weak signal not enough to lock it in. I think the problem is that the house I'm in has aluminum siding(had issues with wifi too) any ideas on getting a better signal? Also I'm getting a weak signal from WTAE as well so I know the antenna is good, seeing as to how I'm in the Coral area of Indiana county. I'm using a 30db amp and have attempted a parabolic reflector with no luck, the reflector actually seems to decrease signal from both channels.
trapsh00ter is offline
Old 03-15-2010, 02:26 PM
ProjectSHO89's Avatar
Quoted: 271 Post(s)
Liked: 129
If the skin of the house is metal, you have to get the antenna outside of the envelope. RF signals cannot penetrate metal.
You might get lucky and get some signal trough a glass window, but you still have to avoid metal window screens and low-E glass with metallic films.
The biggest amplifier in the world cannot make up for a signal that doesn't arrive at the antenna.
ProjectSHO89 is offline
Old 03-22-2010, 12:27 PM
Ok so I put the antenna outside, I now have a world of new channels opened up, however I still get weak signals too weak to capture any streams. I have the 30db amp hooked up, what if anything can I do to get these signals to where I can capture the streams to get a lock?
Old 03-22-2010, 04:18 PM
Dave Loudin's Avatar
The next thing to do is to get a proper antenna. First, go to tvfool.com, select the "start maps" option, put in your address, then click the map this button. Zoom in on the map and drag the receive location over your location if it's not there already. Adjust the antenna height to what you will use, then click on the "make radar plot" button. Share your results by posting the URL as instructed and we'll take a crack at suggesting something that will work.
Dave Loudin is offline
Old 03-22-2010, 05:32 PM
Ok so I plotted out my address which can be found here, http://www.tvfool.com/?option=com_wr...b7c809e0cd1a55 from what I can see an attic mounted antenna is sufficient, however a roof mount may be better. If this is the case could the roof mount be mounted on a tripod and still achieve good results? Reason I ask is I have an omnidirectional dish that can be adapted to a tripod, I've never hooked it up due to not having the time to do so
Old 03-22-2010, 09:11 PM
Trip in VA's Avatar
Quoted: 703 Post(s)
Liked: 198
Send a message via AIM to Trip in VA
Anyone seeing WEMW-LD 19 on the air in the Greensburg area? Should be repeating WBGN-CD. Not sure how it's mapping.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
Old 03-24-2010, 10:11 AM
dmorrison's Avatar
What do you see when you take the amp out of the line? Any improvement? Degradation? Sometimes these amps cause more harm than good to a digital signal.
Dave Morrison
WPXI Engineering
Old 03-24-2010, 01:34 PM
Dave Morrison
WPXI Engineering
Actually I never tried putting the antenna directly into line with the converter, I'll have to look at it to see what we get
Old 03-25-2010, 05:19 PM
SamVin's Avatar
Does anyone know what happened to the sub-channels on WBGN [59-x, UHF 16]?
Last night as I was tuning past 59-1 I couldn't go to 59-2, etc. as it kept throwing me back to 59-1. Then as I switched to the number pad to select the channel I noticed that hitting "5" didn't present me with a listing of any channels except for 53-1 and 59-1.
And as of this evening they (59-2, 59-3, 59-4) haven't comeback.
So did something happen that the station is unaware of; or was this a planned removal of the subs?
By the way losing their subs has improved my reception of the main WBGN signal.
SamVin is offline
Old 03-25-2010, 07:24 PM
Saulinpa's Avatar
Try re-scanning. I still get 59-2 and 59-3 but 59-4 (STUFF) disappeared.
Saulinpa is offline
Old 03-25-2010, 07:39 PM
- Trip
Trip, nothing showing here..................
Tom
Old 03-28-2010, 06:40 PM
JK77's Avatar
No, I have been checking RF 19 daily to see if it's on the air. I'm not far from Greensburg, so their digital signal should reach me.
JK77 is online now
Old 03-30-2010, 12:22 PM
Dave Morrison
WPXI Engineering
Ok so I took the amp out of the equation, and had no improvement, so I added a length of cable and got the antenna up another 3 ft or so and boom instant reception, however I have some minor tearing but am getting good signal on 2, 4, 6, and 53. I suppose if I get it up a few more feet we'll be in great shape. Why didn't I think of that sooner? I guess it's one of those so simple we forget to try things
Old 04-05-2010, 09:17 AM
wallybarthman's Avatar
The short answer is - the higher the better
wallybarthman is offline
Old 04-09-2010, 11:26 AM
ChuckZ's Avatar
My question is for both Daves:
What hardware encoders did you guys go with when you made the move to HD?
I'm guessing WPXI upgraded to something more recent with the new studio and all.
Did you guys at WTAE keep your old MPEG-2 hardware encoder or did you have to upgrade (if it was standard definition only)?
Did you guys do shoot outs between brands to determine the best ones or do you go by reputation or whatever consultants tell you?
I'm curious to know because there seems to be a good deal of competition and innovation in the broadcast encoder market. Developers can sell more of these than offline software encoders and see a better ROI.
ChuckZ is offline
Old 04-10-2010, 10:40 AM
dmorrison's Avatar
Higher was always better when receiving analog. In digital land, higher is not necessarily better. You simply have to find the "sweet spot".
Dave
Old 04-14-2010, 10:06 AM
Sammer's Avatar
With Cox (WPXI), Hearst (WTAE), and Sinclair (WPGH, WPMY) all members of the Open Mobile Video Coalition when are we going to hear something about ATSC M/H in Pittsburgh? With the FCC taking a use it or lose it attitude toward OTA UHF spectrum it's not like the stations have any time to waste.
Sammer is offline
Old 04-14-2010, 01:24 PM
Quoted: 271 Post(s)
Liked: 129
Dave
It would be more accurate to say that "Higher is almost always better". Digital is no different than analog in this regard. UHF signals still layer more than VHF (since many old analog stations were on VHF but are now on UHF) and you're still looking for the strongest RF field with the least amount of reflected or distorted signal.
Because of the greater preponderance of digital on UHF relative to VHF, you really have to pay more attention to the idiosyncrasies of UHF propagation and reception than you used to.
Old 04-14-2010, 09:08 PM
lutznct1's Avatar
Hey Dave Morrison,
Any updates on when the WPXI repeater in New Castle on RF 33 will be put up? I'm going to guess you'll have that get that up first due to WDLI future interference with RF 48. Just curious.
lutznct1 is offline
Old 04-15-2010, 06:49 PM
Cabin_Fever's Avatar
While we're talking WPXI repeaters, any news about when the Uniontown repeater will be up? Thanks.
Cabin_Fever is offline
Old 04-23-2010, 08:13 AM
dmorrison's Avatar
Yup! Yesterday (4/22) at 7:30pm. You'll find it on channel 23 and it is mapped to 11.1 and 11.2. Happy viewing!
Old 04-23-2010, 03:37 PM
WB3LEQ's Avatar
Thank you Dave! Nice to have channel 11 back in eastern Greene County. Again, THANKS and WELL DONE!!!
Bob
WB3LEQ is offline
Old 04-24-2010, 06:43 PM
larrybpsu's Avatar
Sweet!!!!!!!!!!!
Finally, I have a rock solid signal on 11 from McClellandtown! Now I can really enjoy the RTV channel.
Now, if Only QED would do the same, I'd be really happy.
larrybpsu is offline
