Pittsburgh, PA - OTA - Page 154 - AVS Forum | Home Theater Discussions And Reviews
post #4591 of 4617 Old 07-20-2015, 07:23 AM
pittsoccer33's Avatar
Quoted: 561 Post(s)
Liked: 388
they had vintage grand prix stuff on yesterday.
i was a little bit bummed, since i just moved and havent gotten my OTA stuff set up yet.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is online now
post #4592 of 4617 Old 07-30-2015, 06:31 PM
Liked: 0
Thank you for the great resource and allowing me to be her.
I am just north of Kittanning. (16218 Zip code) I am at a pretty high elevation
I recently cut the cord with Direct and trying to figure out some idiosyncracies.
I have a directional antenna without a rotor. I turn the mast by hand if I have to.
Also have a Channel Master booster
As best I can tell, I'm pointing around 210-215 approximately.
I get a lot of stations but not WPXI or WTAE.
I realize that WTAE is a bit in a different direction but I get a lot of stations that have weaker signals from different directions at that setting.
I get some Youngstown, Steubenville and Johnstown stations and a couple I don't know where from recently.
Specifically, 60.1, 60.2 and 60.3.
When I do a channel scan, I got 30 stations last night but not all come in.
I just get a blue screen.
Mostly on the Ion stations (16.1-16.5) and a couple of the Youngstown stations.
Enjoying the experience because there's a lot of old programming.
I would like to get WPXI and WTAE.
Any suggestions woulf be greatly appreciated.
Thank you
blackstonecap is offline
post #4593 of 4617 Old 07-31-2015, 06:27 AM
Quoted: 561 Post(s)
Liked: 388
I have a few coworkers from out your way that commute into downtown daily. I think they're all nuts - I'm 4 miles from my office and think it takes me too long
WTAE reception just seems to be terrible. Their main tower is down in the Mon Valley, and they have a repeater on WQED's tower at the top of Pitt's campus in Oakland. Can you get 4.3 at all?
My place literally just a mile down Center Ave has spotty reception.
post #4594 of 4617 Old 07-31-2015, 06:46 AM
Liked: 0
Thanks, pittsoccer for the reply.
I, too, think your coworkers may be nuts to make that drive..
I can get nothing from any of the 4+ or 11+ stations.
If I do a channel scan, it skips right over those.
Other stations don't come in but show up as a selection with a blue screen.
16s, for example.
WPXI is a real puzzle to me.
It is in the same general direction that my antenna is pointing and has a strong signal
Another thing that happens is there are times I can hardly pick up anything.
I do a channel scan and it finds somewhere between 20-30.
Weather doesn't seem to be a factor
post #4595 of 4617 Old 07-31-2015, 10:51 AM
Mr.G's Avatar
Quoted: 416 Post(s)
Liked: 207
16s, for example.
If you look at your TV Fool report (based on your zip code) it would seem you are fortunate to get what you do.
http://www.tvfool.com/?option=com_wr...8e03892231cd0f
WPXI is to your southeast while the bulk of the other stations you receive are to the southwest.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #4596 of 4617 Old 07-31-2015, 11:14 AM
Liked: 0
Thanks, Mr. G.
I was using Antennapoint
But, looking at TVFool, KDKA is at 217 and WPXI is 214 from true north
I pick up WWCP, for example, which is at 155 (same direction as WTAE) but it has a weak signal.
I also get WFMJ And WKBN out of Youngstown at 280 (approx.) and WJAC at 139.
All of these without changing my antenna direction.
These are the things that befuddle me.
I'n a techno-dunce if it didn't show
post #4597 of 4617 Old 07-31-2015, 01:24 PM
Trip in VA's Avatar
Quoted: 351 Post(s)
Liked: 111
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
Use TVFool with your specific location (not just zip code) and post the resulting bolded link here (you'll need 5 posts first, I think) so people can better help you.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #4598 of 4617 Old 07-31-2015, 02:22 PM
Liked: 0
Thank you, Trip in Va.
Hate to spam the board
post #4599 of 4617 Old 07-31-2015, 02:28 PM
Liked: 0
Sorry but this is #5
Next pone has the link.
post #4600 of 4617 Old 07-31-2015, 02:29 PM
Liked: 0
post #4601 of 4617 Old 08-11-2015, 02:44 PM
Liked: 0
I seem to need to run a channel search daily and get different results with searches only minutes apart.
Last evening, I couldn't get WJAC which always comes in regardless of the antenna direction.
I still have not been able to pick up WPXI or WTAE
post #4602 of 4617 Old 08-12-2015, 07:24 AM
Liked: 0
What is the difference in station designations DT, TV and CD, please?
post #4603 of 4617 Old 08-12-2015, 07:54 AM
Quoted: 561 Post(s)
Liked: 388
https://en.wikipedia.org/wiki/List_o...tation_classes
All US digital stations received a -DT suffix during the analog-to-digital transition. At analog shutdown, the FCC assigned to each digital station the call sign its associated analog station had used. (with a -TV suffix if the analog station had this suffix, without the -TV suffix if the analog station didn't have it). Stations could optionally choose to keep the -DT suffix. Most stations did not keep the -DT suffix.
For US analog stations, the -TV suffix was required if there was a radio station with the same three- or four-letter callsign. Stations not required to use the -TV suffix may optionally request it if desired.
Class-A stations (US) (suffix: -CA or -CD for digital class A):
VHF (2-13): 3 kW analog video; 3 kW digital
UHF (14-69): 150 kW analog video; 15 kW digital
The class-A television class is a variant of LPTV created in 2000 by the FCC to allocate and protect some low-power affiliates. Class-A stations are still low-power, but are protected from RF interference and from having to change channel should a full-service station request that channel.[10]
Additionally, class-A stations, LPTV stations, and translators are the only stations currently authorized to broadcast both analog and digital signals, unlike full-power stations which must broadcast a digital signal only.
post #4604 of 4617 Old 08-12-2015, 08:02 AM
Liked: 0
Thank you for that, pittsoccer33.
You wouldn't happen to have any input on my main issue above would you?
post #4605 of 4617 Old 08-13-2015, 05:57 AM
PA_MainyYak's Avatar
Quoted: 18 Post(s)
Digital reception can be challenging. From your description of antenna system and your TV Fool report, you seem to be pointing in the direction of your most important signals.
My suggestion is rather than doing a full channel scan, try manually tuning each individual RF channel. For example, for WPXI (11.1, 11.2, 11.3), you would input 48 on your tuner. Check your TV Fool report for the RF channel numbers. Once your TV locks in a channel, try another (KDKA 25, WPGH 43, etc.). Some stations use multiple RF channels to better cover their service area. As previously mentioned, WTAE's main RF channel is 51, but from your location, the transmitter at channel 22 might be easier to lock in.
There are some other things to try, but this is an essential first step. Good luck.
"One of the few good things about modern times: If you die horribly on television, you will not have died in vain. You will have entertained us."
- Kurt Vonnegut
-0-
PA_MainyYak is online now
post #4606 of 4617 Old 08-13-2015, 06:01 AM
Liked: 0
Thanks for the suggestions, Pa_MainyYak.
I'll give that a try.
Do I do that in the channel search function or just on regular TV?
post #4607 of 4617 Old 08-14-2015, 06:59 AM
Quoted: 18 Post(s)
Use your tuner.
- Kurt Vonnegut
-0-
post #4608 of 4617 Old 08-14-2015, 07:07 AM
Liked: 0
I tried that and it just went to the next higher station.
For Example, when I entered 48 (for WPXI) it went to 53
I, also, tried "11" but it just went to 13.
post #4609 of 4617 Old 08-25-2015, 09:24 AM
Liked: 0
WIIC-rf/31, will become an affiliate of BOUNCE TV.The station is not on the air yet. Also,WPNT may be adding a sci-fi themed sub-channel this fall.
elvintongue is offline
post #4610 of 4617 Old 08-25-2015, 10:05 AM
Quoted: 561 Post(s)
Liked: 388
I've pretty much come to the conclusion all the sub channels (except MeTV - I like recording old movies on Svengoolie) are junk. They mostly all distort the aspect ratios and the bitrates are way too low for any screen larger than 24" or so
post #4611 of 4617 Old 10-09-2015, 08:46 AM
Liked: 0
WPNT,will add a sub-channel called COMET TV,onOCTOBER 31st.
post #4612 of 4617 Old 10-09-2015, 04:35 PM
pacofortacos's Avatar
What model antenna and amp are you using? Also where is it located and what coax are you using?
I am a little closer than you and get all of them. FYI channel 9 mirrors 11 for most programming if you can get it.
Thank you
pacofortacos is offline
post #4613 of 4617 Old 10-31-2015, 09:56 PM
JK77's Avatar
Comet Comes to WPNT
Comet is now on the air at WPNT-22.3, and the duplicate GetTV on 22.4, that was broadcasting while Comet was just color bars the past few days, has been deleted.
I wondered why they skipped over .2, thinking that they are just keeping it consistent across all of their stations since it seems to be on the third channel on a lot of them. There is a second channel in the mux that I found with TSReader, which is listed as "ASN" in the PSIP. It must be a temporary feed for their American Sports Network to air games that were originally aired on GetTV.
JK77 is offline
post #4614 of 4617 Old 11-12-2015, 08:06 PM
RedPenguin2's Avatar
Quoted: 17 Post(s)
I am just seeing if there is any folks in and around Uniontown that have Atlantic Broadband.
I am curious how Atlantic Broadband does traps/filters in the area.
My area of Johnstown is converting to digital and we have two types of analog traps:
Internet Only - Ch 76+ only allowed
Limited Basic w or w/o Internet - 2-22 & 76+
Of course Value+ gets no trap at all.
I'm curious since ABB leaves Limited Basic still in analog or at least locals, how do they handle the analog stations because one of the advantages to go digital is to remove all traps. Would they only use traps for Internet Only customers?
I'm a radio scanner/geek type guy and I'm curious how this will be handled but nobody seems to know and I figured since Uniontown is already converted, folks in that area would have to know.
My Technological Website - http://www.thethreetechamigos.net
RedPenguin2 is offline
post #4615 of 4617 Old 11-27-2015, 09:19 AM
Liked: 0
WPGH, will add ANTENNA TV as a sub-channel on JANUARY 1. GET TV will move to WPNT.
post #4616 of 4617 Old 12-07-2015, 10:08 PM
JK77's Avatar
It's already on 53.2 with the PSIP changed to "Ant TV."
This explains why GetTV was simulcasting on 22.4 along with 53.2 off and on since Comet launched.
JK77 is offline
post #4617 of 4617 Old Today, 09:58 PM
raynist's Avatar
Quoted: 639 Post(s)
Liked: 625
Not sure if any of you are into home theater also but here is a thread about trying to get a get together going in Pittsburgh. Feel free to drop in if interested.
Any interest in a Pittsburgh area meet up?
raynist is online now
