Los Angeles, CA - OTA - Page 321 - AVS Forum
 36Likes
Old 10-06-2014, 12:16 AM
mkpl's Avatar
I'm having trouble with 11 and 13 this Sunday evening in south Orange County. Anyone else seeing this?
mkpl is offline
Old 10-06-2014, 07:31 AM
HarrisonS's Avatar
Liked: 24
I was not specifically watching those channels Sunday night, but 11 and 13 have always been stable for me. Are you using an indoor antenna?
HarrisonS is online now
Old 10-06-2014, 08:22 AM
mkpl's Avatar
I have a CM4228 in the attic. Every now and then 11 and 13 have issues, the other VHF signals seem fine. This morning they look ok again.
mkpl is offline
Old 10-08-2014, 08:41 AM
HarrisonS's Avatar
Liked: 24
If the problem persists, and if the reception of 11 and 13 is important to you, you might try adding a specialized high-band VHF antenna like the Winegard YA-1713.
Old 11-17-2014, 07:12 PM
Liked: 3
Hey all,
I came across this site while looking for answers as to why my reception is what it is. I'm located in Echo Park on the side of the ridge outside of Elysian Park about halfway down, so my LOS situation ain't so great. I believe I have the RCA 715 antenna on my roof using the mount used for the DirecTV dish when I told them where to put it when I reduced my service to basically nothing so I could just have HBO.
I've been having problems recently with 2, 7, 11 (sometimes), 13, and the PBS stations in the 50's. I've read here that some people have better luck with indoor rabbit ears, so I was wondering if I wouldn't need to go bigger and better outside since obtaining LOS is a pipe dream. Also, I've been using this site (antennawebDOTorg) as a guide when aiming the antenna.
It's almost like spinning a wheel sometimes as to what channels I'll get and both my girl and I are getting frustrated, but putting the dish back up isn't an option as they are basically raping us with the cost.
I have two TV's in the house and one uses a cheapo Radio Shack HD rabbit ears antenna that seems to pretty good reception when the one on the roof fails us. It's almost like what channels we can't get on one we can get on the other and vice versa. We supplement with two Apple TVs as we can ABC and FOX (with our parent's ID and passwords for their cable), but we'd like to just watch TV without wearing foil hats and doing yoga poses to get the stations to stay up.
Any suggestions for antennas (inside or out), amplifiers, etc. etc.?
deckard_b26354 is offline
Old 11-17-2014, 07:14 PM
phildaant's Avatar
Quoted: 401 Post(s)
Liked: 128
Arrow
Originally Posted by deckard_b26354 View Post
Hey all,
I came across this site while looking for answers as to why my reception is what it is. I'm located in Echo Park on the side of the ridge outside of Elysian Park about halfway down, so my LOS situation ain't so great. I believe I have the RCA 715 antenna on my roof ...
You will want to provide the details from http://www.tvfool.com/ (better than AntennaWeb).
phildaant is online now
Old 11-17-2014, 07:16 PM
Liked: 3
Thanks! I'll check it out. That other site seemed a bit to much like a used car salesman.
phildaant likes this.
Old 11-17-2014, 07:18 PM
phildaant's Avatar
Quoted: 401 Post(s)
Liked: 128
Yeah, IIRC. It existed before TVfool.
Old 11-17-2014, 08:03 PM
Liked: 3
Old 11-18-2014, 06:13 AM
ProjectSHO89's Avatar
Quoted: 83 Post(s)
Liked: 74
Your TVFool plot says this is an easy slam dunk, but your describe your LOS as a lost cause. Both cannot be correct although it must be noted that the TVFool simulation can not account for local obstacles such as buildings or trees.
Use the interactive maps feature and the overhead (not the 45° view) satellite view to precisely pinpoint your location, and run a new report at the antenna's estimated height above ground. Post that one up and see if it's different.
ProjectSHO89 is offline
Old 11-18-2014, 10:00 AM
Liked: 3
Well as I had mentioned, I'm on the slope of a hill that, while it is a residential neighborhood, does have many trees and homes in the way to the transmitters. They aren't directly blocking the antenna, but that is my line of sight situation.
We are in a single floor house and as it turns out, the antenna is directly below where we sit and the TV is directly across from us at about 8' away. This morning we could watch KCBS (2) for a short time and then it would start cutting out. One of us would stand and walk away and it was fine.
We do have a pretty long run of coax that is not a single strand (about 75-100 ft.), so sometimes I start thinking it's that--but then all of a sudden one day the signal will be solid without any yoga moves on our (or our pets') part. Then I start thinking it's the antenna and I should make it higher or get a larger antenna. But as I said before, with our other TV, KCBS usually comes in good with just rabbit ears. And then the frustration moves in…
Old 11-18-2014, 10:03 AM
phildaant's Avatar
Quoted: 401 Post(s)
Liked: 128
Have you tried exploring all over your home to find a sweet spot with the antenna(s/e)? Maybe you can get lucky.
Old 11-18-2014, 10:40 AM
Liked: 3
Here's the maps result: http://www.tvfool.com/?option=com_wr...d24325b45238b0
It's identical. Looking at the overlays…while there are smudges of purple around my location (about 1/8 mile way), I'm in the green (almost with the slightest hint of purple tinge--but it's hard to tell). After reading more of the FAQ for this, perhaps I need to look at my cable run first. I do have at least one splice that I can recall. Could that be the culprit? I also bought a powered amp that basically looks like a splitter with an AC adapter. I suppose I should look at something a bit more robust--maybe it's just too cheap in build quality to do any good (or perhaps being detrimental).
Old 11-19-2014, 10:00 AM
retiredengineer's Avatar
If you are close to the 5 freeway, that may be the cause of the problems you are seeing. Reflections off of cars can briefly mess up your reception. It could be your outside antenna can see the reflections but the indoor does not. The only remedy you can try is to move your outside antenna to different locations. I would not use a bigger antenna since your signals are already strong.
retiredengineer is offline
Old 11-19-2014, 12:37 PM
ADTech's Avatar
Quoted: 29 Post(s)
Liked: 36
Actually, a "bigger", "stronger", "longer-range", etc antenna would provide a significant opportunity for improved reception.
Such antennas are going to be more directional at the expense of increased physical size (length and # of elements, usually). This will do several good things simultaneously, like improve the signal power of the desired signals, reject undesired signals (noise) from other directions, and improve the ratio between the desired signal and other noise sources. There is no danger of overloading the system from an antenna alone since the signal powers in the forecast do not take into account the transmitting antenna tilt or its vertical (elevation) pattern. Most likely, the main lobe of the transmitting antennas' signals is still well overhead in this location. Installing such an antenna so it's shielded from reflections from the interstate would help reduce those dynamic multipath problems.
It has been my observation and experience when using TVFool's simulator, that, for locations immediately on the back side of a hill, the estimates are usually way too optimistic.
Tech support for Antennas Direct
ADTech is offline
Old 11-19-2014, 12:45 PM
phildaant's Avatar
Quoted: 401 Post(s)
Liked: 128
I also noticed to try various positions, heights, angles, locations, etc. for the antenna. Just be sure you can return it from the stores if bought.
Old 12-17-2014, 08:14 AM
lotto_pi's Avatar
KFLA 8.1 FilmOnTV is blank the past couple days. Still shows signal, though, and I'm still getting 8.3 Retro TV.
And a rescan last night found 182 (!) channels. Wow.
_
Neil
lotto_pi is offline
Old 12-18-2014, 10:39 AM
HarrisonS's Avatar
Liked: 24
_
Neil
I noticed that too. Also I noticed recently that they had begun to broadcast unstretched video on 8.1. That was another positive sign that the trend is in the right direction for SD broadcasts.
Generally, I can only receive KFLA during overcast weather, when propagation conditions are more favorable for non-LOS local stations. KFLA often disappears for weeks at a time during warm sunny weather. At such times I occasionally even lose some stronger non-LOS stations, like KCLS and even KCET. This is most likely to happen in the early evening hours, when reception can suddenly drop out completely in the middle of a program.
Old 12-18-2014, 12:55 PM
phildaant's Avatar
Quoted: 401 Post(s)
Liked: 128
_
Neil
Wow, 182. What type of setup and where is this? What channels do you see? From LA, SD, SB, etc.? The highest I ever went was like 117 in my old place.
Old Today, 06:43 AM
jmonier's Avatar
182 IS a lot. I just did a scan and with LOS to Mt. Wilson and an outside high gain antenna 30' above ground level I got 176 in Torrance.
jmonier is offline
Old Today, 07:33 AM
Quoted: 83 Post(s)
Liked: 74
Since LA has several broadcasters that operate multiple transmitters, each showing the same 5-15 subchannels, it's really not much of a stretch to get such channel counts during a scan if you can pick up several of those individual signals.
Old Today, 09:36 AM
phildaant's Avatar
Quoted: 401 Post(s)
Liked: 128
Question
Did the stations add many more since 9/15/2013 since I last scanned at my old place (can't get many now in my new place that is blocked)?
