Los Angeles, CA - OTA - Page 322 - AVS | Home Theater Discussions And Reviews
 45Likes
post #9631 of 9643 Old 01-22-2015, 05:23 PM
lnong's Avatar
I recently cut the Cox cable cord, and have been looking for a good digital HD indoor antenna so that I can just watch the OTA channels, but I'm running out of choices. I've tried several different ones, including ones that have good reviews. With all of them, I can get CBS (2), NBC (4) and KTLA (5). With none of them, except for the Winegard antennas, can I get ABC (7), KCAL (9), FOX (11) and KCOP (13). With the Winegards, I SOMETIMES can get ABC (7), KCAL (9), FOX (11) and KCOP (13) but only like one at a time, depending where I place the antenna around the room. Very sensitive. And on top of that the signal is very weak. Sometimes the I see pictures for a second or two and then the signal breaks apart. Very sad and frustrating.
The indoor HD antennas I've tried:
- RadioShack brand amped
- RCA brand nonAmped
- Winegard FL5500A
- Winegard FL55YR
- Some $90 amped antenna from RCA
I ended up having to return all of them. If any of you guys live in Irvine and use an indoor HD antenna that can pick up all the local OTA channels I've listed above, please share! I'm fine with any style of antenna (flat wave, rabbit ears, etc) as long as it's for indoors.
lnong is online now
post #9632 of 9643 Old 01-22-2015, 05:28 PM
phildaant's Avatar
Quoted: 431 Post(s)
Liked: 134
Arrow
- Winegard FL5500A
- Winegard FL55YR
Indoor won't work for that far. Also, did you try using http://www.tvfool.com/ ?
phildaant is online now
post #9633 of 9643 Old 01-22-2015, 05:32 PM
lnong's Avatar
I just did. Based on the TV signal report, all those channels I listed are in the green area, meaning I should be able to pick them up with an indoor set-top antenna..
Here's the TVFool Report:
lnong is online now
post #9634 of 9643 Old 01-22-2015, 05:34 PM
SledgeHammer's Avatar
Quoted: 55 Post(s)
Liked: 39
- Winegard FL5500A
- Winegard FL55YR
I live in Irvine and pull all the OTAs. I have a "roof" antenna, but its in my attic. Its not amped, but it is probably like 3' x 2'. I want to say its a channel master... something like this:
http://www.solidsignal.com/pview.asp...-(CM4221)&c=TV Antennas&sku=
I don't think its that particular model (its a bit smaller), but its the similiar style directional antenna. Its not even mounted on a pole in my attic... just sloppily propped up against a roof rafter in the correct direction and I pull all channels.
Also, I'm using the DirecTV AM21 tuner for OTA and thats known to be a weak tuner.
SledgeHammer is online now
post #9635 of 9643 Old 01-23-2015, 04:04 PM
holl_ands's Avatar
Quoted: 96 Post(s)
Liked: 78
- Winegard FL5500A
- Winegard FL55YR
The channels you can't receive are in the Hi-VHF Band (REAL Ch7-13) and ALL of the Indoor Antennas you listed are UHF Antennas that are NOT specifically designed for Hi-VHF Band.
BTW: The channel numbers you cite are the VIRTUAL Channel numbers (end in a decimal)...we need to discuss REAL Channel numbers to know what kind of Antenna you need. We ALSO need you to enter you location into www.tvfool.com and copy/paste the Results URL (Webaddress at top of Browser) into a post so we can see what kind of signal strengths you have and can make a determination as to whether your location is even SUITABLE for an Indoor Antenna....
You need an Antenna that is actually DESIGNED for Both UHF and Hi-VHF Band, which in an Indoor Antenna is usually something that includes RABBIT-EARS plus a UHF Antenna.
Fol. thread summarizes various Indoor Antenna Test...some are UHF-ONLY, some are UHF that just HAPPEN to have mediocre Hi-VHF performance and a FEW are specifically designed for UHF and VHF:
I'm still using rabbits ear antenna for my HDTV, need better stronger Antenna signal
IF you can actually receive enough signal strength for an Indoor Antenna, I recommend TRYING Terk HDTVa or Philips PHDTV3 Amplified Silver Sensor...BOTH of which come equipped with Rabbit-Ears and are Directive for more Gain and moderate Multipath signal suppression.....but awaiting those TVFool Results....
holl_ands is online now
post #9636 of 9643 Old 01-23-2015, 08:21 PM
lnong's Avatar
You seem to be correct, and thank you. I went back to the Winegard website to browse their indoor HD antennas and found that the "FV-30BB FreeVision Indoor/Outdoor HDTV Antenna" (also sold as FVHD30H) can receive hi-band VHF. I also found that Home Depot sells this one, so I picked on up. True enough, I set it up and I am now able to receive ALL those OTA channels I listed. Great signal for being around 41-42 miles away from the signal towers in LA, and this antenna even says it's only for up to 30 miles from a tower. I am definitely satisfied now.
phildaant likes this.
lnong is online now
post #9637 of 9643 Old 01-23-2015, 09:00 PM
phildaant's Avatar
Quoted: 431 Post(s)
Liked: 134
Question
Where did you put it? In the attic?
post #9638 of 9643 Old 01-24-2015, 10:51 AM
HoTatII's Avatar
Originally Posted by rdvegas View Post
Get ready to laugh as ABC launches a new diginet under the title of "LAFF TV". The diginet will air on KABC 7.2, it is speculated prior to the April 15th launch.
http://deadline.com/2015/01/laff-net...ps-1201352773/
To note;
The PR actually states that LAFF TV will air on the ABC station group's "D3" sub-channels, or KABC 7-3 for the LA market.
7-2 will continue to air the LWN as will all the stations in the group, even though it is technically no longer in syndication.
Sent from my SGH-M819N using Tapatalk
HoTatII is online now
post #9639 of 9643 Old 01-24-2015, 10:56 AM
phildaant's Avatar
Quoted: 431 Post(s)
Liked: 134
Cool
Originally Posted by Dante_101 View Post
Well, its not till April -- maybe they're still in negotiations for shows.
I filled out its e-mail form to ask what it will be showing.
post #9640 of 9643 Old Yesterday, 12:53 AM
lnong's Avatar
No, I put it on a side table in the same room as the TV on the 1st floor. I also had to use a long (25') coaxial cable in order to run the cable neatly and out of view along the wall.
lnong is online now
post #9641 of 9643 Old Yesterday, 12:29 PM
fshagan's Avatar
I'm quite a bit north of most of you ... in Oxnard, closer to Santa Barbara than to Los Angeles. TV Fool report: http://www.tvfool.com/?option=com_wr...2c15cafa53fa76
I installed a Antenna's Direct C4-CJM 20 inch ClearStream 4 extreme range UHF outdoors, about 30' above ground at the peak of my house and combined it with a home-built directional yagi tuned for and pointed for the Santa Barbara station I wanted, KEYT (ABC) broadcasting on channel 27. At first I was able to pull in KABC (VHF channel 7) and KCAL VHF 9 but now they are absent from the channel scans on my DVR+.
I think I understand why ... the ClearStream 4 isn't providing any VHF channels by design. Antenna's Direct doesn't have a kit or method to add VHF to the ClearStream 4. I'm wondering if it would be possible to use a diplexer intended to add UHF and VHF antennas together (I actually have one from Radio Shack), and combine the two together BEFORE I combine that signal with the directional antenna tuned for channel 27. It would have to either mount to the same outside mount the ClearStream 4 is on or in the attic.
fshagan is offline
post #9642 of 9643 Old Today, 11:05 AM
Liked: 0
I have cut the cable cord and am trying to get OTA channels. I have tried a couple of small TV-top antennas, but haven't been able to pick up hardly anything. I looked a little closer and realized that I can't see Mt. Wilson at my house. There is a mountain ridge between us. I attached a screenshot of TVfool's map view. So does that mean I need to get my antenna up high by installing a pole on the top of my house? I'm just looking for some help figuring out all the equipment I'd have to buy to make it work. Thanks for the help. Here's the link to the tvfool report:
http://www.tvfool.com/?option=com_wr...2c15e72c520472
grego26 is offline
post #9643 of 9643 Unread Today, 04:48 PM
lnong's Avatar
Which TV-top antennas have you tried? Before you climb up to install an outdoor antenna on your roof, try going to your local Fry's, Radio Shack, BestBuy, or Costco and buying Winegard's FlatWave amplified antenna (you don't seem too far from the tower, so you can try the cheaper non-amped version too). If that doesn't work, go pick up Winegard's FreeVision indoor/outdoor antenna from your local Home Depot (yes, Home depot sells this antenna). I live over 40 miles away, and the FreeVision is the ONLY indoor antenna that can pick up all the local OTA channels for me.
lnong is online now
