Los Angeles, CA - OTA - Page 335 - AVS Forum | Home Theater Discussions And Reviews
 126Likes
Old 03-04-2017, 05:32 PM
Jerrymc777's Avatar
Quoted: 26 Post(s)
Originally Posted by ProjectSHO89 View Post
FM Radio, maybe. LTE, unlikely. Have you run an FMFool report to see if you have strong local FM signals?
Yes there is... (see attached)
I have both a preamp and a dist. amp that both have FM filtering.
Would FM frequencies cause worse interference in colder weather or when the sun is setting?
Large HD8200XL antenna with HDB91X and RCA preamp
,aimed at Mt. Wilson (Los Angeles) from Etiwanda area.
CM3410 Dist. amp in attic for a 5 room hookup.
Located in foothills behind Mt. Baldy, and experiencing signal loss and pixelation depending on time of day.
Jerrymc777 is offline
Old 03-04-2017, 08:13 PM
tvmaster's Avatar
A silver sensor antenna on the roof isn't much of an antenna.
How about posting the link to your TVFool plot so we can get an idea of what the signal situation is expected to be at your location.
like this? it reads more bleak than it is:
http://www.tvfool.com/?option=com_wr...e6a4c67b3346b1
Essentially, I have two silver sensors on a pole, one pointing to LA, one to San Diego. I get very little, if anything, from LA.
tvmaster is offline
Old 03-05-2017, 05:15 AM
ProjectSHO89's Avatar
Quoted: 261 Post(s)
Liked: 129
You'd need to put a LOT more metal up in the air along with an appropriate preamp. The calculations in your plot suggests that it's doable, but you'd really need to step up your game. If you happen to have the good fortune of a clear signal path towards LA, that would be quite an advantage.
ProjectSHO89 is online now
Old 03-05-2017, 07:29 AM
tvmaster's Avatar
any examples or links of what a lot more metal may be, and when you say preamp, I'd also need to get AC up there as well?
tvmaster is offline
Old 03-05-2017, 07:31 PM
Falcon_77's Avatar
Quoted: 14 Post(s)
Your best shot to LA are the VHF stations (7, 9, 11, 13 at the moment) and there will be more after the repack. So, you will want a VHF antenna at least for VHF-Hi unless KVCR moves to Mt. Wilson on Lo-VHF. We will know in about a month if there will be more Lo-VHF's here as well.
First I want to ask if your 2 Silver Sensors are on the same cable run? If so, get a switch or rotator (commonly just called a rotor). Two antennas pointing in different directions can result in unexpected patterns and make things worse.
Try a new antenna before a pre-amp, but you are probably going to need one. What coax cable are you using? Make sure it's RG-6. A pre-amp doesn't need an AC outlet on the roof. The power is fed thru the coax.
Knowing that VHF will play a larger role, I would suggest something pretty hefty. Something like this, perhaps:
If you don't care about Lo-VHF/FM:
http://www.solidsignal.com/pview.asp?p=hd7698p#Reviews
If you do want Lo-VHF/FM:
http://www.solidsignal.com/pview.asp?p=hd8200u
This thing is huge (14' long and 9' wide) and it's probably best to wait for the new channel allocations to come out to bother with this, unless you want FM too. My Uncle lives in San Clemente and even LA FM radio is tough there.
Falcon_77 is offline
Old 03-06-2017, 09:35 AM
Marc Alexander's Avatar
Quoted: 1512 Post(s)
Liked: 1204
You would keep the preamp in the attic or use one that utilizes a DC inserter on the coax.
Marc Alexander is offline
Old 03-06-2017, 01:01 PM
Quoted: 261 Post(s)
Liked: 129
Originally Posted by Marc Alexander View Post
You would keep the preamp in the attic ...
Why???
...or use one that utilizes a DC inserter on the coax.
ALL modern preamps are connected that way.... If it doesn't connect that way, it probably isn't a preamplifier.
Old 03-06-2017, 01:14 PM
Falcon_77's Avatar
Quoted: 14 Post(s)
Why???
Right. Like the one in my closet. A distribution amp. I don't need a preamp at my location and they are different things.
Pre-amps are mounted at the antenna mast or as close to the antenna as practical so as little noise is amplified as possible.
Old 03-23-2017, 07:37 PM
dishrich's Avatar
Quoted: 59 Post(s)
Liked: 39
Just a curious question from an out-of-market visitor...is there actually an LD station called KSFV-6 somewhere in LA???
edit: deleted the rest of my post, think I finally found the answer here...so evidently DISH just upgraded it this week to HD. And with Sinclair involved, makes perfect sense as to how this got on DISH!
http://stocknewsnow.com/newsrss/2058618-Services
BEVERLY HILLS, CA--(Marketwired - September 25, 2015) - Greek Billionaire Alki David's FilmOn Networks announced today a massive slate of college sports to broadcast on FOTV, the cable channel that can be viewed on Dish Network and Charter Cable in Southern California. The games are presented in a partnership with Sinclair Broadcasting's American Sports Network. There will be up to three live broadcast of games each Saturday representing major teams and conferences from across the nation, all games you can't see anywhere else in the region.
FOTV is also on Dish Network channel 6 in the L.A. market, between KTLA and KABC, running 24 hours a day, and over the air on KIIO channel 10.2. It is also on Charter Communications at channel 387, spanning from Burbank to the San Gabriel Valley.
Sorry for the interruption...
dishrich is offline
Old 03-25-2017, 08:16 PM
Liked: 0
Balanced or Unbalanced 3 way antenna combiner?
I am going to combine 3 antennas.
Should I get a Balanced or Unbalanced splitter?
Balanced
https://www.amazon.com/Extreme-Balan...rum-convert-20
Unbalanced
https://www.amazon.com/dp/B009FN72PO...rum-convert-20
johnnybegoode is offline
Old 03-26-2017, 07:22 AM
Super Moderator
DrDon's Avatar
Quoted: 1019 Post(s)
Liked: 2045
Balanced
Unbalanced
We're gonna need your TVFool link in order to help you. We've continually asked you for this in your other threads, but you don't want to supply it. So, at that price, buy both and keep the one that works better.
rdvegas likes this.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
Old 03-26-2017, 09:05 AM
Quoted: 261 Post(s)
Liked: 129
And don't be surprised if neither of them do what you think they will.
DrDon likes this.
Old 03-26-2017, 02:35 PM
Liked: 0
http://www.tvfool.com/?option=com_wr...e6a400fb119c69
I am already using a 2 way splitter for 2 antennas.
They work better than just 1, and I would like to add one more antenna.
I just don't know if balance or unbalanced would would better?
I have limited resources.
Old 03-26-2017, 03:14 PM
Super Moderator
DrDon's Avatar
Liked: 2045
What antennas do you have, which way are they pointing, where are they located and what are you trying to accomplish?
DrDon is online now
Old 03-26-2017, 06:31 PM
Liked: 0
They are pointing in the NW direction and I am trying to cover a bigger area of the window.
Having 2 antennas has greatly improved my reception.
However whenever planes, helicopters and autos are in the signal's pathway, they would affect the signal.
My TV's tuner would make unbearable sound whenever there are interferences.
The two 50miles amped flat antennas are hanging loosely over the window's blind rod and I could move them whenever required.
The interferences sound are eliminate when the antennas are in a close proximity. With 3 antennas, I would be able to cover a bigger area of the window (the whole window would look and function like a big antenna) and having them in a closer proximity would eliminating the hassle of moving any antenna around.
I might even be able to receive more channels. I'm already getting 90% of the channels listed on TV fools.
The length of antennas need to be almost the same to prevent phasing (cancel out of one another's signal).
After some research, I am answering my own question.
I assume that all modern flat HD amped antennas are balanced and so the balanced splitter is the better choice.
Old 04-13-2017, 11:34 AM
HoTatII's Avatar
Quoted: 61 Post(s)
Liked: 25
Oh my goodness ....
Trip just posted the FCC's release of the post-auction repack and channel reassignment plan;
https://www.rabbitears.info/repackchannels.php
And the following stations will be leaving the air in the LA market...
KAZA-DT
KOCE-DT
KNET-CD
KSFV-CD
KLCS-DT
KBEH-DT
KRCA-DT
KJLA-DT
Wow ... so I guess that's it for PBS broadcasting in the LA market then with both KOCE and KLCS going off the air. And KCET having long left ...
Sheesh ...
Oh well, except for losing Spanish KWHY and any possibily of getting KVCR, which I can't currently receive anyway, at least I won't really need a new rooftop antenna with VHF-lo band capability.
Sent from my LGMS550 using Tapatalk
HoTatII is online now
Old 04-13-2017, 11:47 AM
Trip in VA's Avatar
Quoted: 691 Post(s)
Liked: 197
Send a message via AIM to Trip in VA
"Off air" indicates either going off the air or channel sharing. (To the auction system, they look like the same thing--freeing a TV channel.) More than 90% of stations going "off the air" indicated at least an interest in channel sharing.
Don't forget that KLCS and KCET announced they would channel share back in 2014. https://www.kcet.org/press-room/kcet...ng-partnership
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
gonzo90017's Avatar
Quoted: 43 Post(s)
That really, really sucks! I had a feeling something like this was going to happen. KAZA-DT is where I get most of my soccer fix on the weekends. KOCE is one of my most DVRed stations. This also sucks for a lot of parents since now there will be no more PBS Kids.
gonzo90017 is offline
Old 04-13-2017, 01:04 PM
Liked: 3
They're channel sharing, not going away.
Bryan Cannon is offline
Old 04-13-2017, 01:13 PM
HoTatII's Avatar
Quoted: 61 Post(s)
Liked: 25
I hope so ...
However, even if channel sharing they certainly won't be dragging all their current secondary sub-channels with them I would think ...
Old 04-13-2017, 01:42 PM
Liked: 3
Originally Posted by HoTatII View Post
I hope so ...
With ATSC 3.0 on the way, it won't be a problem.
Old 04-14-2017, 01:23 AM
Trip in VA's Avatar
Quoted: 691 Post(s)
Liked: 197
Here's a relevant article about KOCE. http://www.tvnewscheck.com/article/1...-auction-money
- Trip
N4MJC
RabbitEars
Old 04-14-2017, 03:22 AM
HoTatII's Avatar
Quoted: 61 Post(s)
Liked: 25
- Trip
... There will be no change for viewers is said; PBS SoCal will continue to broadcast, for free and **in high quality (UHF),** the full lineup of PBS programs on all four of its current channels over the air, via cable and satellite, and online at pbssocal.org.
While I don't expect these sorts of articles to always be technically accurate, but I notice there is no mention of "high quality HD" here, but "in high quality (UHF)."
So what does that mean? Are they still going to be able to keep 50-1 in 1080i HD with this channel sharing agreement with KSCI?
They're going to be hard pressed to do that plus carry all the secondary sub-channels short of a bit-starved mess ...
... Through a channel sharing agreement with local Los Angeles full-power television station KSCI, PBS SoCal retained most of the stations’ combined spectrum, ensuring sufficient bandwidth to serve the Southern California region while earning revenues that will be invested in building for the long-term future of PBS SoCal.
Ah ... "retained most of the stations’ combined spectrum?"
"ensuring sufficient bandwidth to serve the Southern California region?"
Well ... KSCI is running at 11 SD sub-channels right now and KOCE is at 5 (not 4 as the article says) sub-channels with the main at 1080i HD.
So how is this supposed to work out unless KSCI is going to eliminate almost all of its secondary sub-channels or KSCI eliminating maybe half of their subs. and KOCE going SD on all their sub-channels?
Old 04-14-2017, 03:33 AM
Trip in VA's Avatar
Quoted: 691 Post(s)
Liked: 197
If you look at the list of winning prices:
https://apps.fcc.gov/edocs_public/at...A-17-314A2.pdf
You see that KOCE won $138 million. But the article says they're walking away with $49 million, which is about 35% of the money. If you imagine the split in shared money equaling the split in bandwidth (no guarantee of that, but seems reasonable) then that means KOCE would retain 65% of the spectrum (since they're paying 65% of their money to KSCI), which is about 12.6 Mbps total. Definitely sounds like KSCI would be cutting back with 6.7 Mbps total. Not sure how much cutting, if any, KOCE would need to do depending on how much money gets put into state of the art encoding hardware and how good that hardware is.
- Trip
N4MJC
RabbitEars
Old 04-14-2017, 01:32 PM
LensClock's Avatar
Quoted: 16 Post(s)
Here is a link to the Washington Post article about the auction.
The middle part describes the options available to the stations that have to move:
https://www.washingtonpost.com/news/...=.e3bd63d42fb8
LensClock is offline
Old 04-24-2017, 08:57 AM
Liked: 1
Repack question: KCBS - KTLA
So if I'm reading the repack list correctly, it appears KCBS (now on 43) will be moving to 31.
and KTLA, which is currently on 31, will be moving to 35 (currently KRCA which will go dark).
So why not just move KCBS to 35 and leave KTLA where it is ?
I'm probably missing something....
EngineerinLA is offline
Old 04-24-2017, 11:47 AM
Trip in VA's Avatar
Quoted: 691 Post(s)
Liked: 197
Adjacent-channel interference. KCBS cannot be adjacent to KNBC.
- Trip
N4MJC
RabbitEars
Old 04-24-2017, 11:55 AM
HoTatII's Avatar
Quoted: 61 Post(s)
Liked: 25
- Trip
Huh?
I thought that was one of the primary advantages of DTV over analog. No further need to use alternate channel spacing in the same market to prevent ACI?
Old Today, 06:23 AM
Trip in VA's Avatar
Quoted: 691 Post(s)
Liked: 197
It's situation-specific. Stations can be adjacent if they're either similarly situated (similar location, height, power, antenna pattern) or if one or the other accepts the interference resulting from a discrepancy. In this case, KCBS and KNBC are different enough in one or more of those aspects that they could not be adjacent to each other, while KNBC and KTLA were similar enough that they could.
- Trip
N4MJC
RabbitEars
ch 2.1 , ch 43.1 , grand wega , kcbs , pasadena ca
