Bugging out EscapeTV and Get TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-05-2015, 06:03 PM - Thread Starter
stoxguy's Avatar
Unhappy Bugging out EscapeTV and Get TV
I previously received both 68.3 (GET tv) and 68.4 (Escape TV). I have a "real" antenna that is aimed directly at NYC. The antenna is indoors, as I have not mounted in my attic. I have a SONY that was built in 2006 and works fine. My digital to analog converted was receiving ALL High-Def stations in the NYC area. Around 50+ stations. Now, all of a sudden, I am getting a black screen on both GET and ESCAPE. I checked the signal strength and both are over 40%, yet I am not getting their broadcasts. Every station works fine. This just occurred today. I did a factory reset and unplugged the converter and the same problem occurs. The title description changes, but I do NOT get a broadcast from either station on my TV. What's going on? The signal strength is more than enough for the converter to work with.
stoxguy is offline
post #2 of 2 Old 03-06-2015, 03:48 PM
cwpl's Avatar
If there not back yet, try emailing station they might be doing maintenance or repair.
cwpl is offline
