Champaign, IL - HDTV - Page 167 - AVS Forum | Home Theater Discussions And Reviews
post #4981 of 4999 Old 01-18-2015, 11:07 AM
TimfromSpfdIL's Avatar
Originally Posted by TimfromSpfdIL View Post
I just spotted 20-3 with GritTV. Not sure if WICS added this subchannel on New Year's Day, but today was the first time I noticed it. At least for the time being, 20-2 is still active with ZUUS Country. I don't see Grit on Comcast yet.
Today's State Journal-Register out of Springfield reports in their Business section that Comcast will be adding Grit on channel 420 on our local system later this month.
http://www.sj-r.com/article/20150117...INESS/?Start=2
TimfromSpfdIL is offline
post #4982 of 4999 Old 01-20-2015, 11:56 AM
kc9hzn's Avatar
I was recently given a pocket analog TV. Of course, with full power analog stations no longer being on the air and not having the proper connectors, I had no way of knowing that the TV actually worked, just my suspicion that it did. Anyway, I had to go to Champaign proper earlier today and decided that it would be a great idea to go on an analog LPTV DXpedition. In particular, I was hoping to determine whether I would be able to tune in WBXC-CA, a supposed America One affiliate licensed to Champaign. No, I was not able to tune it in (their filings with the FCC indicate a history of being off the air at various times, plus they have a CP for a digital station), but I did manage to find an analog HSN station in Champaign. Top of the hour conditions were horrible, though, so I couldn't see if the station ID'd, plus, the TV has an annoying quirk: it's impossible to tell what channel you're actually on, you can only guestimate based on the scale at the bottom of the screen. This HSN station appeared to be located around channels 30-40. However, I can't seem to find any record of a HSN station in the Champaign area in the first place. So, anyway, the analog TV does indeed work. I may try to do some analog Es DXing this summer on it.
Can we get someone in Champaign proper to try to tune in WBXC-CA, either in analog or digital? I, for one, would really like to know what's on it. I suppose it's quite possible that it is the HSN station I tuned in. The low power TBN station shut down, leaving only one or two low power analog stations left in Champaign.
Edit: Further research indicates that it was most likely W39BH. Which means that the TBN station didn't so much shut down as it did change hands and become an HSN affiliate AFTER the analog shutdown. (I definitely tuned them in once as a TBN station post shutdown.)
kc9hzn is offline
post #4983 of 4999 Old 01-24-2015, 09:31 AM
dishrich's Avatar
Quoted: 18 Post(s)
Liked: 29
Pleasantly surprised to see that WRSP-55 & WBUI-23 are now broadcasting syndicated HD prog, in actual HD now...
dishrich is offline
post #4984 of 4999 Old 03-19-2015, 05:23 AM
mvcg66b3r's Avatar
Quoted: 29 Post(s)
Liked: 1
WICD cancels all local newscasts; will now be produced at WICS
Well well well… It looks like Sinclair is ready to make a transition to make WICS/WICD look more like one news station, instead of two. And that requires also shutting down one of the stations’ duopoly’s news departments. And WICD, will get that ax.
We are being told, according to VermillionCountyFirst.com and also according to FTVLive, that Sinclair has pink slipped a number of on-air and off-air staffers at WICD 15, the ABC station out of Champaign, IL that is a semi-satellite to WICS 20 in Springfield, IL. And because of that semi-satellite status, WICD will dump 95% of its locally produced newscasts and move them to WICS 20, starting next month in April. In other words, all newscasts seen on WICS 20 will also be seen on WICD 15.
Just letting you know that I said 95% and that I didn’t count the other 5%. Why? Its because WICD 15 will be trading in the 95% for the 5% to start up a brand new one-hour 9:00 p.m. weeknight newscast on WRSP 55’s semi-satellite station WCCU 27. This new one-hour newscast will also start in April and will be produced out of WICD 15. WICS 20 will continue to produce the Springfield version of the news at 9:00 for WRSP 55 as well as the weekend editions at 9:00 on WRSP 55/WCCU 27 in both areas.
According to VermillionCountyFirst.com and FTVLive, some employees have been given 30-day termination notices and will only keep a few employees while the rest could either be retained by WICS 20 in Springfield or could be let go altogether. A news release says that the “reallocation of resources will require fewer staff members in Champaign and more news staffers in Springfield.”
https://changingnewscasts.wordpress....0-pm-be-saved/
We already seen this in Minneapolis with WCCO/KCCO/KCCW and KSTP/KSAX/KRWF.
Could this happen in other markets with semi-satellites (WDAY Fargo/WDAZ Grand Forks; KLTV Tyler/KTRE Lufkin; KIMA Yakima/KEPR Pasco)?
One person's craziness is another person's reality. - Tim Burton
mvcg66b3r is online now
post #4985 of 4999 Old 03-19-2015, 10:45 AM
unclehonkey's Avatar
Quoted: 103 Post(s)
not really the same thing
KCCO and KSAX had a 5 minute cut-in after the 1st commercial break and the weather was also the "local" version. The rest of the news came from the mothership (WCCO or KSTP)
KCCW was a 100% satellite feed of KCCO from the get-go. They always ID'd as "7/12" even when Alexandria was its own market (and they were NBC/ABC affiliates)
KRWF is a 100% satellite feed of KSAX
unclehonkey is offline
post #4986 of 4999 Old 03-20-2015, 06:49 PM
Let me guess the implications of this not-surprising move on the Springfield side of the market: Significantly Less Springfield-area non-Capitol news and Boatloads of Champaign-Danville news--basically what 20's marketwide weekend newscasts and Fox 55/27 News at Nine looks like now. This time nearly 24/7.
post #4987 of 4999 Old 03-20-2015, 09:09 PM
dishrich's Avatar
Quoted: 18 Post(s)
Liked: 29
OK, well the only thing I was not totally clear on is...
WICD 15 will produce and air a one-hour weeknight newscast at 9:00 p.m. on WCCU 27, starting in April.
So if you notice it did NOT say WRSP 55...ONLY WCCU 27. So what they are really doing, is moving WICD's (C/U) newscasts to ONLY the WCCU signal...while WRSP having a (completely) separate newscast for Spfld/Dec news(?) Since it says specifically WICD will produce it, it sounds like they will just feed WICD's newscast feed directly over to WCCU.
So actually, all they are doing is flip-flopping the newscasts between WICS/WICD & WRSP/WCCU. If you want mostly S/D news, you'll need to watch it at 9PM on WRSP; if you want mostly C/U news, you'll have to watch it at 9PM on WCCU.
Since I DVR everything, I'll just start DVR'ing the WRSP news@9 instead.
NOW, here's something else interesting...Sinclair got DISH Network to finally put up WICD-HD in our locals pkg about 2 years ago; the premise being, C/U viewers were NOT getting to see their C/U newscasts. (previously ONLY having WICS) Now that the brainboxes@Sinclair are doing this thing, now DISH subs in C/U are right back where they started, since DISH does NOT carry WCCU at all. (no matter either way for DirecTV subs, since it has never carried either WICD or WCCU)
dishrich is offline
post #4988 of 4999 Old 03-23-2015, 10:00 AM
Jokinjer1's Avatar
At least these stations are ran much better than the crap operations I have to look at when I'm back home in Peoria. :P
Jokinjer1 is offline
post #4989 of 4999 Unread 06-08-2015, 11:22 AM
Marty Milton's Avatar
Recently I noticed that Comcast here in C-U is zooming almost all the SD channels, including those that were originally broadcast in the 4:3 format. I really don't like this.
Marty Milton is offline
post #4990 of 4999 Unread 06-18-2015, 02:23 PM
TechFan893's Avatar
Liked: 0
I noticed a promo during WCIA's noon news today for Saturday's Cubs game on WCIX being touted as "now in high definition." I emailed the chief engineer and he told me WCIX will be switched to HD late tonight. If I'm not mistaken, this will be the last full power station in the market to go HD.
TechFan893 is offline
post #4991 of 4999 Unread 06-20-2015, 05:05 PM
kc9hzn's Avatar
I wonder what that means for 3.2. Will they run it at 720p, or keep it at 480i?
kc9hzn is offline
post #4992 of 4999 Unread 06-21-2015, 07:03 PM
dishrich's Avatar
Quoted: 18 Post(s)
Liked: 29
First, thx TechFan for this info...& yes, this IS the last (full-power) station in our market to go HD, which means we now have ALL the major English OTA nets in HD now. (not that MNT is really "major", but you get the point...) While I do NOT watch anything on MNT itself, I do watch some of the syndicated shows on WCIX. I was pissed when they moved (& downgraded) Inside Edition to blurry SD on WCIX; I went back to watching it on WLS out of Chicago.
I checked out the feed that's always been on the Spfld/Decatur Comcast ch 918, which is in the "HD neighborhood" of all our other HD OTA's...but has always been just a dupe 480 SD feed since day 1. To my amazement, it IS now a 1080i HD feed.
I then checked out the OTA signal of 49.1/49.2; my TV(s) report BOTH channels are now 1080i. While I didn't have time to thoroughly check out the picture on both, 49.2/CBS seems as good as it was before...& obviously a BIG improvement on 49.1/MNT.
I viewed Inside Edition & a couple other syndicated shows & they, too are being broadcast in HD now. This means that any syndicated prog that is available in HD, should be in HD in our market if it is shown here!
kc - WCIX/49.2 has ALWAYS been in 1080i HD since day 1 when they went HD with WCIA; they are talking about the actual WCIX/MNT feed, that up until now has only been in SD on both 3.2/49.1.
I can't get 3.1/3.2 over here, but I would assume they are doing the same thing with both channels there as well. I am surprised that they did not go with 720p for WCIX 49.1/3.2...considering MNT is broadcast in 720p, as well as all the sports they keep putting on WCIX; it probably would have been easier to squeeze it alongside WCIA's 1080i signal. Maybe Nexstar got a "good deal" on a (new, dual) 1080i encoder.
Now to wait & see how long it takes to get the HD feed added on U-verse, DISH & DirecTV...
dishrich is offline
post #4993 of 4999 Unread 06-22-2015, 11:52 AM
mvcg66b3r's Avatar
Quoted: 29 Post(s)
Liked: 1
RabbitEars says WCIA 3.2 is still in 480i SD.
http://www.rabbitears.info/market.ph...=42124#station
post #4994 of 4999 Unread 06-22-2015, 08:12 PM
kc9hzn's Avatar
Heck, even I'm doing well to get 3.1 or 3.2. It seems to come in better during the summer. Even when it was on RF 3, we never did have much luck in tuning in WCIA. (In fact, WCIA is the one station that we get better service from post-transition than we ever did pre-transition. That's partially due to the Terk HDTVa I bought back in 2010, and partially due the move to UHF.) Even though Champaign is only about 30 miles from us, we primarily got CBS service from WTHI. (And even then, primarily on the second floor. Channel 10 didn't usually come in well on the first floor.)
kc9hzn is offline
post #4995 of 4999 Unread 06-23-2015, 06:54 AM
dishrich's Avatar
Quoted: 18 Post(s)
Liked: 29
Wiki says otherwise:
https://en.wikipedia.org/wiki/WCIA
Surely there's ONE person out here that can actually get 3.1/3.2 OTA & verify...
dishrich is offline
post #4996 of 4999 Unread 06-23-2015, 07:18 AM
Trip in VA's Avatar
Quoted: 237 Post(s)
Liked: 89
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
I don't update things until I get confirmations. I've heard no confirmation of WCIA, only of WCIX.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #4997 of 4999 Unread 06-23-2015, 07:36 PM
TechFan893's Avatar
Liked: 0
- Trip
I receive WCIA and can confirm that 3.2 is broadcasting in 1080i.
post #4998 of 4999 Unread 06-23-2015, 07:38 PM
TechFan893's Avatar
Liked: 0
Also, WCIX's nickname needs to be updated to "X 49" Trip.
post #4999 of 4999 Unread 06-24-2015, 03:10 AM
Trip in VA's Avatar
Quoted: 237 Post(s)
Liked: 89
Thanks, corrections made.
- Trip
N4MJC
RabbitEars
