Moving a TV from one place to another - AVS | Home Theater Discussions And Reviews
post #1 of 1 Old 04-22-2015, 03:05 PM - Thread Starter
Rawe's Avatar
What would you recommend for moving a TV from one place to another I don't have the stuff that came to cover the screen anymore. Would a towel.work? I would put the tv in a box. And transfer it that way. Just want to make sure there is no damage done.
Rawe is offline
