Rockford, IL - HDTV - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 1210 Old 09-15-2006, 04:04 PM
sebenste's Avatar
Quoted: 21 Post(s)
Originally Posted by jgags6 View Post
So I went up and decided to try to get the madison's again. Well this time it worked better than last time. I acually got Fox ABC PBS and CW, i also got NBC but it kept going in and out, which sucks. I wonder why i didnt get CBS. Since I didnt want to loose NBC and CBS i put it back. I guess i will try and get a pre amp.
NBC is only at 56 kw, and because of their channel choice, they can't go any higher. CBS might be because of interference with channel 50 in Chicago.
I betcha if you get that preamp, you're going to be amazed at what you get!
Gilbert
sebenste is offline
post #362 of 1210 Old 09-15-2006, 04:35 PM
jgags6's Avatar
Okay I just figure out that I have a Winegard 7084 antenna. Now what would be the pre-amp you guys would recomend to go with that.
jgags6 is offline
post #363 of 1210 Old 09-15-2006, 06:03 PM
sebenste's Avatar
Quoted: 21 Post(s)
Nice antenna. No change in thinking; this Winegard preamp will serve you well.
http://www.warrenelectronics.com/antennas/AP8700.htm
In fact, here is a picture of your antenna with a model similar to the AP8700
that this person mounted on the mast.
http://www.tvantenna.com/products/tv...rs/preamp.html
Gilbert
sebenste is offline
post #364 of 1210 Old 09-15-2006, 06:06 PM
Jeff Whitford's Avatar
If you want the weather map its on 15.2 from Madison.
Jeff Whitford is offline
post #365 of 1210 Old 09-15-2006, 09:51 PM
Jason Nipp's Avatar
WQAD out of Moline runs a Doppler feed on 8.3 as well.
Jason Nipp is offline
post #366 of 1210 Old 09-15-2006, 10:11 PM
jgags6's Avatar
Do you think there is any chance of getting Chicago's locals from Rockton?
jgags6 is offline
post #367 of 1210 Old 09-16-2006, 07:38 AM
Jason Nipp's Avatar
I'm in Caledonia. Your a bit further out....not sure.
post #368 of 1210 Old 09-16-2006, 09:37 AM
sebenste's Avatar
Quoted: 21 Post(s)
Jeff and Jason,
Wish I could get those. But at 56 kw, 15.2 is too weak to pick up from DeKalb (19 from Chicago, WGN-DT also stomps on it here, even with a CM 4228 antenna),
and 8.3 is blocked by a large ridge to my west which runs north-south through far eastern Ogle and Lee counties. How about it 39-2?
Jgags,
If you want a better shot, you could try the Winegard AP-8275 amp. That really
cranks up the gain, also available from Warren. But, you then risk overloading on the Rockford stations, causing you to not get them anymore.
Once you are over the 60 mile Chicago broadcast reception line-of-sight horizon, all bets are off. If you are on a hill or high area, you have a shot. Way earlier in this thread, people have talked about how they could solidly lock WTTW-DT in Rockford from State street near Rockford College, but that was with the largest Winegard antenna, twice the size of yours...and outside, with a preamplifier.
Gilbert
sebenste is offline
post #369 of 1210 Old 09-16-2006, 09:43 PM
hvs10trk's Avatar
Doubtful. Rockton is pretty low. When I worked at WTVO we could only do live shots from several points in town. You could try but don't be dissapointed if it doesnt work. You'd be better trying madison.
"Celebrating over 20 years of creating new and inovative ways to completely screw up television programming!"
Disclaimer: My opinions are mine and do not represent those of my employer
hvs10trk is offline
post #370 of 1210 Old 09-16-2006, 09:45 PM
hvs10trk's Avatar
Originally Posted by sebenste View Post
Jeff and Jason,
Jgags,
Insight Com. locks WTTW from Loves park but thats with a 200'+ tower and the picture ain't all that great.
hvs10trk is offline
post #371 of 1210 Old 09-17-2006, 08:12 AM
jgags6's Avatar
Alright, looks like i will just go for Madison. Is there any place to get the pre-amp here in Rockford. I hate waiting for things when I order them online.
jgags6 is offline
post #372 of 1210 Old 09-17-2006, 09:44 AM
Bock or Jaytronics
post #373 of 1210 Old 09-17-2006, 02:25 PM
Jason Nipp's Avatar
I'm doing pretty good this weekend.
I turned my antenna's azimuth about 20 degrees further north.
I picked up a few more stations, although my receiver will not translate the guide info. Most likely cause I don't get those channels through satellite, so it doesn't have the EPG info to populate the fields.
The one thing I don't understand is, even though the sat receiver provided the guide data, it still uses PSIP to indentify the station. The problem I don't understand is on channel 35.1, the channel does not indent, but the rest of the 35 subs do. Weird.
Here some pics, sorry about the CRT in these pics.
post #374 of 1210 Old 09-17-2006, 02:27 PM
Jason Nipp's Avatar
Two more.
post #375 of 1210 Old 09-17-2006, 03:32 PM
hvs10trk's Avatar
Originally Posted by Jeff Whitford View Post
Bock or Jaytronics
Jaytronics is a great store. Used to do tons of business with them.
hvs10trk is offline
post #376 of 1210 Old 09-20-2006, 11:10 AM
Jason Nipp's Avatar
bump. close to falling off.
post #377 of 1210 Old 09-20-2006, 12:01 PM
hvs10trk's Avatar
a
a
a
a
h
h
h
hvs10trk is offline
post #378 of 1210 Old 09-22-2006, 02:54 PM
jgags6's Avatar
So i got the pre amp, Installed it, but i still cannot get CBS. I get all of the others. This is really disapointing, i thought for sure that this would work. Any pointers?
jgags6 is offline
post #379 of 1210 Old 09-22-2006, 04:09 PM
johnnykretentiv's Avatar
Is there I reason I am not getting FOX? I get other channels (ABC, CBS, NBC, CW?) at 90+%. I actually get a 75-80% signal from Fox but no pic. Probably obvious but could some one please help me out.
BTW - just using a litte RCA indoor antenna.
johnnykretentiv is offline
post #380 of 1210 Old 09-22-2006, 04:19 PM
jgags6's Avatar
WQRF isnt up to full power, im also in rockton and i have an antenna on my roof and i never get fox. I was told today that WQRF is going to broadcast HD starting sunday, but that doesnt nessararaly mean that they will push it up to full power
jgags6 is offline
post #381 of 1210 Old 09-22-2006, 08:17 PM
3.1 is the weekest Madison channel I get. I have to pretty much point my antennas due north to get it. I dont really need it because 23.1 has everything I want. Until/if the Packers and the Bears play at the same time on CBS which I dont think happens.
post #382 of 1210 Old 09-22-2006, 08:30 PM
Got 3.1 for a couple days. Nothing lately though.
Thanks jgags6 I 'll wait patiently
post #383 of 1210 Old 09-23-2006, 12:56 AM
sebenste's Avatar
Quoted: 21 Post(s)
Punch in channel 41-1. See if you can get it directly. Do you have a signal strength meter, and if so, what does it say? How does analog 23 come in, any way you can check?
Gilbert
sebenste is offline
post #384 of 1210 Old 09-23-2006, 05:27 PM
hvs10trk's Avatar
They're not ready for full power yet. That involves some construction work still yet to come.
hvs10trk is offline
post #385 of 1210 Old 09-23-2006, 05:29 PM
hvs10trk's Avatar
WQRF-DT is strong to the south and east. Where are you located?
hvs10trk is offline
post #386 of 1210 Old 09-23-2006, 05:35 PM
jgags6's Avatar
so what are the odds that WQRF will be broadcasting the game in HD tomorrow?
jgags6 is offline
post #387 of 1210 Old 09-23-2006, 05:37 PM
Rammitinski's Avatar
Not sure where they're transmitting from, but I believe that their signal emanates from the lowest point of all the digital channels.
Rammitinski is offline
post #388 of 1210 Old 09-23-2006, 07:11 PM
Rockton
post #389 of 1210 Old 09-24-2006, 07:47 AM
hvs10trk's Avatar
WTVO's tower most of the way up.
hvs10trk is offline
post #390 of 1210 Old 09-24-2006, 07:52 AM
hvs10trk's Avatar
Rockton
You should be able to receive them. Hopefully you're not right up by the river. Otherwise you should see them. Heck I could get a live shot from Old Settler's day from the bank!!
hvs10trk is offline
