Rockford, IL - HDTV - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 1210 Old 11-05-2006, 03:47 PM
cmunroe's Avatar
I also lost Wrex on one of my TV's
- strong signal no video - a rescan fixed the problem.
cmunroe is offline
post #542 of 1210 Old 11-05-2006, 08:49 PM
jazzjukebox's Avatar
No such luck for me. Still no WREX-DT. :-(
jazzjukebox is offline
post #543 of 1210 Old 11-06-2006, 05:15 AM
hvs10trk's Avatar
I'll see what I can find out from my inside sources.
"Celebrating over 20 years of creating new and inovative ways to completely screw up television programming!"
Disclaimer: My opinions are mine and do not represent those of my employer
hvs10trk is offline
post #544 of 1210 Old 11-06-2006, 10:40 AM
I got an email response from WREX Chief Engineer, Gerr Meinders.
> Yes, WREX made a PSIP software upgrade and this has
> generated the digital reception problem. We'll be making
> changes to our PSIP to clear up the problem.
post #545 of 1210 Old 11-08-2006, 05:40 PM
connery58's Avatar
Hey All,
I was wondering if anyone had any information on Insight broadcasting WQRF in HD. I have inquired Insight a couple of times and haven't really gotten a good answer. Any info would be greatly appreciated!!!
connery58 is offline
post #546 of 1210 Old 11-09-2006, 04:56 PM
Ast Chf's Avatar
Originally Posted by connery58 View Post
Hey All,
Insight just this week installed fiber at WQRF for just this. This is a guess but I'd say we'd be on in the next couple of weeks.
I'll post again once we get a firm date.
Ast Chf is offline
post #547 of 1210 Old 11-11-2006, 01:20 AM
sebenste's Avatar
Quoted: 21 Post(s)
Hey Assistant Chief,
Just an FYI---during a program tonight, I noticed that there's a dark blue-colored, solid FOX logo in the far bottom right corner of the screen that is barely 15% on-screen. Just so's you nose...
Gilbert
sebenste is offline
post #548 of 1210 Old 11-11-2006, 06:01 AM
johnnykretentiv's Avatar
I get the same thing from Fox here in Rockton.
johnnykretentiv is online now
post #549 of 1210 Old 11-11-2006, 03:52 PM
Ast Chf's Avatar
That will be replaced with a WQRF-DT logo in the next day or 2. That is a default logo that Fox triggers remotly and we have no control over
Ast Chf is offline
post #550 of 1210 Old 11-13-2006, 01:32 AM
Karrrma's Avatar
Hi all, I am really a newbie in all of this, and wanted to know if I could get some basic info to get my feet wet and then maybe I can get into more technical areas.
I am looking into getting an OTA to go with my DishNetwork and I have had so many people tell me all different things that I just want to throw all that info out and start fresh.
I want to pick up the rockford channels but want to know what extra steps I would have to do to pick up either and both of chicago and madison. I am at candlewick lake if that helps. Please let me know if I can answer anything else to help you help me
Karrrma is offline
post #551 of 1210 Old 11-13-2006, 05:40 PM
connery58's Avatar
Thanks for the info, I can't wait to start getting WQRF in HD over Insight!!
post #552 of 1210 Old 11-14-2006, 11:19 AM
BigCubFan's Avatar
Does anyone know when WQRF-DT will be broadcasting at full strength? I can get all the other local HD channels in Roscoe on an indoor antenna except for Fox and I gotta see Da Bears in Hi-Def! Thanks
BigCubFan is offline
post #553 of 1210 Old 11-14-2006, 12:05 PM
sebenste's Avatar
Quoted: 21 Post(s)
For just Rockford stations, a rooftop antenna such as this:
http://www.warrenelectronics.com/antennas/pr7037.htm
should work fine. If you put it in an attic, you'll need a preamplifier, such as this:
http://www.warrenelectronics.com/antennas/ap2870.htm
If you want Chicago stations, you need a large ChannelMaster antenna, such as:
http://www.starkelectronic.com/allant.htm
Look at the ChannelMaster 3671. That should do you well, putting it on a rotor.
As for a tuner, try a Samsung SIR T-451 from Ebay. The latest generation is out,
but unless you have an HDTV, the menu won't display. I have seen the T-451
at Best Buy and elsewhere, but it has been discontinued. Ebay has some. I like it!
Gilbert
sebenste is offline
post #554 of 1210 Old 11-14-2006, 12:39 PM
Rammitinski's Avatar
I noticed that the local BB here in Crystal Lake was still selling the T-451 (along with the newer model) about a week ago, so you might find one near you that has some in stock.
If not, you could always try begging them to have one sent over from here, or just stop by the store here if you happen to be out this way. But I'd definitely call them first to make sure they still have one.
Rammitinski is offline
post #555 of 1210 Old 11-14-2006, 12:44 PM
Karrrma's Avatar
Do I need something like the T-451 with the Dishnetwork reciever?
Karrrma is offline
post #556 of 1210 Old 11-14-2006, 12:56 PM
It depends on which Dish receiver you have. If it's an HD-capable one (and it includes an OTA ATSC tuner), you can use it to get the local digital channels. If it's only standard def, then you'll need an additional receiver like the Samsung to get them.
Let us know the model number of your Dish receiver.
post #557 of 1210 Old 11-15-2006, 10:01 PM
sebenste's Avatar
Quoted: 21 Post(s)
WIFR-TV had a heinous blowout of their Klystron tube in their analog transmitter.
On their website, they note that they probably will be back on the air late Wednesday or tomorrow, and say most cable systems and satellite are having no problems. That's because of fiber, and...ahem...WIFR-DT is still on the air just fine. Why didn't they mention THAT?
C'mon guys, half your station is up and doing fine!
And in DeKalb, WWME-TV 23 from Chicago is coming in decently...
Gilbert
sebenste is offline
post #558 of 1210 Old 11-16-2006, 01:55 AM
dline's Avatar
As for a tuner, try a Samsung SIR T-451 from Ebay. The latest generation is out, but unless you have an HDTV, the menu won't display.
If the 451 is anything like the 351, which I have, there may be a switch on the back called "Resolution Select," which sets the output resolution. On the T-351, the 480i output (for analog sets) is "always on." But the menu will only appear on a 480i set if this switch is set to the 480i output. If it's set to the 720p or 1080i outputs, the box is still outputting the 480i signal but there will be no menus or anything else superimposed on it.
Views are strictly my own unless otherwise noted.
"ItÂs looking more like Y2K than the Bay of Pigs." - FCC Commissioner Adelstein, 6-13-09, on the DTV switch
dline is offline
post #559 of 1210 Old 11-21-2006, 07:03 PM
Ast Chf's Avatar
WQRF-DT is now on Insight cable on channel 908 in HD
Ast Chf is offline
post #560 of 1210 Old 11-21-2006, 07:04 PM
Ast Chf's Avatar
CORRECTION WQRF is on Insight channel # 910. (908 is WTVO-DT)
Ast Chf is offline
post #561 of 1210 Old 11-21-2006, 07:16 PM
hvs10trk's Avatar
I don't have Insight. Can you tell me what channel on RCN???
hvs10trk is offline
post #562 of 1210 Old 11-24-2006, 12:15 PM
hvs10trk's Avatar
Boy, tough crowd. Hope everyone had a Great Thanksgiving.
hvs10trk is offline
post #563 of 1210 Old 11-30-2006, 07:28 PM
Jason Nipp's Avatar
Did anybody else notice WIFR-DT added a new subchannel with accuweather live doppler?
Jason Nipp is offline
post #564 of 1210 Old 11-30-2006, 07:44 PM
sebenste's Avatar
Quoted: 21 Post(s)
You beat me to it by 10 minutes! I noticed it about 20 minutes ago.
Gilbert
sebenste is offline
post #565 of 1210 Old 12-01-2006, 06:35 AM
Jason Nipp's Avatar
Snow day!
However since I'm on call today I will eventually have to venture out into the white abyss.
post #566 of 1210 Old 12-01-2006, 11:25 PM
I thought that Letterman wasn't looking as good as usual the last couple of nights. Now I know why .
post #567 of 1210 Old 12-02-2006, 08:12 PM
Jason Nipp's Avatar
I watch Leno, so couldn't say.
post #568 of 1210 Old 12-04-2006, 11:23 AM
hvs10trk's Avatar
When did Letterman go HD???
hvs10trk is offline
post #569 of 1210 Old 12-04-2006, 12:58 PM
Jeff Whitford's Avatar
A year ago
Jeff Whitford is offline
post #570 of 1210 Old 12-04-2006, 03:24 PM
You really should spend less time working and posting on this website, and actually WATCH the TV a little more often .
